[GeoNode-users] Problems to change Geonode database name
Davi Custodio
davicustodio at gmail.com
Wed May 27 05:50:50 PDT 2015
Hello. I have problem in GeoNode 2.4 to rename the GeoNode database. I need
to change the names of "GeoNode" and "geonode_data" because I am
centralizing the databases of various GeoNode servers in the same instance
of PostgreSQL.
I changed the names in local_settings.py, and then restarted the apache,
and I received an error to Django still trying to find a database with old
name "GeoNode".
Besides local_settings.py, there is another location that I should change
the database name?
Below the full log.
Davi.
OperationalError at /
FATAL: database "geonode" does not exist
Request Method:GETRequest URL:http://muchita.cnpm.embrapa.br/Django Version:
1.6.1Exception Type:OperationalErrorException Value:
Exception Location:/usr/lib/python2.7/dist-packages/psycopg2/__init__.py in
connect, line 179Python Executable:/usr/bin/pythonPython Version:2.7.6Python
Path:
['/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/pymodules/python2.7',
'/var/www']
Server time:Qua, 27 Mai 2015 07:36:18 -0500
Traceback Switch to copy-and-paste view <http://muchita.cnpm.embrapa.br/#>
- /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
get_response
1.
response = response.render()
▶ Local vars <http://muchita.cnpm.embrapa.br/#>
- /usr/lib/python2.7/dist-packages/django/template/response.py in render
1.
self.content = self.rendered_content
rendered_content
1.
context = self.resolve_context(self.context_data)
resolve_context
1.
return RequestContext(self._request, context,
current_app=self._current_app)
- /usr/lib/python2.7/dist-packages/django/template/context.py in __init__
1.
self.update(processor(request))
- /usr/local/lib/python2.7/dist-packages/geonode/context_processors.py
in resource_urls
1.
site = Site.objects.get_current()
- /usr/lib/python2.7/dist-packages/django/contrib/sites/models.py in
get_current
1.
current_site = self.get(pk=sid)
- /usr/lib/python2.7/dist-packages/django/db/models/manager.py in get
1.
return self.get_queryset().get(*args, **kwargs)
- /usr/lib/python2.7/dist-packages/django/db/models/query.py in get
1.
num = len(clone)
- /usr/lib/python2.7/dist-packages/django/db/models/query.py in __len__
1.
self._fetch_all()
_fetch_all
1.
self._result_cache = list(self.iterator())
- /usr/lib/python2.7/dist-packages/django/db/models/query.py in iterator
1.
for row in compiler.results_iter():
- /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py in
results_iter
1.
for rows in self.execute_sql(MULTI):
execute_sql
1.
cursor = self.connection.cursor()
- /usr/lib/python2.7/dist-packages/django/db/backends/__init__.py in
cursor
1.
cursor = self.make_debug_cursor(self._cursor())
_cursor
1.
self.ensure_connection()
ensure_connection
1.
self.connect()
- /usr/lib/python2.7/dist-packages/django/db/utils.py in __exit__
1.
six.reraise(dj_exc_type, dj_exc_value, traceback)
ensure_connection
1.
self.connect()
connect
1.
self.connection = self.get_new_connection(conn_params)
/usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
in get_new_connection
1.
return Database.connect(**conn_params)
- /usr/lib/python2.7/dist-packages/psycopg2/__init__.py in connect
1.
connection_factory=connection_factory, async=async)
Request informationGET
No GET data
POST
No POST data
FILES
No FILES data
COOKIESVariableValue__utmz
'128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)'
ys-user
'o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
_ga
'GA1.2.1150756117.1398259583'
__gads
'ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ'
csrftoken
'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
s_getNewRepeat
'1423508214723-Repeat'
ys-alreadyShowMessage
'b%3A1'
__utma
'128008848.1150756117.1398259583.1432729377.1432729377.1'
__utmb
'128008848.1.10.1432729377'
__utmc
'128008848'
s_fid
'691159BDD05014BE-21BD7FC62185D9C7'
METAVariableValuemod_wsgi.listener_port
'80'
HTTP_COOKIE
'__gads=ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ;
__utmz=237664978.1423046483.18.3.utmccn=(referral)|utmcsr=google.com.br|utmcct=/|utmcmd=referral;
__utma=237664978.1207420118.1398169929.1423046483.1423244128.19;
s_fid=691159BDD05014BE-21BD7FC62185D9C7;
s_getNewRepeat=1423508214723-Repeat;
__utma=218996109.1150756117.1398259583.1432299746.1432304989.52;
__utmz=218996109.1432304989.52.23.utmcsr=chorao.cnpm.embrapa.br:9081|utmccn=(referral)|utmcmd=referral|utmcct=/;
_ga=GA1.2.1150756117.1398259583;
csrftoken=GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb;
__utma=128008848.1150756117.1398259583.1432729377.1432729377.1;
__utmb=128008848.1.10.1432729377; __utmc=128008848;
__utmz=128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none);
ys-alreadyShowMessage=b%3A1;
ys-user=o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
mod_wsgi.listener_host
CONTEXT_DOCUMENT_ROOT
'/var/www'
SERVER_SOFTWARE
'Apache/2.4.7 (Ubuntu)'
SCRIPT_NAME
u''
mod_wsgi.enable_sendfile
'0'
mod_wsgi.handler_script
SERVER_SIGNATURE
'<address>Apache/2.4.7 (Ubuntu) Server at muchita.cnpm.embrapa.br Port
80</address>\n'
REQUEST_METHOD
'GET'
PATH_INFO
u'/'
SERVER_PROTOCOL
'HTTP/1.1'
QUERY_STRING
HTTP_USER_AGENT
'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like
Gecko) Chrome/43.0.2357.65 Safari/537.36'
HTTP_CONNECTION
'keep-alive'
SERVER_NAME
'muchita.cnpm.embrapa.br'
REMOTE_ADDR
'10.157.20.55'
mod_wsgi.queue_start
'1432730176843671'
mod_wsgi.request_handler
'wsgi-script'
wsgi.url_scheme
'http'
PATH_TRANSLATED
'/var/www/geonode/wsgi/geonode.wsgi/'
SERVER_PORT
'80'
wsgi.multiprocess
True
mod_wsgi.input_chunked
'0'
SERVER_ADDR
'192.168.10.10'
DOCUMENT_ROOT
'/var/www'
mod_wsgi.process_group
'geonode'
HTTP_PRAGMA
'no-cache'
SCRIPT_FILENAME
'/var/www/geonode/wsgi/geonode.wsgi'
SERVER_ADMIN
'webmaster at localhost'
wsgi.input
<mod_wsgi.Input object at 0x7fe089acf530>
HTTP_HOST
CONTEXT_PREFIX
wsgi.multithread
True
mod_wsgi.callable_object
'application'
HTTP_CACHE_CONTROL
'no-cache'
REQUEST_URI
HTTP_ACCEPT
'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
wsgi.version
(1, 0)
GATEWAY_INTERFACE
'CGI/1.1'
wsgi.run_once
False
wsgi.errors
<mod_wsgi.Log object at 0x7fe0899a1f70>
REMOTE_PORT
'51799'
HTTP_ACCEPT_LANGUAGE
'pt-PT,pt;q=0.8,pt-BR;q=0.6,en-US;q=0.4,en;q=0.2'
REQUEST_SCHEME
'http'
mod_wsgi.version
(3, 4)
mod_wsgi.application_group
'aguai.cnpm.embrapa.br|'
mod_wsgi.script_reloading
'1'
wsgi.file_wrapper
CSRF_COOKIE
u'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
HTTP_ACCEPT_ENCODING
'gzip, deflate, sdch'
SettingsUsing settings module geonode.settingsSettingValueCASCADE_WORKSPACE
'geonode'
ACCOUNT_USER_DISPLAY
DATABASES
{'datastore': {'ATOMIC_REQUESTS': False,
'AUTOCOMMIT': True,
'CONN_MAX_AGE': 0,
'ENGINE': 'django.contrib.gis.db.backends.postgis',
'HOST': 'jatoba.cnpm.embrapa.br',
'NAME': 'geonode_data',
'OPTIONS': {},
'PASSWORD': u'********************',
'PORT': '5432',
'TEST_CHARSET': None,
'TEST_COLLATION': None,
'TEST_MIRROR': None,
'TEST_NAME': None,
'TIME_ZONE': 'America/Chicago',
'USER': 'geonode'},
'default': {'ATOMIC_REQUESTS': False,
'AUTOCOMMIT': True,
'CONN_MAX_AGE': 0,
'ENGINE': 'django.db.backends.postgresql_psycopg2',
'NAME': 'geonode',
'OPTIONS': {},
'PORT': '5432',
'TEST_NAME': None,
'USER': 'geonode'}}
GOOGLE_API_KEY
CELERY_CREATE_MISSING_QUEUES
True
CSRF_COOKIE_SECURE
False
CELERY_DEFAULT_QUEUE
'default'
UPLOADER
{'BACKEND': 'geonode.rest',
'OPTIONS': {'GEOGIG_ENABLED': False, 'TIME_ENABLED': False}}
LANGUAGE_CODE
'pt-br'
LICENSES
{'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
MANAGERS
DOWNLOAD_FORMATS_METADATA
['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
BROKER_URL
'django://'
DEFAULT_CHARSET
'utf-8'
IGNORABLE_404_URLS
CELERY_DEFAULT_EXCHANGE_TYPE
'direct'
SESSION_SERIALIZER
'django.contrib.sessions.serializers.PickleSerializer'
DEFAULT_MAP_CENTER
(0, 0)
ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
3
USE_THOUSAND_SEPARATOR
False
ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
None
ACCOUNT_INVITE_USER_URL
u'account_invite_user'
REGISTRATION_OPEN
False
ALLOWED_HOSTS
['muchita.cnpm.embrapa.br', 'localhost']
EMAIL_HOST
'localhost'
DOWNLOAD_FORMATS_RASTER
['JPEG',
'PDF',
'PNG',
'ArcGrid',
'GeoTIFF',
'Gtopo30',
'ImageMosaic',
'KML',
'View in Google Earth',
'Tiles']
AUTH_EXEMPT_URLS
WSGI_APPLICATION
None
EMAIL_SUBJECT_PREFIX
'[Django] '
SEND_BROKEN_LINK_EMAILS
False
TEMPLATE_STRING_IF_INVALID
STATICFILES_FINDERS
('django.contrib.staticfiles.finders.FileSystemFinder',
'django.contrib.staticfiles.finders.AppDirectoriesFinder')
NOTIFICATION_QUEUE_ALL
False
SESSION_CACHE_ALIAS
'default'
CELERY_IMPORTS
('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
SESSION_COOKIE_DOMAIN
None
SESSION_COOKIE_NAME
'sessionid'
ADMIN_FOR
TIME_INPUT_FORMATS
('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
ACCOUNT_USE_AUTH_AUTHENTICATE
False
X_FRAME_OPTIONS
'SAMEORIGIN'
FILE_UPLOAD_PERMISSIONS
None
ACCOUNT_TIMEZONES
[('Africa/Abidjan', 'Africa/Abidjan'),
('Africa/Accra', 'Africa/Accra'),
('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
('Africa/Algiers', 'Africa/Algiers'),
('Africa/Asmara', 'Africa/Asmara'),
('Africa/Asmera', 'Africa/Asmera'),
('Africa/Bamako', 'Africa/Bamako'),
('Africa/Bangui', 'Africa/Bangui'),
('Africa/Banjul', 'Africa/Banjul'),
('Africa/Bissau', 'Africa/Bissau'),
('Africa/Blantyre', 'Africa/Blantyre'),
('Africa/Brazzaville', 'Africa/Brazzaville'),
('Africa/Bujumbura', 'Africa/Bujumbura'),
('Africa/Cairo', 'Africa/Cairo'),
('Africa/Casablanca', 'Africa/Casablanca'),
('Africa/Ceuta', 'Africa/Ceuta'),
('Africa/Conakry', 'Africa/Conakry'),
('Africa/Dakar', 'Africa/Dakar'),
('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
('Africa/Djibouti', 'Africa/Djibouti'),
('Africa/Douala', 'Africa/Douala'),
('Africa/El_Aaiun', 'Africa/El_Aaiun'),
('Africa/Freetown', 'Africa/Freetown'),
('Africa/Gaborone', 'Africa/Gaborone'),
('Africa/Harare', 'Africa/Harare'),
('Africa/Johannesburg', 'Africa/Johannesburg'),
('Africa/Juba', 'Africa/Juba'),
('Africa/Kampala', 'Africa/Kampala'),
('Africa/Khartoum', 'Africa/Khartoum'),
('Africa/Kigali', 'Africa/Kigali'),
('Africa/Kinshasa', 'Africa/Kinshasa'),
('Africa/Lagos', 'Africa/Lagos'),
('Africa/Libreville', 'Africa/Libreville'),
('Africa/Lome', 'Africa/Lome'),
('Africa/Luanda', 'Africa/Luanda'),
('Africa/Lubumbashi', 'Africa/Lubumbashi'),
('Africa/Lusaka', 'Africa/Lusaka'),
('Africa/Malabo', 'Africa/Malabo'),
('Africa/Maputo', 'Africa/Maputo'),
('Africa/Maseru', 'Africa/Maseru'),
('Africa/Mbabane', 'Africa/Mbabane'),
('Africa/Mogadishu', 'Africa/Mogadishu'),
('Africa/Monrovia', 'Africa/Monrovia'),
('Africa/Nairobi', 'Africa/Nairobi'),
('Africa/Ndjamena', 'Africa/Ndjamena'),
('Africa/Niamey', 'Africa/Niamey'),
('Africa/Nouakchott', 'Africa/Nouakchott'),
('Africa/Ouagadougou', 'Africa/Ouagadougou'),
('Africa/Porto-Novo', 'Africa/Porto-Novo'),
('Africa/Sao_Tome', 'Africa/Sao_Tome'),
('Africa/Timbuktu', 'Africa/Timbuktu'),
('Africa/Tripoli', 'Africa/Tripoli'),
('Africa/Tunis', 'Africa/Tunis'),
('Africa/Windhoek', 'Africa/Windhoek'),
('America/Adak', 'America/Adak'),
('America/Anchorage', 'America/Anchorage'),
('America/Anguilla', 'America/Anguilla'),
('America/Antigua', 'America/Antigua'),
('America/Araguaina', 'America/Araguaina'),
('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
('America/Argentina/Salta', 'America/Argentina/Salta'),
('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
('America/Aruba', 'America/Aruba'),
('America/Asuncion', 'America/Asuncion'),
('America/Atikokan', 'America/Atikokan'),
('America/Atka', 'America/Atka'),
('America/Bahia', 'America/Bahia'),
('America/Bahia_Banderas', 'America/Bahia_Banderas'),
('America/Barbados', 'America/Barbados'),
('America/Belem', 'America/Belem'),
('America/Belize', 'America/Belize'),
('America/Blanc-Sablon', 'America/Blanc-Sablon'),
('America/Boa_Vista', 'America/Boa_Vista'),
('America/Bogota', 'America/Bogota'),
('America/Boise', 'America/Boise'),
('America/Buenos_Aires', 'America/Buenos_Aires'),
('America/Cambridge_Bay', 'America/Cambridge_Bay'),
('America/Campo_Grande', 'America/Campo_Grande'),
('America/Cancun', 'America/Cancun'),
('America/Caracas', 'America/Caracas'),
('America/Catamarca', 'America/Catamarca'),
('America/Cayenne', 'America/Cayenne'),
('America/Cayman', 'America/Cayman'),
('America/Chicago', 'America/Chicago'),
('America/Chihuahua', 'America/Chihuahua'),
('America/Coral_Harbour', 'America/Coral_Harbour'),
('America/Cordoba', 'America/Cordoba'),
('America/Costa_Rica', 'America/Costa_Rica'),
('America/Creston', 'America/Creston'),
('America/Cuiaba', 'America/Cuiaba'),
('America/Curacao', 'America/Curacao'),
('America/Danmarkshavn', 'America/Danmarkshavn'),
('America/Dawson', 'America/Dawson'),
('America/Dawson_Creek', 'America/Dawson_Creek'),
('America/Denver', 'America/Denver'),
('America/Detroit', 'America/Detroit'),
('America/Dominica', 'America/Dominica'),
('America/Edmonton', 'America/Edmonton'),
('America/Eirunepe', 'America/Eirunepe'),
('America/El_Salvador', 'America/El_Salvador'),
('America/Ensenada', 'America/Ensenada'),
('America/Fort_Wayne', 'America/Fort_Wayne'),
('America/Fortaleza', 'America/Fortaleza'),
('America/Glace_Bay', 'America/Glace_Bay'),
('America/Godthab', 'America/Godthab'),
('America/Goose_Bay', 'America/Goose_Bay'),
('America/Grand_Turk', 'America/Grand_Turk'),
('America/Grenada', 'America/Grenada'),
('America/Guadeloupe', 'America/Guadeloupe'),
('America/Guatemala', 'America/Guatemala'),
('America/Guayaquil', 'America/Guayaquil'),
('America/Guyana', 'America/Guyana'),
('America/Halifax', 'America/Halifax'),
('America/Havana', 'America/Havana'),
('America/Hermosillo', 'America/Hermosillo'),
('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
('America/Indiana/Knox', 'America/Indiana/Knox'),
('America/Indiana/Marengo', 'America/Indiana/Marengo'),
('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
('America/Indiana/Vevay', 'America/Indiana/Vevay'),
('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
('America/Indiana/Winamac', 'America/Indiana/Winamac'),
('America/Indianapolis', 'America/Indianapolis'),
('America/Inuvik', 'America/Inuvik'),
('America/Iqaluit', 'America/Iqaluit'),
('America/Jamaica', 'America/Jamaica'),
('America/Jujuy', 'America/Jujuy'),
('America/Juneau', 'America/Juneau'),
('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
('America/Knox_IN', 'America/Knox_IN'),
('America/Kralendijk', 'America/Kralendijk'),
('America/La_Paz', 'America/La_Paz'),
('America/Lima', 'America/Lima'),
('America/Los_Angeles', 'America/Los_Angeles'),
('America/Louisville', 'America/Louisville'),
('America/Lower_Princes', 'America/Lower_Princes'),
('America/Maceio', 'America/Maceio'),
('America/Managua', 'America/Managua'),
('America/Manaus', 'America/Manaus'),
('America/Marigot', 'America/Marigot'),
('America/Martinique', 'America/Martinique'),
('America/Matamoros', 'America/Matamoros'),
('America/Mazatlan', 'America/Mazatlan'),
('America/Mendoza', 'America/Mendoza'),
('America/Menominee', 'America/Menominee'),
('America/Merida', 'America/Merida'),
('America/Metlakatla', 'America/Metlakatla'),
('America/Mexico_City', 'America/Mexico_City'),
('America/Miquelon', 'America/Miquelon'),
('America/Moncton', 'America/Moncton'),
('America/Monterrey', 'America/Monterrey'),
('America/Montevideo', 'America/Montevideo'),
('America/Montreal', 'America/Montreal'),
('America/Montserrat', 'America/Montserrat'),
('America/Nassau', 'America/Nassau'),
('America/New_York', 'America/New_York'),
('America/Nipigon', 'America/Nipigon'),
('America/Nome', 'America/Nome'),
('America/Noronha', 'America/Noronha'),
('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
('America/North_Dakota/Center', 'America/North_Dakota/Center'),
('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
('America/Ojinaga', 'America/Ojinaga'),
('America/Panama', 'America/Panama'),
('America/Pangnirtung', 'America/Pangnirtung'),
('America/Paramaribo', 'America/Paramaribo'),
('America/Phoenix', 'America/Phoenix'),
('America/Port-au-Prince', 'America/Port-au-Prince'),
('America/Port_of_Spain', 'America/Port_of_Spain'),
('America/Porto_Acre', 'America/Porto_Acre'),
('America/Porto_Velho', 'America/Porto_Velho'),
('America/Puerto_Rico', 'America/Puerto_Rico'),
('America/Rainy_River', 'America/Rainy_River'),
('America/Rankin_Inlet', 'America/Rankin_Inlet'),
('America/Recife', 'America/Recife'),
('America/Regina', 'America/Regina'),
('America/Resolute', 'America/Resolute'),
('America/Rio_Branco', 'America/Rio_Branco'),
('America/Rosario', 'America/Rosario'),
('America/Santa_Isabel', 'America/Santa_Isabel'),
('America/Santarem', 'America/Santarem'),
('America/Santiago', 'America/Santiago'),
('America/Santo_Domingo', 'America/Santo_Domingo'),
('America/Sao_Paulo', 'America/Sao_Paulo'),
('America/Scoresbysund', 'America/Scoresbysund'),
('America/Shiprock', 'America/Shiprock'),
('America/Sitka', 'America/Sitka'),
('America/St_Barthelemy', 'America/St_Barthelemy'),
('America/St_Johns', 'America/St_Johns'),
('America/St_Kitts', 'America/St_Kitts'),
('America/St_Lucia', 'America/St_Lucia'),
('America/St_Thomas', 'America/St_Thomas'),
('America/St_Vincent', 'America/St_Vincent'),
('America/Swift_Current', 'America/Swift_Current'),
('America/Tegucigalpa', 'America/Tegucigalpa'),
('America/Thule', 'America/Thule'),
('America/Thunder_Bay', 'America/Thunder_Bay'),
('America/Tijuana', 'America/Tijuana'),
('America/Toronto', 'America/Toronto'),
('America/Tortola', 'America/Tortola'),
('America/Vancouver', 'America/Vancouver'),
('America/Virgin', 'America/Virgin'),
('America/Whitehorse', 'America/Whitehorse'),
('America/Winnipeg', 'America/Winnipeg'),
('America/Yakutat', 'America/Yakutat'),
('America/Yellowknife', 'America/Yellowknife'),
('Antarctica/Casey', 'Antarctica/Casey'),
('Antarctica/Davis', 'Antarctica/Davis'),
('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
('Antarctica/Macquarie', 'Antarctica/Macquarie'),
('Antarctica/Mawson', 'Antarctica/Mawson'),
('Antarctica/McMurdo', 'Antarctica/McMurdo'),
('Antarctica/Palmer', 'Antarctica/Palmer'),
('Antarctica/Rothera', 'Antarctica/Rothera'),
('Antarctica/South_Pole', 'Antarctica/South_Pole'),
('Antarctica/Syowa', 'Antarctica/Syowa'),
('Antarctica/Vostok', 'Antarctica/Vostok'),
('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
('Asia/Aden', 'Asia/Aden'),
('Asia/Almaty', 'Asia/Almaty'),
('Asia/Amman', 'Asia/Amman'),
('Asia/Anadyr', 'Asia/Anadyr'),
('Asia/Aqtau', 'Asia/Aqtau'),
('Asia/Aqtobe', 'Asia/Aqtobe'),
('Asia/Ashgabat', 'Asia/Ashgabat'),
('Asia/Ashkhabad', 'Asia/Ashkhabad'),
('Asia/Baghdad', 'Asia/Baghdad'),
('Asia/Bahrain', 'Asia/Bahrain'),
('Asia/Baku', 'Asia/Baku'),
('Asia/Bangkok', 'Asia/Bangkok'),
('Asia/Beirut', 'Asia/Beirut'),
('Asia/Bishkek', 'Asia/Bishkek'),
('Asia/Brunei', 'Asia/Brunei'),
('Asia/Calcutta', 'Asia/Calcutta'),
('Asia/Choibalsan', 'Asia/Choibalsan'),
('Asia/Chongqing', 'Asia/Chongqing'),
('Asia/Chungking', 'Asia/Chungking'),
('Asia/Colombo', 'Asia/Colombo'),
('Asia/Dacca', 'Asia/Dacca'),
('Asia/Damascus', 'Asia/Damascus'),
('Asia/Dhaka', 'Asia/Dhaka'),
('Asia/Dili', 'Asia/Dili'),
('Asia/Dubai', 'Asia/Dubai'),
('Asia/Dushanbe', 'Asia/Dushanbe'),
('Asia/Gaza', 'Asia/Gaza'),
('Asia/Harbin', 'Asia/Harbin'),
('Asia/Hebron', 'Asia/Hebron'),
('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
('Asia/Hong_Kong', 'Asia/Hong_Kong'),
('Asia/Hovd', 'Asia/Hovd'),
('Asia/Irkutsk', 'Asia/Irkutsk'),
('Asia/Istanbul', 'Asia/Istanbul'),
('Asia/Jakarta', 'Asia/Jakarta'),
('Asia/Jayapura', 'Asia/Jayapura'),
('Asia/Jerusalem', 'Asia/Jerusalem'),
('Asia/Kabul', 'Asia/Kabul'),
('Asia/Kamchatka', 'Asia/Kamchatka'),
('Asia/Karachi', 'Asia/Karachi'),
('Asia/Kashgar', 'Asia/Kashgar'),
('Asia/Kathmandu', 'Asia/Kathmandu'),
('Asia/Katmandu', 'Asia/Katmandu'),
('Asia/Kolkata', 'Asia/Kolkata'),
('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
('Asia/Kuching', 'Asia/Kuching'),
('Asia/Kuwait', 'Asia/Kuwait'),
('Asia/Macao', 'Asia/Macao'),
('Asia/Macau', 'Asia/Macau'),
('Asia/Magadan', 'Asia/Magadan'),
('Asia/Makassar', 'Asia/Makassar'),
('Asia/Manila', 'Asia/Manila'),
('Asia/Muscat', 'Asia/Muscat'),
('Asia/Nicosia', 'Asia/Nicosia'),
('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
('Asia/Novosibirsk', 'Asia/Novosibirsk'),
('Asia/Omsk', 'Asia/Omsk'),
('Asia/Oral', 'Asia/Oral'),
('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
('Asia/Pontianak', 'Asia/Pontianak'),
('Asia/Pyongyang', 'Asia/Pyongyang'),
('Asia/Qatar', 'Asia/Qatar'),
('Asia/Qyzylorda', 'Asia/Qyzylorda'),
('Asia/Rangoon', 'Asia/Rangoon'),
('Asia/Riyadh', 'Asia/Riyadh'),
('Asia/Saigon', 'Asia/Saigon'),
('Asia/Sakhalin', 'Asia/Sakhalin'),
('Asia/Samarkand', 'Asia/Samarkand'),
('Asia/Seoul', 'Asia/Seoul'),
('Asia/Shanghai', 'Asia/Shanghai'),
('Asia/Singapore', 'Asia/Singapore'),
('Asia/Taipei', 'Asia/Taipei'),
('Asia/Tashkent', 'Asia/Tashkent'),
('Asia/Tbilisi', 'Asia/Tbilisi'),
('Asia/Tehran', 'Asia/Tehran'),
('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
('Asia/Thimbu', 'Asia/Thimbu'),
('Asia/Thimphu', 'Asia/Thimphu'),
('Asia/Tokyo', 'Asia/Tokyo'),
('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
('Asia/Urumqi', 'Asia/Urumqi'),
('Asia/Vientiane', 'Asia/Vientiane'),
('Asia/Vladivostok', 'Asia/Vladivostok'),
('Asia/Yakutsk', 'Asia/Yakutsk'),
('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
('Asia/Yerevan', 'Asia/Yerevan'),
('Atlantic/Azores', 'Atlantic/Azores'),
('Atlantic/Bermuda', 'Atlantic/Bermuda'),
('Atlantic/Canary', 'Atlantic/Canary'),
('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
('Atlantic/Faeroe', 'Atlantic/Faeroe'),
('Atlantic/Faroe', 'Atlantic/Faroe'),
('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
('Atlantic/Madeira', 'Atlantic/Madeira'),
('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
('Atlantic/St_Helena', 'Atlantic/St_Helena'),
('Atlantic/Stanley', 'Atlantic/Stanley'),
('Australia/ACT', 'Australia/ACT'),
('Australia/Adelaide', 'Australia/Adelaide'),
('Australia/Brisbane', 'Australia/Brisbane'),
('Australia/Broken_Hill', 'Australia/Broken_Hill'),
('Australia/Canberra', 'Australia/Canberra'),
('Australia/Currie', 'Australia/Currie'),
('Australia/Darwin', 'Australia/Darwin'),
('Australia/Eucla', 'Australia/Eucla'),
('Australia/Hobart', 'Australia/Hobart'),
('Australia/LHI', 'Australia/LHI'),
('Australia/Lindeman', 'Australia/Lindeman'),
('Australia/Lord_Howe', 'Australia/Lord_Howe'),
('Australia/Melbourne', 'Australia/Melbourne'),
('Australia/NSW', 'Australia/NSW'),
('Australia/North', 'Australia/North'),
('Australia/Perth', 'Australia/Perth'),
('Australia/Queensland', 'Australia/Queensland'),
('Australia/South', 'Australia/South'),
('Australia/Sydney', 'Australia/Sydney'),
('Australia/Tasmania', 'Australia/Tasmania'),
('Australia/Victoria', 'Australia/Victoria'),
('Australia/West', 'Australia/West'),
('Australia/Yancowinna', 'Australia/Yancowinna'),
('Brazil/Acre', 'Brazil/Acre'),
('Brazil/DeNoronha', 'Brazil/DeNoronha'),
('Brazil/East', 'Brazil/East'),
('Brazil/West', 'Brazil/West'),
('CET', 'CET'),
('CST6CDT', 'CST6CDT'),
('Canada/Atlantic', 'Canada/Atlantic'),
('Canada/Central', 'Canada/Central'),
('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
('Canada/Eastern', 'Canada/Eastern'),
('Canada/Mountain', 'Canada/Mountain'),
('Canada/Newfoundland', 'Canada/Newfoundland'),
('Canada/Pacific', 'Canada/Pacific'),
('Canada/Saskatchewan', 'Canada/Saskatchewan'),
('Canada/Yukon', 'Canada/Yukon'),
('Chile/Continental', 'Chile/Continental'),
('Chile/EasterIsland', 'Chile/EasterIsland'),
('Cuba', 'Cuba'),
('EET', 'EET'),
('EST', 'EST'),
('EST5EDT', 'EST5EDT'),
('Egypt', 'Egypt'),
('Eire', 'Eire'),
('Etc/GMT', 'Etc/GMT'),
('Etc/GMT+0', 'Etc/GMT+0'),
('Etc/GMT+1', 'Etc/GMT+1'),
('Etc/GMT+10', 'Etc/GMT+10'),
('Etc/GMT+11', 'Etc/GMT+11'),
('Etc/GMT+12', 'Etc/GMT+12'),
('Etc/GMT+2', 'Etc/GMT+2'),
('Etc/GMT+3', 'Etc/GMT+3'),
('Etc/GMT+4', 'Etc/GMT+4'),
('Etc/GMT+5', 'Etc/GMT+5'),
('Etc/GMT+6', 'Etc/GMT+6'),
('Etc/GMT+7', 'Etc/GMT+7'),
('Etc/GMT+8', 'Etc/GMT+8'),
('Etc/GMT+9', 'Etc/GMT+9'),
('Etc/GMT-0', 'Etc/GMT-0'),
('Etc/GMT-1', 'Etc/GMT-1'),
('Etc/GMT-10', 'Etc/GMT-10'),
('Etc/GMT-11', 'Etc/GMT-11'),
('Etc/GMT-12', 'Etc/GMT-12'),
('Etc/GMT-13', 'Etc/GMT-13'),
('Etc/GMT-14', 'Etc/GMT-14'),
('Etc/GMT-2', 'Etc/GMT-2'),
('Etc/GMT-3', 'Etc/GMT-3'),
('Etc/GMT-4', 'Etc/GMT-4'),
('Etc/GMT-5', 'Etc/GMT-5'),
('Etc/GMT-6', 'Etc/GMT-6'),
('Etc/GMT-7', 'Etc/GMT-7'),
('Etc/GMT-8', 'Etc/GMT-8'),
('Etc/GMT-9', 'Etc/GMT-9'),
('Etc/GMT0', 'Etc/GMT0'),
('Etc/Greenwich', 'Etc/Greenwich'),
('Etc/UCT', 'Etc/UCT'),
('Etc/UTC', 'Etc/UTC'),
('Etc/Universal', 'Etc/Universal'),
('Etc/Zulu', 'Etc/Zulu'),
('Europe/Amsterdam', 'Europe/Amsterdam'),
('Europe/Andorra', 'Europe/Andorra'),
('Europe/Athens', 'Europe/Athens'),
('Europe/Belfast', 'Europe/Belfast'),
('Europe/Belgrade', 'Europe/Belgrade'),
('Europe/Berlin', 'Europe/Berlin'),
('Europe/Bratislava', 'Europe/Bratislava'),
('Europe/Brussels', 'Europe/Brussels'),
('Europe/Bucharest', 'Europe/Bucharest'),
('Europe/Budapest', 'Europe/Budapest'),
('Europe/Chisinau', 'Europe/Chisinau'),
('Europe/Copenhagen', 'Europe/Copenhagen'),
('Europe/Dublin', 'Europe/Dublin'),
('Europe/Gibraltar', 'Europe/Gibraltar'),
('Europe/Guernsey', 'Europe/Guernsey'),
('Europe/Helsinki', 'Europe/Helsinki'),
('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
('Europe/Istanbul', 'Europe/Istanbul'),
('Europe/Jersey', 'Europe/Jersey'),
('Europe/Kaliningrad', 'Europe/Kaliningrad'),
('Europe/Kiev', 'Europe/Kiev'),
('Europe/Lisbon', 'Europe/Lisbon'),
('Europe/Ljubljana', 'Europe/Ljubljana'),
('Europe/London', 'Europe/London'),
('Europe/Luxembourg', 'Europe/Luxembourg'),
('Europe/Madrid', 'Europe/Madrid'),
('Europe/Malta', 'Europe/Malta'),
('Europe/Mariehamn', 'Europe/Mariehamn'),
('Europe/Minsk', 'Europe/Minsk'),
('Europe/Monaco', 'Europe/Monaco'),
('Europe/Moscow', 'Europe/Moscow'),
('Europe/Nicosia', 'Europe/Nicosia'),
('Europe/Oslo', 'Europe/Oslo'),
('Europe/Paris', 'Europe/Paris'),
('Europe/Podgorica', 'Europe/Podgorica'),
('Europe/Prague', 'Europe/Prague'),
('Europe/Riga', 'Europe/Riga'),
('Europe/Rome', 'Europe/Rome'),
('Europe/Samara', 'Europe/Samara'),
('Europe/San_Marino', 'Europe/San_Marino'),
('Europe/Sarajevo', 'Europe/Sarajevo'),
('Europe/Simferopol', 'Europe/Simferopol'),
('Europe/Skopje', 'Europe/Skopje'),
('Europe/Sofia', 'Europe/Sofia'),
('Europe/Stockholm', 'Europe/Stockholm'),
('Europe/Tallinn', 'Europe/Tallinn'),
('Europe/Tirane', 'Europe/Tirane'),
('Europe/Tiraspol', 'Europe/Tiraspol'),
('Europe/Uzhgorod', 'Europe/Uzhgorod'),
('Europe/Vaduz', 'Europe/Vaduz'),
('Europe/Vatican', 'Europe/Vatican'),
('Europe/Vienna', 'Europe/Vienna'),
('Europe/Vilnius', 'Europe/Vilnius'),
('Europe/Volgograd', 'Europe/Volgograd'),
('Europe/Warsaw', 'Europe/Warsaw'),
('Europe/Zagreb', 'Europe/Zagreb'),
('Europe/Zaporozhye', 'Europe/Zaporozhye'),
('Europe/Zurich', 'Europe/Zurich'),
('GB', 'GB'),
('GB-Eire', 'GB-Eire'),
('GMT', 'GMT'),
('GMT+0', 'GMT+0'),
('GMT-0', 'GMT-0'),
('GMT0', 'GMT0'),
('Greenwich', 'Greenwich'),
('HST', 'HST'),
('Hongkong', 'Hongkong'),
('Iceland', 'Iceland'),
('Indian/Antananarivo', 'Indian/Antananarivo'),
('Indian/Chagos', 'Indian/Chagos'),
('Indian/Christmas', 'Indian/Christmas'),
('Indian/Cocos', 'Indian/Cocos'),
('Indian/Comoro', 'Indian/Comoro'),
('Indian/Kerguelen', 'Indian/Kerguelen'),
('Indian/Mahe', 'Indian/Mahe'),
('Indian/Maldives', 'Indian/Maldives'),
('Indian/Mauritius', 'Indian/Mauritius'),
('Indian/Mayotte', 'Indian/Mayotte'),
('Indian/Reunion', 'Indian/Reunion'),
('Iran', 'Iran'),
('Israel', 'Israel'),
('Jamaica', 'Jamaica'),
('Japan', 'Japan'),
('Kwajalein', 'Kwajalein'),
('Libya', 'Libya'),
('MET', 'MET'),
('MST', 'MST'),
('MST7MDT', 'MST7MDT'),
('Mexico/BajaNorte', 'Mexico/BajaNorte'),
('Mexico/BajaSur', 'Mexico/BajaSur'),
('Mexico/General', 'Mexico/General'),
('NZ', 'NZ'),
('NZ-CHAT', 'NZ-CHAT'),
('Navajo', 'Navajo'),
('PRC', 'PRC'),
('PST8PDT', 'PST8PDT'),
('Pacific/Apia', 'Pacific/Apia'),
('Pacific/Auckland', 'Pacific/Auckland'),
('Pacific/Chatham', 'Pacific/Chatham'),
('Pacific/Chuuk', 'Pacific/Chuuk'),
('Pacific/Easter', 'Pacific/Easter'),
('Pacific/Efate', 'Pacific/Efate'),
('Pacific/Enderbury', 'Pacific/Enderbury'),
('Pacific/Fakaofo', 'Pacific/Fakaofo'),
('Pacific/Fiji', 'Pacific/Fiji'),
('Pacific/Funafuti', 'Pacific/Funafuti'),
('Pacific/Galapagos', 'Pacific/Galapagos'),
('Pacific/Gambier', 'Pacific/Gambier'),
('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
('Pacific/Guam', 'Pacific/Guam'),
('Pacific/Honolulu', 'Pacific/Honolulu'),
('Pacific/Johnston', 'Pacific/Johnston'),
('Pacific/Kiritimati', 'Pacific/Kiritimati'),
('Pacific/Kosrae', 'Pacific/Kosrae'),
('Pacific/Kwajalein', 'Pacific/Kwajalein'),
('Pacific/Majuro', 'Pacific/Majuro'),
('Pacific/Marquesas', 'Pacific/Marquesas'),
('Pacific/Midway', 'Pacific/Midway'),
('Pacific/Nauru', 'Pacific/Nauru'),
('Pacific/Niue', 'Pacific/Niue'),
('Pacific/Norfolk', 'Pacific/Norfolk'),
('Pacific/Noumea', 'Pacific/Noumea'),
('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
('Pacific/Palau', 'Pacific/Palau'),
('Pacific/Pitcairn', 'Pacific/Pitcairn'),
('Pacific/Pohnpei', 'Pacific/Pohnpei'),
('Pacific/Ponape', 'Pacific/Ponape'),
('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
('Pacific/Rarotonga', 'Pacific/Rarotonga'),
('Pacific/Saipan', 'Pacific/Saipan'),
('Pacific/Samoa', 'Pacific/Samoa'),
('Pacific/Tahiti', 'Pacific/Tahiti'),
('Pacific/Tarawa', 'Pacific/Tarawa'),
('Pacific/Tongatapu', 'Pacific/Tongatapu'),
('Pacific/Truk', 'Pacific/Truk'),
('Pacific/Wake', 'Pacific/Wake'),
('Pacific/Wallis', 'Pacific/Wallis'),
('Pacific/Yap', 'Pacific/Yap'),
('Poland', 'Poland'),
('Portugal', 'Portugal'),
('ROC', 'ROC'),
('ROK', 'ROK'),
('Singapore', 'Singapore'),
('Turkey', 'Turkey'),
('UCT', 'UCT'),
('US/Alaska', 'US/Alaska'),
('US/Aleutian', 'US/Aleutian'),
('US/Arizona', 'US/Arizona'),
('US/Central', 'US/Central'),
('US/East-Indiana', 'US/East-Indiana'),
('US/Eastern', 'US/Eastern'),
('US/Hawaii', 'US/Hawaii'),
('US/Indiana-Starke', 'US/Indiana-Starke'),
('US/Michigan', 'US/Michigan'),
('US/Mountain', 'US/Mountain'),
('US/Pacific', 'US/Pacific'),
('US/Pacific-New', 'US/Pacific-New'),
('US/Samoa', 'US/Samoa'),
('UTC', 'UTC'),
('Universal', 'Universal'),
('W-SU', 'W-SU'),
('WET', 'WET'),
('Zulu', 'Zulu')]
FILE_UPLOAD_HANDLERS
('django.core.files.uploadhandler.MemoryFileUploadHandler',
'django.core.files.uploadhandler.TemporaryFileUploadHandler')
DEFAULT_CONTENT_TYPE
'text/html'
DEBUG_STATIC
False
ACCOUNT_APPROVAL_REQUIRED
False
APPEND_SLASH
True
FIRST_DAY_OF_WEEK
0
DATABASE_ROUTERS
DEFAULT_TABLESPACE
YEAR_MONTH_FORMAT
'F Y'
STATICFILES_STORAGE
'django.contrib.staticfiles.storage.StaticFilesStorage'
CACHES
{'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
True
CKAN_ORIGINS
[{'css_class': 'hdx',
'label': 'Humanitarian Data Exchange (HDX)',
'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}¬es={abstract}&caveats={caveats}'}]
ACCOUNT_EMAIL_CONFIRMATION_EMAIL
False
SERVER_EMAIL
'root at localhost'
SESSION_COOKIE_PATH
USE_X_FORWARDED_HOST
False
ACCOUNT_OPEN_SIGNUP
True
ROOT_URLCONF
'geonode.urls'
CATALOGUE
{'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
'URL': 'http://muchita.cnpm.embrapa.br/catalogue/csw'}}
MISSING_THUMBNAIL
'geonode/img/missing_thumb.png'
FILE_UPLOAD_TEMP_DIR
None
MIDDLEWARE_CLASSES
('django.middleware.common.CommonMiddleware',
'django.contrib.sessions.middleware.SessionMiddleware',
'django.contrib.messages.middleware.MessageMiddleware',
'django.middleware.locale.LocaleMiddleware',
'pagination.middleware.PaginationMiddleware',
'django.middleware.csrf.CsrfViewMiddleware',
'django.contrib.auth.middleware.AuthenticationMiddleware',
'django.middleware.clickjacking.XFrameOptionsMiddleware')
USE_I18N
True
THOUSAND_SEPARATOR
SECRET_KEY
MODELTRANSLATION_FALLBACK_LANGUAGES
('en',)
LANGUAGE_COOKIE_NAME
'django_language'
ACCOUNT_REMEMBER_ME_EXPIRY
315360000
ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
ACCOUNT_EMAIL_UNIQUE
True
TRANSACTIONS_MANAGED
False
LOGGING_CONFIG
'django.utils.log.dictConfig'
TEMPLATE_LOADERS
('django.template.loaders.filesystem.Loader',
'django.template.loaders.app_directories.Loader')
FORCE_SCRIPT_NAME
None
TASTYPIE_DEFAULT_FORMATS
['json']
TEMPLATE_DEBUG
True
AUTO_GENERATE_AVATAR_SIZES
(20, 32, 80, 100, 140, 200)
CSRF_COOKIE_NAME
'csrftoken'
'default'
CELERY_DEFAULT_ROUTING_KEY
ACCOUNT_LOGIN_REDIRECT_URL
u'/'
CELERY_ALWAYS_EAGER
True
MODIFY_TOPICCATEGORY
False
SIGNING_BACKEND
'django.core.signing.TimestampSigner'
SESSION_COOKIE_SECURE
False
ACCOUNT_LOGIN_URL
u'account_login'
CACHE_TIME
0
PYCSW
{'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
'contact_email': 'Email Address',
'contact_name': 'Organization Name',
'date': 'YYYY-MM-DD',
'default_language': 'eng',
'enabled': 'true',
'gemet_keywords': 'Utility and
governmental services',
'languages_supported': 'eng,gre',
'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
'metadata:main': {'contact_address': 'Mailing Address',
'contact_city': 'City',
'contact_country': 'Country',
'contact_fax': '+xx-xxx-xxx-xxxx',
'contact_hours': 'Hours of Service',
'contact_instructions': 'During
hours of service. Off on weekends.',
'contact_name': 'Lastname, Firstname',
'contact_phone': '+xx-xxx-xxx-xxxx',
'contact_position': 'Position Title',
'contact_postalcode': 'Zip or Postal Code',
'contact_role': 'pointOfContact',
'contact_stateorprovince':
'Administrative Area',
'contact_url': 'Contact URL',
'identification_abstract':
'GeoNode is an open source platform that facilitates the creation,
sharing, and collaborative use of geospatial data',
'identification_accessconstraints': 'None',
'identification_fees': 'None',
'identification_keywords':
'sdi,catalogue,discovery,metadata,GeoNode',
'identification_keywords_type': 'theme',
'identification_title': 'GeoNode
Catalogue',
'provider_name': 'Organization Name',
'provider_url': 'http://localhost:8000/'}}}
CSRF_COOKIE_DOMAIN
None
FILE_CHARSET
'utf-8'
DEBUG
True
SESSION_FILE_PATH
None
DEFAULT_FILE_STORAGE
'django.core.files.storage.FileSystemStorage'
INSTALLED_APPS
('django.contrib.auth',
'django.contrib.contenttypes',
'django.contrib.sessions',
'django.contrib.sites',
'django.contrib.admin',
'django.contrib.sitemaps',
'django.contrib.staticfiles',
'django.contrib.messages',
'django.contrib.humanize',
'django.contrib.gis',
'pagination',
'taggit',
'friendlytagloader',
'geoexplorer',
'leaflet',
'django_extensions',
'autocomplete_light',
'mptt',
'modeltranslation',
'djcelery',
'pinax_theme_bootstrap_account',
'pinax_theme_bootstrap',
'django_forms_bootstrap',
'account',
'avatar',
'dialogos',
'agon_ratings',
'announcements',
'actstream',
'user_messages',
'tastypie',
'polymorphic',
'guardian',
'geonode.people',
'geonode.base',
'geonode.layers',
'geonode.maps',
'geonode.proxy',
'geonode.security',
'geonode.social',
'geonode.catalogue',
'geonode.documents',
'geonode.api',
'geonode.groups',
'geonode.services',
'geonode.geoserver',
'geonode.upload',
'geonode.tasks')
LANGUAGES_BIDI
('he', 'ar', 'fa', 'ur')
USE_L10N
False
DATABASE_ENGINE
'postgresql_psycopg2'
STATIC_ROOT
'/var/www/geonode/static/'
STATICFILES_DIRS
['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
DATABASE_NAME
'geonode'
LEAFLET_CONFIG
{'PLUGINS': {u'ALL': {u'css': [u'/static/leaflet/draw/leaflet.draw.css',
'/static/lib/css/leaflet.fullscreen.css'],
u'js': [u'/static/leaflet/draw/leaflet.draw.js',
u'/static/leaflet/leaflet.extras.js',
u'/static/leaflet/leaflet.forms.js',
'/static/lib/js/Leaflet.fullscreen.min.js',
'/static/lib/js/esri-leaflet.js']},
u'__default__': {u'css':
['/static/lib/css/leaflet.fullscreen.css'],
u'js':
['/static/lib/js/Leaflet.fullscreen.min.js',
u'__is_normalized__': True,
'esri-leaflet': {'auto-include': True,
u'css': [],
'js': ['/static/lib/js/esri-leaflet.js']},
u'forms': {u'auto-include': False,
u'css': [u'/static/leaflet/draw/leaflet.draw.css'],
u'/static/leaflet/leaflet.forms.js']},
'leaflet-fullscreen': {'auto-include': True,
'css':
'js':
['/static/lib/js/Leaflet.fullscreen.min.js']}},
'TILES': [('Watercolor',
'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png',
'Map tiles by <a href="http://stamen.com">Stamen
Design</a>, <a
href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a>
— Map data © <a
href="http://openstreetmap.org">OpenStreetMap</a> contributors,
<a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'),
('Toner Lite',
'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png',
Design</a>, <a
— Map data © <a
<a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>')]}
DOWNLOAD_FORMATS_VECTOR
['JPEG',
'PDF',
'PNG',
'Zipped Shapefile',
'GML 2.0',
'GML 3.1.1',
'CSV',
'Excel',
'GeoJSON',
'KML',
'Tiles']
PREPEND_WWW
False
SECURE_PROXY_SSL_HEADER
None
SOCIAL_ORIGINS
[{'css_class': 'email',
'label': 'Email',
'url': 'mailto:?subject={name}&body={url}'},
{'css_class': 'fb',
'label': 'Facebook',
'url': 'http://www.facebook.com/sharer.php?u={url}'},
{'css_class': 'tw',
'label': 'Twitter',
'url': 'https://twitter.com/share?url={url}'},
{'css_class': 'gp',
'label': 'Google +',
'url': 'https://plus.google.com/share?url={url}'}]
ACCOUNT_PASSWORD_RESET_REDIRECT_URL
SESSION_COOKIE_HTTPONLY
True
DATABASE_PORT
'5432'
DEBUG_PROPAGATE_EXCEPTIONS
False
DEFAULT_ANONYMOUS_VIEW_PERMISSION
True
MEDIA_URL
'/uploaded/'
MONTH_DAY_FORMAT
'F j'
ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
u'account_login'
LOGIN_URL
'/account/login/'
SESSION_EXPIRE_AT_BROWSER_CLOSE
False
OGP_URL
'http://geodata.tufts.edu/solr/select'
CELERY_EAGER_PROPAGATES_EXCEPTIONS
True
TIME_FORMAT
'P'
CELERY_IGNORE_RESULT
True
SERVICE_UPDATE_INTERVAL
0
AUTH_USER_MODEL
'people.Profile'
DATE_INPUT_FORMATS
('%Y-%m-%d',
'%m/%d/%Y',
'%m/%d/%y',
'%b %d %Y',
'%b %d, %Y',
'%d %b %Y',
'%d %b, %Y',
'%B %d %Y',
'%B %d, %Y',
'%d %B %Y',
'%d %B, %Y')
ACCOUNT_LOGOUT_REDIRECT_URL
u'/'
HAYSTACK_SEARCH
False
AUTHENTICATION_BACKENDS
('django.contrib.auth.backends.ModelBackend',
'guardian.backends.ObjectPermissionBackend')
EMAIL_HOST_PASSWORD
CELERY_DISABLE_RATE_LIMITS
True
PASSWORD_RESET_TIMEOUT_DAYS
CACHE_MIDDLEWARE_ALIAS
'default'
SESSION_SAVE_EVERY_REQUEST
False
NUMBER_GROUPING
0
SHORT_DATETIME_FORMAT
'm/d/Y P'
SESSION_ENGINE
'django.contrib.sessions.backends.db'
CELERY_RESULT_BACKEND
None
ACCOUNT_DELETION_MARK_CALLBACK
CSRF_COOKIE_PATH
LOGIN_REDIRECT_URL
'/accounts/profile/'
SITEURL
'http://muchita.cnpm.embrapa.br/'
PROJECT_ROOT
'/usr/local/lib/python2.7/dist-packages/geonode'
ACCOUNT_DELETION_EXPUNGE_HOURS
48
GEONODE_ROOT
DECIMAL_SEPARATOR
CSRF_FAILURE_VIEW
'django.views.csrf.csrf_failure'
CELERY_SEND_EVENTS
False
NOSE_ARGS
['--nocapture', '--detailed-errors']
LOCALE_PATHS
('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
THEME_ACCOUNT_CONTACT_EMAIL
'admin at example.com'
PASSWORD_HASHERS
PROXY_ALLOWED_HOSTS
MESSAGE_STORAGE
'django.contrib.messages.storage.fallback.FallbackStorage'
USE_QUEUE
False
COMMENTS_ALLOW_PROFANITIES
False
LOGOUT_URL
'/account/logout/'
MAP_BASELAYERS
[{'source': {'ptype': 'gxp_wmscsource',
'restUrl': '/gs/rest',
'url': 'http://muchita.cnpm.embrapa.br/geoserver/wms'}},
{'args': ['No background'],
'fixed': True,
'group': 'background',
'source': {'ptype': 'gxp_olsource'},
'type': 'OpenLayers.Layer',
'visibility': False},
{'args': ['OpenStreetMap'],
'fixed': True,
'type': 'OpenLayers.Layer.OSM',
{'group': 'background',
'name': 'osm',
'source': {'ptype': 'gxp_mapquestsource'},
'visibility': True},
'name': 'naip',
{'fixed': True,
'name': 'AerialWithLabels',
'source': {'ptype': 'gxp_bingsource'},
{'source': {'ptype': 'gxp_mapboxsource'}}]
EMAIL_USE_TLS
False
ACCOUNT_LANGUAGES
[('en', u'English'),
('es', u'espa\xf1ol'),
('it', u'italiano'),
('fr', u'fran\xe7ais'),
('de', u'Deutsch'),
('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
('id', u'Bahasa Indonesia'),
('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
('ja', u'\u65e5\u672c\u8a9e'),
('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
('sq', u'shqip'),
('af', u'Afrikaans'),
('sw', u'Kiswahili'),
('pt', u'Portugu\xeas'),
('pt-br', u'Portugu\xeas Brasileiro'),
('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
('ko', u'\ud55c\uad6d\uc5b4'),
('am', 'Amharic'),
('km', u'Khmer'),
('pl', u'polski'),
('sv', u'svenska'),
('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
('si', 'sinhala'),
('ta', u'tamil'),
('tl', 'tagalog')]
FIXTURE_DIRS
ABSOLUTE_URL_OVERRIDES
DATE_FORMAT
'N j, Y'
OGC_SERVER
{'default': {'BACKEND': 'geonode.geoserver',
'BACKEND_WRITE_ENABLED': True,
'DATASTORE': 'datastore',
'GEOGIG_DATASTORE_DIR': '',
'GEONODE_SECURITY_ENABLED': True,
'LOCATION': 'http://localhost:8080/geoserver/',
'LOG_FILE': '/usr/share/geoserver/data/logs/geoserver.log',
'MAPFISH_PRINT_ENABLED': True,
'PRINT_NG_ENABLED': True,
'PUBLIC_LOCATION': 'http://muchita.cnpm.embrapa.br/geoserver/',
'USER': 'admin',
'WMST_ENABLED': False,
'WPS_ENABLED': True}}
SKIP_PERMS_FILTER
False
ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
MEDIA_ROOT
'/var/www/geonode/uploaded'
AGON_RATINGS_CATEGORY_CHOICES
{'documents.Document': {'document': 'How good is this document?'},
'layers.Layer': {'layer': 'How good is this layer?'},
'maps.Map': {'map': 'How good is this map?'}}
DATABASE_HOST
DEFAULT_EXCEPTION_REPORTER_FILTER
'django.views.debug.SafeExceptionReporterFilter'
ADMINS
FORMAT_MODULE_PATH
None
DEFAULT_FROM_EMAIL
GEONODE_APPS
('geonode.people',
'geonode.base',
'geonode.layers',
'geonode.maps',
'geonode.proxy',
'geonode.security',
'geonode.social',
'geonode.api',
'geonode.groups',
'geonode.services',
'geonode.upload',
'geonode.tasks')
GEOSERVER_URL
DATETIME_FORMAT
'N j, Y, P'
TEMPLATE_DIRS
('/etc/geonode/templates',
'/usr/local/lib/python2.7/dist-packages/geonode/templates')
ALLOWED_DOCUMENT_TYPES
['doc',
'docx',
'gif',
'jpg',
'jpeg',
'ods',
'odt',
'odp',
'pdf',
'png',
'ppt',
'pptx',
'rar',
'tif',
'tiff',
'txt',
'xls',
'xlsx',
'xml',
'zip',
'gz']
NOTIFICATION_LANGUAGE_MODULE
'account.Account'
ACCOUNT_DELETION_EXPUNGE_CALLBACK
RESOURCE_PUBLISHING
False
ACCOUNT_HOOKSET
<account.hooks.AccountDefaultHookSet object at 0x7fe06f67d210>
PROXY_URL
'/proxy/?url='
SITE_ID
1
DISALLOWED_USER_AGENTS
ALLOWED_INCLUDE_ROOTS
API_LIMIT_PER_PAGE
ACCOUNT_SETTINGS_REDIRECT_URL
u'account_settings'
EXTRA_LANG_INFO
{'am': {'bidi': False,
'code': 'am',
'name': 'Amharic',
'name_local': 'Amharic'},
'si': {'bidi': False,
'code': 'si',
'name': 'Sinhala',
'name_local': 'sinhala'},
'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
'tl': {'bidi': False,
'code': 'tl',
'name': 'Tagalog',
'name_local': 'tagalog'}}
LOGGING
{'disable_existing_loggers': True,
'filters': {'require_debug_false': {'()':
'django.utils.log.RequireDebugFalse'}},
'formatters': {'simple': {'format': '%(message)s'},
'verbose': {'format': '%(levelname)s %(asctime)s
%(module)s %(process)d %(thread)d %(message)s'}},
'handlers': {'console': {'class': 'logging.StreamHandler',
'formatter': 'simple',
'level': 'ERROR'},
'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
'filters': ['require_debug_false'],
'level': 'ERROR'},
'null': {'class': 'django.utils.log.NullHandler',
'level': 'ERROR'}},
'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
'geonode': {'handlers': ['console'], 'level': 'ERROR'},
'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
'owslib': {'handlers': ['console'], 'level': 'ERROR'},
'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
'version': 1}
SHORT_DATE_FORMAT
'm/d/Y'
DATABASE_USER
'geonode'
TEST_RUNNER
'django_nose.NoseTestSuiteRunner'
ACTSTREAM_SETTINGS
{'FETCH_RELATIONS': True,
'GFK_FETCH_DEPTH': 1,
'MODELS': ('people.Profile',
'layers.layer',
'maps.map',
'dialogos.comment',
'documents.document',
'services.service'),
'USE_JSONFIELD': True,
'USE_PREFETCH': False}
MODELTRANSLATION_LANGUAGES
['en']
HAYSTACK_FACET_COUNTS
False
CACHE_MIDDLEWARE_KEY_PREFIX
DEFAULT_WORKSPACE
'geonode'
TIME_ZONE
'America/Chicago'
FILE_UPLOAD_MAX_MEMORY_SIZE
2621440
LOCAL_GEOSERVER
EMAIL_BACKEND
'django.core.mail.backends.smtp.EmailBackend'
ANONYMOUS_USER_ID
-1
POSTGIS_VERSION
(2, 1, 0)
DEFAULT_MAP_ZOOM
0
TEMPLATE_CONTEXT_PROCESSORS
('django.contrib.auth.context_processors.auth',
'django.core.context_processors.debug',
'django.core.context_processors.i18n',
'django.core.context_processors.tz',
'django.core.context_processors.media',
'django.core.context_processors.static',
'django.core.context_processors.request',
'django.contrib.messages.context_processors.messages',
'account.context_processors.account',
'geonode.context_processors.resource_urls',
'geonode.geoserver.context_processors.geoserver_urls')
CELERY_QUEUES
[<unbound Queue 'default' -> <unbound Exchange ''(direct)> -> default>,
<unbound Queue 'cleanup' -> <unbound Exchange ''(direct)> -> cleanup>,
<unbound Queue 'update' -> <unbound Exchange ''(direct)> -> update>,
<unbound Queue 'email' -> <unbound Exchange ''(direct)> -> email>]
LOCKDOWN_GEONODE
False
SESSION_COOKIE_AGE
1209600
SETTINGS_MODULE
'geonode.settings'
GUARDIAN_GET_INIT_ANONYMOUS_USER
'geonode.people.models.get_anonymous_user_instance'
USE_ETAGS
False
SOCIAL_BUTTONS
True
LANGUAGES
(('en', 'English'),
('es', 'Espa\xc3\xb1ol'),
('it', 'Italiano'),
('fr', 'Fran\xc3\xa7ais'),
('de', 'Deutsch'),
('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
('id', 'Bahasa Indonesia'),
('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
('fa', 'Persian'),
('ar', 'Arabic'),
('bn', 'Bengali'),
('ne', 'Nepali'),
('sq', 'Albanian'),
('af', 'Afrikaans'),
('sw', 'Swahili'),
('pt', 'Portuguese'),
('pt-br', 'Portugu\xc3\xaas Brasil'),
('ru', 'Russian'),
('vi', 'Vietnamese'),
('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
('am', 'Amharic'),
('km', 'Khmer'),
('pl', 'Polish'),
('sv', 'Swedish'),
('th', 'Thai'),
('uk', 'Ukranian'),
('si', 'Sinhala'),
('ta', 'Tamil'),
('tl', 'Tagalog'))
CELERY_TASK_RESULT_EXPIRES
1
DEFAULT_INDEX_TABLESPACE
INTERNAL_IPS
STATIC_URL
'/static/'
EMAIL_PORT
25
LAYER_PREVIEW_LIBRARY
'geoext'
USE_TZ
False
DEFAULT_SEARCH_SIZE
10
CLIENT_RESULTS_LIMIT
100
MODELTRANSLATION_DEFAULT_LANGUAGE
'en'
ACCOUNT_SIGNUP_REDIRECT_URL
u'/'
DOCUMENT_TYPE_MAP
{'doc': 'text',
'docx': 'text',
'gif': 'image',
'gz': 'archive',
'jpeg': 'image',
'jpg': 'image',
'log': 'text',
'odp': 'presentation',
'ods': 'text',
'odt': 'text',
'pdf': 'presentation',
'png': 'image',
'ppt': 'presentation',
'pptx': 'presentation',
'rar': 'archive',
'tif': 'image',
'tiff': 'image',
'txt': 'text',
'xls': 'text',
'xlsx': 'text',
'xml': 'text',
'zip': 'archive'}
CACHE_MIDDLEWARE_SECONDS
600
SITENAME
'GeoNode'
ACCOUNT_CREATE_ON_SAVE
True
CSRF_COOKIE_HTTPONLY
False
DATETIME_INPUT_FORMATS
('%Y-%m-%d %H:%M:%S',
'%Y-%m-%d %H:%M:%S.%f',
'%Y-%m-%d %H:%M',
'%Y-%m-%d',
'%m/%d/%Y %H:%M:%S',
'%m/%d/%Y %H:%M:%S.%f',
'%m/%d/%Y %H:%M',
'%m/%d/%Y',
'%m/%d/%y %H:%M:%S',
'%m/%d/%y %H:%M:%S.%f',
'%m/%d/%y %H:%M',
'%m/%d/%y')
ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
False
DATABASE_PASSWORD
PROFANITIES_LIST
EMAIL_HOST_USER
MAX_DOCUMENT_SIZE
2
You're seeing this error because you have DEBUG = True in your Django
settings file. Change that to False, and Django will display a standard 500
page.
Davi de O. Custódio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150527/9d5d9cef/attachment-0001.html>
More information about the geonode-users
