[GeoNode-users] ppa:geonode/testing install issue
Charles Cossé
ccosse at gmail.com
Thu May 7 15:47:13 PDT 2015
Hello All,
I've just tried to install geonode ~2.4 on Ubuntu 14.04.2 using:
deb http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
deb-src http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
ppa:geonode/testing
sudo apt-get install geonode
During configuration a dpkg sub-process fails with:
---------8<----------
dpkg: error processing package geonode 99--configure):
subprocess installed post-installation script returned error exit status 1
dpkg:dependency problems prevent configuration of geonde:
geonode depnds on geoserver-geonode | geoserver; however:
Package geoserver-geonode is not configured yet.
Package geoserver is not installed.
dependency problems - leaving unconfigured
There may have been some other error preceeding these, but am using a
console so they would have scrolled-off the top. Just doing "apt-get
install geonode" again only crashes at the above, i.e. not going back to
any previous error that may have occured.
The only other detail is that I'm installing to a Raspberry-Pi according to
here <https://wiki.ubuntu.com/ARM/RaspberryPi>, but I don't see anything in
the outputs to suggest that the problem is the R-Pi.
Thanks in advance for any help!
Charles
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150507/ca0599fb/attachment.html>
More information about the geonode-users
