[GeoNode-users] Import a CSV file to PostGis
Jeffrey Johnson ortelius at gmail.com
Thu May 7 14:39:42 PDT 2015
Israel,
I've recently written a new module for this. You can find it here
https://github.com/jj0hns0n/geonode/tree/table-join
It also provides the ability to join tabular data to existing polygon layers.
Im not sure how easy it is for you to integrate it into your
implementation, but happy to help guide you. Can you let me know your
exact use case and I can let you know if this is appropriate. Also let
me know what version you are using etc.
Jeff
On Thu, May 7, 2015 at 5:18 PM, Israel López <asralf at gmail.com> wrote:
> Good day devs and users.
> I was wondering if is there an implemented method or tool
> that could be integrated with geonode to import CSV files into
> Postgres/PostGis tables.
> I found this doc:
> https://github.com/CentroGeo/geonode/blob/master/docs/tutorials/admin/data/gdalogr.txt
> It says csv could be imported into geonode, but i found this issue too:
> https://github.com/GeoNode/geonode/issues/1066
> So, I don't know if this could help me to solve my problem??
> Could you help me?
> Thanks a lot in advance.
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
