[GeoNode-users] Problems to change the name of the geonode-imports database
Simone Dalmasso simone.dalmasso at gmail.com
Tue May 26 11:39:52 PDT 2015
Also geonode 2.4 si using two db, one for Geonode, one for data. But the
other one is called geonode_data. Instead of geonode-imports.
Il martedì 26 maggio 2015, Israel López <asralf at gmail.com> ha scritto:
> Hi Simone, looking at this question I have one related to.
> Why an older version of the installation instructions recommended the
> creation
> of two DB (geonode and geonode-imports) and now just one??? All of my
> installations have two, because of the older instructions perhaps I'm
> using a 2.4
> geonode.
> 2015-05-26 10:14 GMT-05:00 Simone Dalmasso <simone.dalmasso at gmail.com
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>>:
>> Hi Davi, actually there should not be any geonode_imports database in
>> geonode. Could it be an old database?
>> 2015-05-26 17:04 GMT+02:00 Davi Custodio <davicustodio at gmail.com
>> <javascript:_e(%7B%7D,'cvml','davicustodio at gmail.com');>>:
>>> Hello list. I'm using GeoNode 2.4.
>>> I am creating a dedicated server database, which will be housing various
>>> databases relating to various GeoNode servers.
>>> So I need to change the name of each bank, so do not coincide within the
>>> same instance of PostgreSQL.
>>> I can change the names for the "geoNode" and "geonode_data" within the
>>> local_settings.py. But on the "geoNode-imports" database (I understand that
>>> serves to record the comings layers remote harvest) could not find
>>> references to it or the local_settings.py nor in GeoNode code. I wish I
>>> could change the name of this database and then point to the new name where
>>> necessary.
>>> How do I do that? Where are the references to geonode-imports in code or
>>> in the parameterization of GeoNode?
>>> Thank you for your help.
>>> Davi de O. Custódio
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150526/6178dbc7/attachment.html>
More information about the geonode-users mailing list
