[GeoNode-users] Postgis extension on geonode DB
Renata Binotto
rbinotto at arpa.veneto.it
Wed May 13 09:08:08 PDT 2015
Hi Paolo,
bad news... we put the string
'OPTIONS': {
'options': '-c search_path=myschema,public'
in our DATABASES settings in /etc/geonode/local_settings.py but nothing
changed: when we use the command
python manage.py syncdb --database="my_external_db"
it creates the tables in the public schema again not in "myschema".
We put search_path in the postgres DB my_external_db (with psql) too,
using: SET search_path TO myschema, public.
Maybe we miss something...
Thank you.
Ciao!
Renata.
Il 12/05/2015 14:40, Paolo Corti ha scritto:
> Hi Renata
> I think you can create models for tables in a different database/schema.
> What you need to do is:
> * add a database in DATABASES as suggested by Simone and here:
> https://docs.djangoproject.com/en/1.8/topics/db/multi-db/
> * if the tables for which you want to create models are in a schema
> different from public, you may add this using the OPTIONS setting in
> the DATABASES setting:
> DATABASES = {
> 'default': {
> 'ENGINE': 'django.db.backends.sqlite3',
> 'NAME': os.path.join(BASE_DIR, 'db.sqlite3'),
> 'my_external_db' : {
> 'ENGINE': 'django.contrib.gis.db.backends.postgis',
> 'OPTIONS': {
> 'options': '-c search_path=yourschema,public'
> 'NAME': 'mydb',
> 'USER' : 'myuser',
> 'PASSWORD' :'secret',
> 'HOST' : 'myhost',
> 'PORT' : '5432',
> By the way, you can use inspectdb to reverse the postgis layers to
> django models using the --database option:
> $ python manage.py inspectdb --database my_external_db
> hope it helps
> cheers
> p
>> 2015-05-12 12:21 GMT+02:00 Renata Binotto <rbinotto at arpa.veneto.it>:
>>> Hi all,
>>> we have a DB and a postgresql schema (call it ourSchema) with some layers
>>> and some tables and we want to edit the tables using Django Admin facilities
>>> (with server_ipaddress/admin). We wrote in local_settings in /etc/geonode
>>> the connection strings for this DB (ex: ourDB, in the same server with
>>> geonode) but after some tests we understood that:
>>> -- creating a new app (with python manage.py startapp ...), a models.py
>>> with our tables and using python manage.py syncdb --database=ourDB,
>>> Geonode re-create all django tables + our tables in the public schema of
>>> ourDB ('cause there's no info in local_settings about what schema is
>>> connected ourDB);
>>> -- but these new tables in ourDB/public are not seen by
>>> server_ipaddress/admin, but they are seen only if we create them in the
>>> schema geonode(=default)/public;
>>> -- so we thought we could put ourSchema inside geonodeDB or all its
>>> tables/layers in the geonode/public schema (even if we don't like this
>>> solution too much...), but ourSchema contains layers and geonodeDB has no
>>> postgis extensions so we couldn't.
>>> At the end, some desperate questions:
>>> -- is it possible to connect django server_ipaddress/admin to tables in a
>>> different DB (putting some connection string in the app directly, for
>>> example);
>>> -- is it possible to install postgis extension on geonodeDB?
>>> Thanks!
>>> Renata.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
More information about the geonode-users
