[GeoNode-users] ppa:geonode/testing install issue
Charles Cossé ccosse at gmail.com
Thu May 7 15:51:50 PDT 2015
Correction: doing an "apt-get install geoserver"  to try to fix the
geoserver dependency gives
E: Unable to locate package geoserver
and same with package geoserver-geonode
On Thu, May 7, 2015 at 4:47 PM, Charles Cossé <ccosse at gmail.com> wrote:
> Hello All,
> I've just tried to install geonode ~2.4 on Ubuntu 14.04.2 using:
> deb http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
> deb-src http://ppa.launchpad.net/geonode/testing/ubuntu trusty main
> ppa:geonode/testing
> sudo apt-get install geonode
> During configuration a dpkg sub-process fails with:
> ---------8<----------
> dpkg: error processing package geonode 99--configure):
>  subprocess installed post-installation script returned error exit status 1
> dpkg:dependency problems prevent configuration of geonde:
>  geonode depnds on geoserver-geonode | geoserver; however:
>  Package geoserver-geonode is not configured yet.
>  Package geoserver is not installed.
>  dependency problems - leaving unconfigured
> There may have been some other error preceeding these, but am using a
> console so they would have scrolled-off the top.   Just doing "apt-get
> install geonode" again only crashes at the above, i.e. not going back to
> any previous error that may have occured.
> The only other detail is that I'm installing to a Raspberry-Pi according
> to here <https://wiki.ubuntu.com/ARM/RaspberryPi>, but I don't see
> anything in the outputs to suggest that the problem is the R-Pi.
> Thanks in advance for any help!
> Charles
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150507/35cc091b/attachment.html>
More information about the geonode-users mailing list
