[GeoNode-users] Problems to change Geonode database name
Simone Dalmasso simone.dalmasso at gmail.com
Wed May 27 05:55:17 PDT 2015
Davi, seems that your local_settings is not correctly processed. See in
your error that the db settings are still pointing to 'geonode'
2015-05-27 14:50 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
> Hello. I have problem in GeoNode 2.4 to rename the GeoNode database. I
> need to change the names of "GeoNode" and "geonode_data" because I am
> centralizing the databases of various GeoNode servers in the same instance
> of PostgreSQL.
> I changed the names in local_settings.py, and then restarted the apache,
> and I received an error to Django still trying to find a database with old
> name "GeoNode".
> Besides local_settings.py, there is another location that I should change
> the database name?
> Below the full log.
> Davi.
> OperationalError at /
> FATAL:  database "geonode" does not exist
> Request Method:GETRequest URL:http://muchita.cnpm.embrapa.br/Django
> Version:1.6.1Exception Type:OperationalErrorException Value:
> Exception Location:/usr/lib/python2.7/dist-packages/psycopg2/__init__.py
> in connect, line 179Python Executable:/usr/bin/pythonPython Version:2.7.6Python
> Path:
> ['/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PILcompat',
>  '/usr/lib/pymodules/python2.7',
>  '/var/www']
> Server time:Qua, 27 Mai 2015 07:36:18 -0500
> Traceback Switch to copy-and-paste view <http://muchita.cnpm.embrapa.br/#>
>    - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
>    get_response
>    1.
>                       response = response.render()
>    ▶ Local vars <http://muchita.cnpm.embrapa.br/#>
>    - /usr/lib/python2.7/dist-packages/django/template/response.py in
>    render
>    1.
>                   self.content = self.rendered_content
>    rendered_content
>    1.
>               context = self.resolve_context(self.context_data)
>    resolve_context
>    1.
>               return RequestContext(self._request, context, current_app=self._current_app)
>    - /usr/lib/python2.7/dist-packages/django/template/context.py in
>    __init__
>    1.
>                   self.update(processor(request))
>    - /usr/local/lib/python2.7/dist-packages/geonode/context_processors.py
>     in resource_urls
>    1.
>           site = Site.objects.get_current()
>    - /usr/lib/python2.7/dist-packages/django/contrib/sites/models.py in
>    get_current
>    1.
>                   current_site = self.get(pk=sid)
>    - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in get
>    1.
>               return self.get_queryset().get(*args, **kwargs)
>    - /usr/lib/python2.7/dist-packages/django/db/models/query.py in get
>    1.
>               num = len(clone)
>    - /usr/lib/python2.7/dist-packages/django/db/models/query.py in __len__
>    1.
>               self._fetch_all()
>    _fetch_all
>    1.
>                   self._result_cache = list(self.iterator())
>    iterator
>    1.
>               for row in compiler.results_iter():
>    - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py in
>    results_iter
>    1.
>               for rows in self.execute_sql(MULTI):
>    execute_sql
>    1.
>               cursor = self.connection.cursor()
>    - /usr/lib/python2.7/dist-packages/django/db/backends/__init__.py in
>    cursor
>    1.
>                   cursor = self.make_debug_cursor(self._cursor())
>    _cursor
>    1.
>               self.ensure_connection()
>    ensure_connection
>    1.
>                       self.connect()
>    - /usr/lib/python2.7/dist-packages/django/db/utils.py in __exit__
>    1.
>                       six.reraise(dj_exc_type, dj_exc_value, traceback)
>    ensure_connection
>    1.
>                       self.connect()
>    connect
>    1.
>               self.connection = self.get_new_connection(conn_params)
>    /usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>     in get_new_connection
>    1.
>               return Database.connect(**conn_params)
>    - /usr/lib/python2.7/dist-packages/psycopg2/__init__.py in connect
>    1.
>               connection_factory=connection_factory, async=async)
> Request informationGET
> No GET data
> POST
> No POST data
> FILES
> No FILES data
> COOKIESVariableValue__utmz
> '128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)'
> ys-user
> 'o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
> _ga
> 'GA1.2.1150756117.1398259583'
> __gads
> 'ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ'
> csrftoken
> 'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
> s_getNewRepeat
> '1423508214723-Repeat'
> ys-alreadyShowMessage
> 'b%3A1'
> __utma
> '128008848.1150756117.1398259583.1432729377.1432729377.1'
> __utmb
> '128008848.1.10.1432729377'
> __utmc
> '128008848'
> s_fid
> '691159BDD05014BE-21BD7FC62185D9C7'
> METAVariableValuemod_wsgi.listener_port
> '80'
> HTTP_COOKIE
> '__gads=ID=d961b8788d34039d:T=1413485184:S=ALNI_MaiaRd8gEEukW6akCBPz27sqFOcgQ; __utmz=237664978.1423046483.18.3.utmccn=(referral)|utmcsr=google.com.br|utmcct=/|utmcmd=referral; __utma=237664978.1207420118.1398169929.1423046483.1423244128.19; s_fid=691159BDD05014BE-21BD7FC62185D9C7; s_getNewRepeat=1423508214723-Repeat; __utma=218996109.1150756117.1398259583.1432299746.1432304989.52; __utmz=218996109.1432304989.52.23.utmcsr=chorao.cnpm.embrapa.br:9081|utmccn=(referral)|utmcmd=referral|utmcct=/; _ga=GA1.2.1150756117.1398259583; csrftoken=GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb; __utma=128008848.1150756117.1398259583.1432729377.1432729377.1; __utmb=128008848.1.10.1432729377; __utmc=128008848; __utmz=128008848.1432729377.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none); ys-alreadyShowMessage=b%3A1; ys-user=o%3Ausername%3Ds%253Aadmin%5Ename%3Ds%253Aadmin%5Esurname%3Ds%253Aadmin%5Erole%3Ds%253AAdministrator'
> mod_wsgi.listener_host
> CONTEXT_DOCUMENT_ROOT
> '/var/www'
> SERVER_SOFTWARE
> 'Apache/2.4.7 (Ubuntu)'
> SCRIPT_NAME
> u''
> mod_wsgi.enable_sendfile
> '0'
> mod_wsgi.handler_script
> SERVER_SIGNATURE
> '<address>Apache/2.4.7 (Ubuntu) Server at muchita.cnpm.embrapa.br Port 80</address>\n'
> REQUEST_METHOD
> 'GET'
> PATH_INFO
> u'/'
> SERVER_PROTOCOL
> 'HTTP/1.1'
> QUERY_STRING
> HTTP_USER_AGENT
> 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/43.0.2357.65 Safari/537.36'
> HTTP_CONNECTION
> 'keep-alive'
> SERVER_NAME
> 'muchita.cnpm.embrapa.br'
> REMOTE_ADDR
> '10.157.20.55'
> mod_wsgi.queue_start
> '1432730176843671'
> mod_wsgi.request_handler
> 'wsgi-script'
> wsgi.url_scheme
> 'http'
> PATH_TRANSLATED
> '/var/www/geonode/wsgi/geonode.wsgi/'
> SERVER_PORT
> '80'
> wsgi.multiprocess
> True
> mod_wsgi.input_chunked
> '0'
> SERVER_ADDR
> '192.168.10.10'
> DOCUMENT_ROOT
> '/var/www'
> mod_wsgi.process_group
> 'geonode'
> HTTP_PRAGMA
> 'no-cache'
> SCRIPT_FILENAME
> '/var/www/geonode/wsgi/geonode.wsgi'
> SERVER_ADMIN
> 'webmaster at localhost'
> wsgi.input
> <mod_wsgi.Input object at 0x7fe089acf530>
> HTTP_HOST
> CONTEXT_PREFIX
> wsgi.multithread
> True
> mod_wsgi.callable_object
> 'application'
> HTTP_CACHE_CONTROL
> 'no-cache'
> REQUEST_URI
> HTTP_ACCEPT
> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
> wsgi.version
> (1, 0)
> GATEWAY_INTERFACE
> 'CGI/1.1'
> wsgi.run_once
> False
> wsgi.errors
> <mod_wsgi.Log object at 0x7fe0899a1f70>
> REMOTE_PORT
> '51799'
> HTTP_ACCEPT_LANGUAGE
> 'pt-PT,pt;q=0.8,pt-BR;q=0.6,en-US;q=0.4,en;q=0.2'
> REQUEST_SCHEME
> 'http'
> mod_wsgi.version
> (3, 4)
> mod_wsgi.application_group
> 'aguai.cnpm.embrapa.br|'
> mod_wsgi.script_reloading
> '1'
> wsgi.file_wrapper
> CSRF_COOKIE
> u'GsCa0yBBEsMMf6hw6knF1r4qHcfafmXb'
> HTTP_ACCEPT_ENCODING
> 'gzip, deflate, sdch'
> SettingsUsing settings module geonode.settingsSettingValue
> CASCADE_WORKSPACE
> 'geonode'
> ACCOUNT_USER_DISPLAY
> DATABASES
> {'datastore': {'ATOMIC_REQUESTS': False,
>                'AUTOCOMMIT': True,
>                'CONN_MAX_AGE': 0,
>                'ENGINE': 'django.contrib.gis.db.backends.postgis',
>                'HOST': 'jatoba.cnpm.embrapa.br',
>                'NAME': 'geonode_data',
>                'OPTIONS': {},
>                'PASSWORD': u'********************',
>                'PORT': '5432',
>                'TEST_CHARSET': None,
>                'TEST_COLLATION': None,
>                'TEST_MIRROR': None,
>                'TEST_NAME': None,
>                'TIME_ZONE': 'America/Chicago',
>                'USER': 'geonode'},
>  'default': {'ATOMIC_REQUESTS': False,
>              'AUTOCOMMIT': True,
>              'CONN_MAX_AGE': 0,
>              'ENGINE': 'django.db.backends.postgresql_psycopg2',
>              'NAME': 'geonode',
>              'OPTIONS': {},
>              'PORT': '5432',
>              'TEST_NAME': None,
>              'USER': 'geonode'}}
> GOOGLE_API_KEY
> CELERY_CREATE_MISSING_QUEUES
> True
> CSRF_COOKIE_SECURE
> False
> CELERY_DEFAULT_QUEUE
> 'default'
> UPLOADER
> {'BACKEND': 'geonode.rest',
>  'OPTIONS': {'GEOGIG_ENABLED': False, 'TIME_ENABLED': False}}
> LANGUAGE_CODE
> 'pt-br'
> LICENSES
> {'DETAIL': 'above', 'ENABLED': True, 'METADATA': 'verbose'}
> MANAGERS
> DOWNLOAD_FORMATS_METADATA
> ['Atom', 'DIF', 'Dublin Core', 'ebRIM', 'FGDC', 'ISO']
> BROKER_URL
> 'django://'
> DEFAULT_CHARSET
> 'utf-8'
> IGNORABLE_404_URLS
> CELERY_DEFAULT_EXCHANGE_TYPE
> 'direct'
> SESSION_SERIALIZER
> 'django.contrib.sessions.serializers.PickleSerializer'
> DEFAULT_MAP_CENTER
> (0, 0)
> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
> 3
> USE_THOUSAND_SEPARATOR
> False
> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
> None
> ACCOUNT_INVITE_USER_URL
> u'account_invite_user'
> REGISTRATION_OPEN
> False
> ALLOWED_HOSTS
> ['muchita.cnpm.embrapa.br', 'localhost']
> EMAIL_HOST
> 'localhost'
> DOWNLOAD_FORMATS_RASTER
> ['JPEG',
>  'PDF',
>  'PNG',
>  'ArcGrid',
>  'GeoTIFF',
>  'Gtopo30',
>  'ImageMosaic',
>  'KML',
>  'View in Google Earth',
>  'Tiles']
> AUTH_EXEMPT_URLS
> WSGI_APPLICATION
> None
> EMAIL_SUBJECT_PREFIX
> '[Django] '
> SEND_BROKEN_LINK_EMAILS
> False
> TEMPLATE_STRING_IF_INVALID
> STATICFILES_FINDERS
> ('django.contrib.staticfiles.finders.FileSystemFinder',
>  'django.contrib.staticfiles.finders.AppDirectoriesFinder')
> NOTIFICATION_QUEUE_ALL
> False
> SESSION_CACHE_ALIAS
> 'default'
> CELERY_IMPORTS
> ('geonode.tasks.deletion', 'geonode.tasks.update', 'geonode.tasks.email')
> SESSION_COOKIE_DOMAIN
> None
> SESSION_COOKIE_NAME
> 'sessionid'
> ADMIN_FOR
> TIME_INPUT_FORMATS
> ('%H:%M:%S', '%H:%M:%S.%f', '%H:%M')
> ACCOUNT_USE_AUTH_AUTHENTICATE
> False
> X_FRAME_OPTIONS
> 'SAMEORIGIN'
> FILE_UPLOAD_PERMISSIONS
> None
> ACCOUNT_TIMEZONES
> [('Africa/Abidjan', 'Africa/Abidjan'),
>  ('Africa/Accra', 'Africa/Accra'),
>  ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
>  ('Africa/Algiers', 'Africa/Algiers'),
>  ('Africa/Asmara', 'Africa/Asmara'),
>  ('Africa/Asmera', 'Africa/Asmera'),
>  ('Africa/Bamako', 'Africa/Bamako'),
>  ('Africa/Bangui', 'Africa/Bangui'),
>  ('Africa/Banjul', 'Africa/Banjul'),
>  ('Africa/Bissau', 'Africa/Bissau'),
>  ('Africa/Blantyre', 'Africa/Blantyre'),
>  ('Africa/Brazzaville', 'Africa/Brazzaville'),
>  ('Africa/Bujumbura', 'Africa/Bujumbura'),
>  ('Africa/Cairo', 'Africa/Cairo'),
>  ('Africa/Casablanca', 'Africa/Casablanca'),
>  ('Africa/Ceuta', 'Africa/Ceuta'),
>  ('Africa/Conakry', 'Africa/Conakry'),
>  ('Africa/Dakar', 'Africa/Dakar'),
>  ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
>  ('Africa/Djibouti', 'Africa/Djibouti'),
>  ('Africa/Douala', 'Africa/Douala'),
>  ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
>  ('Africa/Freetown', 'Africa/Freetown'),
>  ('Africa/Gaborone', 'Africa/Gaborone'),
>  ('Africa/Harare', 'Africa/Harare'),
>  ('Africa/Johannesburg', 'Africa/Johannesburg'),
>  ('Africa/Juba', 'Africa/Juba'),
>  ('Africa/Kampala', 'Africa/Kampala'),
>  ('Africa/Khartoum', 'Africa/Khartoum'),
>  ('Africa/Kigali', 'Africa/Kigali'),
>  ('Africa/Kinshasa', 'Africa/Kinshasa'),
>  ('Africa/Lagos', 'Africa/Lagos'),
>  ('Africa/Libreville', 'Africa/Libreville'),
>  ('Africa/Lome', 'Africa/Lome'),
>  ('Africa/Luanda', 'Africa/Luanda'),
>  ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
>  ('Africa/Lusaka', 'Africa/Lusaka'),
>  ('Africa/Malabo', 'Africa/Malabo'),
>  ('Africa/Maputo', 'Africa/Maputo'),
>  ('Africa/Maseru', 'Africa/Maseru'),
>  ('Africa/Mbabane', 'Africa/Mbabane'),
>  ('Africa/Mogadishu', 'Africa/Mogadishu'),
>  ('Africa/Monrovia', 'Africa/Monrovia'),
>  ('Africa/Nairobi', 'Africa/Nairobi'),
>  ('Africa/Ndjamena', 'Africa/Ndjamena'),
>  ('Africa/Niamey', 'Africa/Niamey'),
>  ('Africa/Nouakchott', 'Africa/Nouakchott'),
>  ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
>  ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
>  ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
>  ('Africa/Timbuktu', 'Africa/Timbuktu'),
>  ('Africa/Tripoli', 'Africa/Tripoli'),
>  ('Africa/Tunis', 'Africa/Tunis'),
>  ('Africa/Windhoek', 'Africa/Windhoek'),
>  ('America/Adak', 'America/Adak'),
>  ('America/Anchorage', 'America/Anchorage'),
>  ('America/Anguilla', 'America/Anguilla'),
>  ('America/Antigua', 'America/Antigua'),
>  ('America/Araguaina', 'America/Araguaina'),
>  ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
>  ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
>  ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
>  ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
>  ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
>  ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
>  ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
>  ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
>  ('America/Argentina/Salta', 'America/Argentina/Salta'),
>  ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
>  ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
>  ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
>  ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
>  ('America/Aruba', 'America/Aruba'),
>  ('America/Asuncion', 'America/Asuncion'),
>  ('America/Atikokan', 'America/Atikokan'),
>  ('America/Atka', 'America/Atka'),
>  ('America/Bahia', 'America/Bahia'),
>  ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
>  ('America/Barbados', 'America/Barbados'),
>  ('America/Belem', 'America/Belem'),
>  ('America/Belize', 'America/Belize'),
>  ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
>  ('America/Boa_Vista', 'America/Boa_Vista'),
>  ('America/Bogota', 'America/Bogota'),
>  ('America/Boise', 'America/Boise'),
>  ('America/Buenos_Aires', 'America/Buenos_Aires'),
>  ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
>  ('America/Campo_Grande', 'America/Campo_Grande'),
>  ('America/Cancun', 'America/Cancun'),
>  ('America/Caracas', 'America/Caracas'),
>  ('America/Catamarca', 'America/Catamarca'),
>  ('America/Cayenne', 'America/Cayenne'),
>  ('America/Cayman', 'America/Cayman'),
>  ('America/Chicago', 'America/Chicago'),
>  ('America/Chihuahua', 'America/Chihuahua'),
>  ('America/Coral_Harbour', 'America/Coral_Harbour'),
>  ('America/Cordoba', 'America/Cordoba'),
>  ('America/Costa_Rica', 'America/Costa_Rica'),
>  ('America/Creston', 'America/Creston'),
>  ('America/Cuiaba', 'America/Cuiaba'),
>  ('America/Curacao', 'America/Curacao'),
>  ('America/Danmarkshavn', 'America/Danmarkshavn'),
>  ('America/Dawson', 'America/Dawson'),
>  ('America/Dawson_Creek', 'America/Dawson_Creek'),
>  ('America/Denver', 'America/Denver'),
>  ('America/Detroit', 'America/Detroit'),
>  ('America/Dominica', 'America/Dominica'),
>  ('America/Edmonton', 'America/Edmonton'),
>  ('America/Eirunepe', 'America/Eirunepe'),
>  ('America/El_Salvador', 'America/El_Salvador'),
>  ('America/Ensenada', 'America/Ensenada'),
>  ('America/Fort_Wayne', 'America/Fort_Wayne'),
>  ('America/Fortaleza', 'America/Fortaleza'),
>  ('America/Glace_Bay', 'America/Glace_Bay'),
>  ('America/Godthab', 'America/Godthab'),
>  ('America/Goose_Bay', 'America/Goose_Bay'),
>  ('America/Grand_Turk', 'America/Grand_Turk'),
>  ('America/Grenada', 'America/Grenada'),
>  ('America/Guadeloupe', 'America/Guadeloupe'),
>  ('America/Guatemala', 'America/Guatemala'),
>  ('America/Guayaquil', 'America/Guayaquil'),
>  ('America/Guyana', 'America/Guyana'),
>  ('America/Halifax', 'America/Halifax'),
>  ('America/Havana', 'America/Havana'),
>  ('America/Hermosillo', 'America/Hermosillo'),
>  ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
>  ('America/Indiana/Knox', 'America/Indiana/Knox'),
>  ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
>  ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
>  ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
>  ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
>  ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
>  ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
>  ('America/Indianapolis', 'America/Indianapolis'),
>  ('America/Inuvik', 'America/Inuvik'),
>  ('America/Iqaluit', 'America/Iqaluit'),
>  ('America/Jamaica', 'America/Jamaica'),
>  ('America/Jujuy', 'America/Jujuy'),
>  ('America/Juneau', 'America/Juneau'),
>  ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
>  ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
>  ('America/Knox_IN', 'America/Knox_IN'),
>  ('America/Kralendijk', 'America/Kralendijk'),
>  ('America/La_Paz', 'America/La_Paz'),
>  ('America/Lima', 'America/Lima'),
>  ('America/Los_Angeles', 'America/Los_Angeles'),
>  ('America/Louisville', 'America/Louisville'),
>  ('America/Lower_Princes', 'America/Lower_Princes'),
>  ('America/Maceio', 'America/Maceio'),
>  ('America/Managua', 'America/Managua'),
>  ('America/Manaus', 'America/Manaus'),
>  ('America/Marigot', 'America/Marigot'),
>  ('America/Martinique', 'America/Martinique'),
>  ('America/Matamoros', 'America/Matamoros'),
>  ('America/Mazatlan', 'America/Mazatlan'),
>  ('America/Mendoza', 'America/Mendoza'),
>  ('America/Menominee', 'America/Menominee'),
>  ('America/Merida', 'America/Merida'),
>  ('America/Metlakatla', 'America/Metlakatla'),
>  ('America/Mexico_City', 'America/Mexico_City'),
>  ('America/Miquelon', 'America/Miquelon'),
>  ('America/Moncton', 'America/Moncton'),
>  ('America/Monterrey', 'America/Monterrey'),
>  ('America/Montevideo', 'America/Montevideo'),
>  ('America/Montreal', 'America/Montreal'),
>  ('America/Montserrat', 'America/Montserrat'),
>  ('America/Nassau', 'America/Nassau'),
>  ('America/New_York', 'America/New_York'),
>  ('America/Nipigon', 'America/Nipigon'),
>  ('America/Nome', 'America/Nome'),
>  ('America/Noronha', 'America/Noronha'),
>  ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
>  ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
>  ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
>  ('America/Ojinaga', 'America/Ojinaga'),
>  ('America/Panama', 'America/Panama'),
>  ('America/Pangnirtung', 'America/Pangnirtung'),
>  ('America/Paramaribo', 'America/Paramaribo'),
>  ('America/Phoenix', 'America/Phoenix'),
>  ('America/Port-au-Prince', 'America/Port-au-Prince'),
>  ('America/Port_of_Spain', 'America/Port_of_Spain'),
>  ('America/Porto_Acre', 'America/Porto_Acre'),
>  ('America/Porto_Velho', 'America/Porto_Velho'),
>  ('America/Puerto_Rico', 'America/Puerto_Rico'),
>  ('America/Rainy_River', 'America/Rainy_River'),
>  ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
>  ('America/Recife', 'America/Recife'),
>  ('America/Regina', 'America/Regina'),
>  ('America/Resolute', 'America/Resolute'),
>  ('America/Rio_Branco', 'America/Rio_Branco'),
>  ('America/Rosario', 'America/Rosario'),
>  ('America/Santa_Isabel', 'America/Santa_Isabel'),
>  ('America/Santarem', 'America/Santarem'),
>  ('America/Santiago', 'America/Santiago'),
>  ('America/Santo_Domingo', 'America/Santo_Domingo'),
>  ('America/Sao_Paulo', 'America/Sao_Paulo'),
>  ('America/Scoresbysund', 'America/Scoresbysund'),
>  ('America/Shiprock', 'America/Shiprock'),
>  ('America/Sitka', 'America/Sitka'),
>  ('America/St_Barthelemy', 'America/St_Barthelemy'),
>  ('America/St_Johns', 'America/St_Johns'),
>  ('America/St_Kitts', 'America/St_Kitts'),
>  ('America/St_Lucia', 'America/St_Lucia'),
>  ('America/St_Thomas', 'America/St_Thomas'),
>  ('America/St_Vincent', 'America/St_Vincent'),
>  ('America/Swift_Current', 'America/Swift_Current'),
>  ('America/Tegucigalpa', 'America/Tegucigalpa'),
>  ('America/Thule', 'America/Thule'),
>  ('America/Thunder_Bay', 'America/Thunder_Bay'),
>  ('America/Tijuana', 'America/Tijuana'),
>  ('America/Toronto', 'America/Toronto'),
>  ('America/Tortola', 'America/Tortola'),
>  ('America/Vancouver', 'America/Vancouver'),
>  ('America/Virgin', 'America/Virgin'),
>  ('America/Whitehorse', 'America/Whitehorse'),
>  ('America/Winnipeg', 'America/Winnipeg'),
>  ('America/Yakutat', 'America/Yakutat'),
>  ('America/Yellowknife', 'America/Yellowknife'),
>  ('Antarctica/Casey', 'Antarctica/Casey'),
>  ('Antarctica/Davis', 'Antarctica/Davis'),
>  ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
>  ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
>  ('Antarctica/Mawson', 'Antarctica/Mawson'),
>  ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
>  ('Antarctica/Palmer', 'Antarctica/Palmer'),
>  ('Antarctica/Rothera', 'Antarctica/Rothera'),
>  ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
>  ('Antarctica/Syowa', 'Antarctica/Syowa'),
>  ('Antarctica/Vostok', 'Antarctica/Vostok'),
>  ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
>  ('Asia/Aden', 'Asia/Aden'),
>  ('Asia/Almaty', 'Asia/Almaty'),
>  ('Asia/Amman', 'Asia/Amman'),
>  ('Asia/Anadyr', 'Asia/Anadyr'),
>  ('Asia/Aqtau', 'Asia/Aqtau'),
>  ('Asia/Aqtobe', 'Asia/Aqtobe'),
>  ('Asia/Ashgabat', 'Asia/Ashgabat'),
>  ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
>  ('Asia/Baghdad', 'Asia/Baghdad'),
>  ('Asia/Bahrain', 'Asia/Bahrain'),
>  ('Asia/Baku', 'Asia/Baku'),
>  ('Asia/Bangkok', 'Asia/Bangkok'),
>  ('Asia/Beirut', 'Asia/Beirut'),
>  ('Asia/Bishkek', 'Asia/Bishkek'),
>  ('Asia/Brunei', 'Asia/Brunei'),
>  ('Asia/Calcutta', 'Asia/Calcutta'),
>  ('Asia/Choibalsan', 'Asia/Choibalsan'),
>  ('Asia/Chongqing', 'Asia/Chongqing'),
>  ('Asia/Chungking', 'Asia/Chungking'),
>  ('Asia/Colombo', 'Asia/Colombo'),
>  ('Asia/Dacca', 'Asia/Dacca'),
>  ('Asia/Damascus', 'Asia/Damascus'),
>  ('Asia/Dhaka', 'Asia/Dhaka'),
>  ('Asia/Dili', 'Asia/Dili'),
>  ('Asia/Dubai', 'Asia/Dubai'),
>  ('Asia/Dushanbe', 'Asia/Dushanbe'),
>  ('Asia/Gaza', 'Asia/Gaza'),
>  ('Asia/Harbin', 'Asia/Harbin'),
>  ('Asia/Hebron', 'Asia/Hebron'),
>  ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
>  ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
>  ('Asia/Hovd', 'Asia/Hovd'),
>  ('Asia/Irkutsk', 'Asia/Irkutsk'),
>  ('Asia/Istanbul', 'Asia/Istanbul'),
>  ('Asia/Jakarta', 'Asia/Jakarta'),
>  ('Asia/Jayapura', 'Asia/Jayapura'),
>  ('Asia/Jerusalem', 'Asia/Jerusalem'),
>  ('Asia/Kabul', 'Asia/Kabul'),
>  ('Asia/Kamchatka', 'Asia/Kamchatka'),
>  ('Asia/Karachi', 'Asia/Karachi'),
>  ('Asia/Kashgar', 'Asia/Kashgar'),
>  ('Asia/Kathmandu', 'Asia/Kathmandu'),
>  ('Asia/Katmandu', 'Asia/Katmandu'),
>  ('Asia/Kolkata', 'Asia/Kolkata'),
>  ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
>  ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
>  ('Asia/Kuching', 'Asia/Kuching'),
>  ('Asia/Kuwait', 'Asia/Kuwait'),
>  ('Asia/Macao', 'Asia/Macao'),
>  ('Asia/Macau', 'Asia/Macau'),
>  ('Asia/Magadan', 'Asia/Magadan'),
>  ('Asia/Makassar', 'Asia/Makassar'),
>  ('Asia/Manila', 'Asia/Manila'),
>  ('Asia/Muscat', 'Asia/Muscat'),
>  ('Asia/Nicosia', 'Asia/Nicosia'),
>  ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
>  ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
>  ('Asia/Omsk', 'Asia/Omsk'),
>  ('Asia/Oral', 'Asia/Oral'),
>  ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
>  ('Asia/Pontianak', 'Asia/Pontianak'),
>  ('Asia/Pyongyang', 'Asia/Pyongyang'),
>  ('Asia/Qatar', 'Asia/Qatar'),
>  ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
>  ('Asia/Rangoon', 'Asia/Rangoon'),
>  ('Asia/Riyadh', 'Asia/Riyadh'),
>  ('Asia/Saigon', 'Asia/Saigon'),
>  ('Asia/Sakhalin', 'Asia/Sakhalin'),
>  ('Asia/Samarkand', 'Asia/Samarkand'),
>  ('Asia/Seoul', 'Asia/Seoul'),
>  ('Asia/Shanghai', 'Asia/Shanghai'),
>  ('Asia/Singapore', 'Asia/Singapore'),
>  ('Asia/Taipei', 'Asia/Taipei'),
>  ('Asia/Tashkent', 'Asia/Tashkent'),
>  ('Asia/Tbilisi', 'Asia/Tbilisi'),
>  ('Asia/Tehran', 'Asia/Tehran'),
>  ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
>  ('Asia/Thimbu', 'Asia/Thimbu'),
>  ('Asia/Thimphu', 'Asia/Thimphu'),
>  ('Asia/Tokyo', 'Asia/Tokyo'),
>  ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
>  ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
>  ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
>  ('Asia/Urumqi', 'Asia/Urumqi'),
>  ('Asia/Vientiane', 'Asia/Vientiane'),
>  ('Asia/Vladivostok', 'Asia/Vladivostok'),
>  ('Asia/Yakutsk', 'Asia/Yakutsk'),
>  ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
>  ('Asia/Yerevan', 'Asia/Yerevan'),
>  ('Atlantic/Azores', 'Atlantic/Azores'),
>  ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
>  ('Atlantic/Canary', 'Atlantic/Canary'),
>  ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
>  ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
>  ('Atlantic/Faroe', 'Atlantic/Faroe'),
>  ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
>  ('Atlantic/Madeira', 'Atlantic/Madeira'),
>  ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
>  ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
>  ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
>  ('Atlantic/Stanley', 'Atlantic/Stanley'),
>  ('Australia/ACT', 'Australia/ACT'),
>  ('Australia/Adelaide', 'Australia/Adelaide'),
>  ('Australia/Brisbane', 'Australia/Brisbane'),
>  ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
>  ('Australia/Canberra', 'Australia/Canberra'),
>  ('Australia/Currie', 'Australia/Currie'),
>  ('Australia/Darwin', 'Australia/Darwin'),
>  ('Australia/Eucla', 'Australia/Eucla'),
>  ('Australia/Hobart', 'Australia/Hobart'),
>  ('Australia/LHI', 'Australia/LHI'),
>  ('Australia/Lindeman', 'Australia/Lindeman'),
>  ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
>  ('Australia/Melbourne', 'Australia/Melbourne'),
>  ('Australia/NSW', 'Australia/NSW'),
>  ('Australia/North', 'Australia/North'),
>  ('Australia/Perth', 'Australia/Perth'),
>  ('Australia/Queensland', 'Australia/Queensland'),
>  ('Australia/South', 'Australia/South'),
>  ('Australia/Sydney', 'Australia/Sydney'),
>  ('Australia/Tasmania', 'Australia/Tasmania'),
>  ('Australia/Victoria', 'Australia/Victoria'),
>  ('Australia/West', 'Australia/West'),
>  ('Australia/Yancowinna', 'Australia/Yancowinna'),
>  ('Brazil/Acre', 'Brazil/Acre'),
>  ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
>  ('Brazil/East', 'Brazil/East'),
>  ('Brazil/West', 'Brazil/West'),
>  ('CET', 'CET'),
>  ('CST6CDT', 'CST6CDT'),
>  ('Canada/Atlantic', 'Canada/Atlantic'),
>  ('Canada/Central', 'Canada/Central'),
>  ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
>  ('Canada/Eastern', 'Canada/Eastern'),
>  ('Canada/Mountain', 'Canada/Mountain'),
>  ('Canada/Newfoundland', 'Canada/Newfoundland'),
>  ('Canada/Pacific', 'Canada/Pacific'),
>  ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
>  ('Canada/Yukon', 'Canada/Yukon'),
>  ('Chile/Continental', 'Chile/Continental'),
>  ('Chile/EasterIsland', 'Chile/EasterIsland'),
>  ('Cuba', 'Cuba'),
>  ('EET', 'EET'),
>  ('EST', 'EST'),
>  ('EST5EDT', 'EST5EDT'),
>  ('Egypt', 'Egypt'),
>  ('Eire', 'Eire'),
>  ('Etc/GMT', 'Etc/GMT'),
>  ('Etc/GMT+0', 'Etc/GMT+0'),
>  ('Etc/GMT+1', 'Etc/GMT+1'),
>  ('Etc/GMT+10', 'Etc/GMT+10'),
>  ('Etc/GMT+11', 'Etc/GMT+11'),
>  ('Etc/GMT+12', 'Etc/GMT+12'),
>  ('Etc/GMT+2', 'Etc/GMT+2'),
>  ('Etc/GMT+3', 'Etc/GMT+3'),
>  ('Etc/GMT+4', 'Etc/GMT+4'),
>  ('Etc/GMT+5', 'Etc/GMT+5'),
>  ('Etc/GMT+6', 'Etc/GMT+6'),
>  ('Etc/GMT+7', 'Etc/GMT+7'),
>  ('Etc/GMT+8', 'Etc/GMT+8'),
>  ('Etc/GMT+9', 'Etc/GMT+9'),
>  ('Etc/GMT-0', 'Etc/GMT-0'),
>  ('Etc/GMT-1', 'Etc/GMT-1'),
>  ('Etc/GMT-10', 'Etc/GMT-10'),
>  ('Etc/GMT-11', 'Etc/GMT-11'),
>  ('Etc/GMT-12', 'Etc/GMT-12'),
>  ('Etc/GMT-13', 'Etc/GMT-13'),
>  ('Etc/GMT-14', 'Etc/GMT-14'),
>  ('Etc/GMT-2', 'Etc/GMT-2'),
>  ('Etc/GMT-3', 'Etc/GMT-3'),
>  ('Etc/GMT-4', 'Etc/GMT-4'),
>  ('Etc/GMT-5', 'Etc/GMT-5'),
>  ('Etc/GMT-6', 'Etc/GMT-6'),
>  ('Etc/GMT-7', 'Etc/GMT-7'),
>  ('Etc/GMT-8', 'Etc/GMT-8'),
>  ('Etc/GMT-9', 'Etc/GMT-9'),
>  ('Etc/GMT0', 'Etc/GMT0'),
>  ('Etc/Greenwich', 'Etc/Greenwich'),
>  ('Etc/UCT', 'Etc/UCT'),
>  ('Etc/UTC', 'Etc/UTC'),
>  ('Etc/Universal', 'Etc/Universal'),
>  ('Etc/Zulu', 'Etc/Zulu'),
>  ('Europe/Amsterdam', 'Europe/Amsterdam'),
>  ('Europe/Andorra', 'Europe/Andorra'),
>  ('Europe/Athens', 'Europe/Athens'),
>  ('Europe/Belfast', 'Europe/Belfast'),
>  ('Europe/Belgrade', 'Europe/Belgrade'),
>  ('Europe/Berlin', 'Europe/Berlin'),
>  ('Europe/Bratislava', 'Europe/Bratislava'),
>  ('Europe/Brussels', 'Europe/Brussels'),
>  ('Europe/Bucharest', 'Europe/Bucharest'),
>  ('Europe/Budapest', 'Europe/Budapest'),
>  ('Europe/Chisinau', 'Europe/Chisinau'),
>  ('Europe/Copenhagen', 'Europe/Copenhagen'),
>  ('Europe/Dublin', 'Europe/Dublin'),
>  ('Europe/Gibraltar', 'Europe/Gibraltar'),
>  ('Europe/Guernsey', 'Europe/Guernsey'),
>  ('Europe/Helsinki', 'Europe/Helsinki'),
>  ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
>  ('Europe/Istanbul', 'Europe/Istanbul'),
>  ('Europe/Jersey', 'Europe/Jersey'),
>  ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
>  ('Europe/Kiev', 'Europe/Kiev'),
>  ('Europe/Lisbon', 'Europe/Lisbon'),
>  ('Europe/Ljubljana', 'Europe/Ljubljana'),
>  ('Europe/London', 'Europe/London'),
>  ('Europe/Luxembourg', 'Europe/Luxembourg'),
>  ('Europe/Madrid', 'Europe/Madrid'),
>  ('Europe/Malta', 'Europe/Malta'),
>  ('Europe/Mariehamn', 'Europe/Mariehamn'),
>  ('Europe/Minsk', 'Europe/Minsk'),
>  ('Europe/Monaco', 'Europe/Monaco'),
>  ('Europe/Moscow', 'Europe/Moscow'),
>  ('Europe/Nicosia', 'Europe/Nicosia'),
>  ('Europe/Oslo', 'Europe/Oslo'),
>  ('Europe/Paris', 'Europe/Paris'),
>  ('Europe/Podgorica', 'Europe/Podgorica'),
>  ('Europe/Prague', 'Europe/Prague'),
>  ('Europe/Riga', 'Europe/Riga'),
>  ('Europe/Rome', 'Europe/Rome'),
>  ('Europe/Samara', 'Europe/Samara'),
>  ('Europe/San_Marino', 'Europe/San_Marino'),
>  ('Europe/Sarajevo', 'Europe/Sarajevo'),
>  ('Europe/Simferopol', 'Europe/Simferopol'),
>  ('Europe/Skopje', 'Europe/Skopje'),
>  ('Europe/Sofia', 'Europe/Sofia'),
>  ('Europe/Stockholm', 'Europe/Stockholm'),
>  ('Europe/Tallinn', 'Europe/Tallinn'),
>  ('Europe/Tirane', 'Europe/Tirane'),
>  ('Europe/Tiraspol', 'Europe/Tiraspol'),
>  ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
>  ('Europe/Vaduz', 'Europe/Vaduz'),
>  ('Europe/Vatican', 'Europe/Vatican'),
>  ('Europe/Vienna', 'Europe/Vienna'),
>  ('Europe/Vilnius', 'Europe/Vilnius'),
>  ('Europe/Volgograd', 'Europe/Volgograd'),
>  ('Europe/Warsaw', 'Europe/Warsaw'),
>  ('Europe/Zagreb', 'Europe/Zagreb'),
>  ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
>  ('Europe/Zurich', 'Europe/Zurich'),
>  ('GB', 'GB'),
>  ('GB-Eire', 'GB-Eire'),
>  ('GMT', 'GMT'),
>  ('GMT+0', 'GMT+0'),
>  ('GMT-0', 'GMT-0'),
>  ('GMT0', 'GMT0'),
>  ('Greenwich', 'Greenwich'),
>  ('HST', 'HST'),
>  ('Hongkong', 'Hongkong'),
>  ('Iceland', 'Iceland'),
>  ('Indian/Antananarivo', 'Indian/Antananarivo'),
>  ('Indian/Chagos', 'Indian/Chagos'),
>  ('Indian/Christmas', 'Indian/Christmas'),
>  ('Indian/Cocos', 'Indian/Cocos'),
>  ('Indian/Comoro', 'Indian/Comoro'),
>  ('Indian/Kerguelen', 'Indian/Kerguelen'),
>  ('Indian/Mahe', 'Indian/Mahe'),
>  ('Indian/Maldives', 'Indian/Maldives'),
>  ('Indian/Mauritius', 'Indian/Mauritius'),
>  ('Indian/Mayotte', 'Indian/Mayotte'),
>  ('Indian/Reunion', 'Indian/Reunion'),
>  ('Iran', 'Iran'),
>  ('Israel', 'Israel'),
>  ('Jamaica', 'Jamaica'),
>  ('Japan', 'Japan'),
>  ('Kwajalein', 'Kwajalein'),
>  ('Libya', 'Libya'),
>  ('MET', 'MET'),
>  ('MST', 'MST'),
>  ('MST7MDT', 'MST7MDT'),
>  ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
>  ('Mexico/BajaSur', 'Mexico/BajaSur'),
>  ('Mexico/General', 'Mexico/General'),
>  ('NZ', 'NZ'),
>  ('NZ-CHAT', 'NZ-CHAT'),
>  ('Navajo', 'Navajo'),
>  ('PRC', 'PRC'),
>  ('PST8PDT', 'PST8PDT'),
>  ('Pacific/Apia', 'Pacific/Apia'),
>  ('Pacific/Auckland', 'Pacific/Auckland'),
>  ('Pacific/Chatham', 'Pacific/Chatham'),
>  ('Pacific/Chuuk', 'Pacific/Chuuk'),
>  ('Pacific/Easter', 'Pacific/Easter'),
>  ('Pacific/Efate', 'Pacific/Efate'),
>  ('Pacific/Enderbury', 'Pacific/Enderbury'),
>  ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
>  ('Pacific/Fiji', 'Pacific/Fiji'),
>  ('Pacific/Funafuti', 'Pacific/Funafuti'),
>  ('Pacific/Galapagos', 'Pacific/Galapagos'),
>  ('Pacific/Gambier', 'Pacific/Gambier'),
>  ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
>  ('Pacific/Guam', 'Pacific/Guam'),
>  ('Pacific/Honolulu', 'Pacific/Honolulu'),
>  ('Pacific/Johnston', 'Pacific/Johnston'),
>  ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
>  ('Pacific/Kosrae', 'Pacific/Kosrae'),
>  ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
>  ('Pacific/Majuro', 'Pacific/Majuro'),
>  ('Pacific/Marquesas', 'Pacific/Marquesas'),
>  ('Pacific/Midway', 'Pacific/Midway'),
>  ('Pacific/Nauru', 'Pacific/Nauru'),
>  ('Pacific/Niue', 'Pacific/Niue'),
>  ('Pacific/Norfolk', 'Pacific/Norfolk'),
>  ('Pacific/Noumea', 'Pacific/Noumea'),
>  ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
>  ('Pacific/Palau', 'Pacific/Palau'),
>  ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
>  ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
>  ('Pacific/Ponape', 'Pacific/Ponape'),
>  ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
>  ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
>  ('Pacific/Saipan', 'Pacific/Saipan'),
>  ('Pacific/Samoa', 'Pacific/Samoa'),
>  ('Pacific/Tahiti', 'Pacific/Tahiti'),
>  ('Pacific/Tarawa', 'Pacific/Tarawa'),
>  ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
>  ('Pacific/Truk', 'Pacific/Truk'),
>  ('Pacific/Wake', 'Pacific/Wake'),
>  ('Pacific/Wallis', 'Pacific/Wallis'),
>  ('Pacific/Yap', 'Pacific/Yap'),
>  ('Poland', 'Poland'),
>  ('Portugal', 'Portugal'),
>  ('ROC', 'ROC'),
>  ('ROK', 'ROK'),
>  ('Singapore', 'Singapore'),
>  ('Turkey', 'Turkey'),
>  ('UCT', 'UCT'),
>  ('US/Alaska', 'US/Alaska'),
>  ('US/Aleutian', 'US/Aleutian'),
>  ('US/Arizona', 'US/Arizona'),
>  ('US/Central', 'US/Central'),
>  ('US/East-Indiana', 'US/East-Indiana'),
>  ('US/Eastern', 'US/Eastern'),
>  ('US/Hawaii', 'US/Hawaii'),
>  ('US/Indiana-Starke', 'US/Indiana-Starke'),
>  ('US/Michigan', 'US/Michigan'),
>  ('US/Mountain', 'US/Mountain'),
>  ('US/Pacific', 'US/Pacific'),
>  ('US/Pacific-New', 'US/Pacific-New'),
>  ('US/Samoa', 'US/Samoa'),
>  ('UTC', 'UTC'),
>  ('Universal', 'Universal'),
>  ('W-SU', 'W-SU'),
>  ('WET', 'WET'),
>  ('Zulu', 'Zulu')]
> FILE_UPLOAD_HANDLERS
> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
>  'django.core.files.uploadhandler.TemporaryFileUploadHandler')
> DEFAULT_CONTENT_TYPE
> 'text/html'
> DEBUG_STATIC
> False
> ACCOUNT_APPROVAL_REQUIRED
> False
> APPEND_SLASH
> True
> FIRST_DAY_OF_WEEK
> 0
> DATABASE_ROUTERS
> DEFAULT_TABLESPACE
> YEAR_MONTH_FORMAT
> 'F Y'
> STATICFILES_STORAGE
> 'django.contrib.staticfiles.storage.StaticFilesStorage'
> CACHES
> {'default': {'BACKEND': 'django.core.cache.backends.dummy.DummyCache'}}
> DEFAULT_ANONYMOUS_DOWNLOAD_PERMISSION
> True
> CKAN_ORIGINS
> [{'css_class': 'hdx',
>   'label': 'Humanitarian Data Exchange (HDX)',
>   'url': 'https://data.hdx.rwlabs.org/dataset/new?title={name}&dataset_date={date}&notes={abstract}&caveats={caveats}'}]
> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
> False
> SERVER_EMAIL
> 'root at localhost'
> SESSION_COOKIE_PATH
> USE_X_FORWARDED_HOST
> False
> ACCOUNT_OPEN_SIGNUP
> True
> ROOT_URLCONF
> 'geonode.urls'
> CATALOGUE
> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>              'URL': 'http://muchita.cnpm.embrapa.br/catalogue/csw'}}
> MISSING_THUMBNAIL
> 'geonode/img/missing_thumb.png'
> FILE_UPLOAD_TEMP_DIR
> None
> MIDDLEWARE_CLASSES
> ('django.middleware.common.CommonMiddleware',
>  'django.contrib.sessions.middleware.SessionMiddleware',
>  'django.contrib.messages.middleware.MessageMiddleware',
>  'django.middleware.locale.LocaleMiddleware',
>  'pagination.middleware.PaginationMiddleware',
>  'django.middleware.csrf.CsrfViewMiddleware',
>  'django.contrib.auth.middleware.AuthenticationMiddleware',
>  'django.middleware.clickjacking.XFrameOptionsMiddleware')
> USE_I18N
> True
> THOUSAND_SEPARATOR
> SECRET_KEY
> MODELTRANSLATION_FALLBACK_LANGUAGES
> ('en',)
> LANGUAGE_COOKIE_NAME
> 'django_language'
> ACCOUNT_REMEMBER_ME_EXPIRY
> 315360000
> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
> ACCOUNT_EMAIL_UNIQUE
> True
> TRANSACTIONS_MANAGED
> False
> LOGGING_CONFIG
> 'django.utils.log.dictConfig'
> TEMPLATE_LOADERS
> ('django.template.loaders.filesystem.Loader',
>  'django.template.loaders.app_directories.Loader')
> FORCE_SCRIPT_NAME
> None
> TASTYPIE_DEFAULT_FORMATS
> ['json']
> TEMPLATE_DEBUG
> True
> AUTO_GENERATE_AVATAR_SIZES
> (20, 32, 80, 100, 140, 200)
> CSRF_COOKIE_NAME
> 'csrftoken'
> 'default'
> CELERY_DEFAULT_ROUTING_KEY
> ACCOUNT_LOGIN_REDIRECT_URL
> u'/'
> CELERY_ALWAYS_EAGER
> True
> MODIFY_TOPICCATEGORY
> False
> SIGNING_BACKEND
> 'django.core.signing.TimestampSigner'
> SESSION_COOKIE_SECURE
> False
> ACCOUNT_LOGIN_URL
> u'account_login'
> CACHE_TIME
> 0
> PYCSW
> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
>                                         'contact_email': 'Email Address',
>                                         'contact_name': 'Organization Name',
>                                         'date': 'YYYY-MM-DD',
>                                         'default_language': 'eng',
>                                         'enabled': 'true',
>                                         'gemet_keywords': 'Utility and governmental services',
>                                         'languages_supported': 'eng,gre',
>                                         'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
>                    'metadata:main': {'contact_address': 'Mailing Address',
>                                      'contact_city': 'City',
>                                      'contact_country': 'Country',
>                                      'contact_fax': '+xx-xxx-xxx-xxxx',
>                                      'contact_hours': 'Hours of Service',
>                                      'contact_instructions': 'During hours of service. Off on weekends.',
>                                      'contact_name': 'Lastname, Firstname',
>                                      'contact_phone': '+xx-xxx-xxx-xxxx',
>                                      'contact_position': 'Position Title',
>                                      'contact_postalcode': 'Zip or Postal Code',
>                                      'contact_role': 'pointOfContact',
>                                      'contact_stateorprovince': 'Administrative Area',
>                                      'contact_url': 'Contact URL',
>                                      'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing,              and collaborative use of geospatial data',
>                                      'identification_accessconstraints': 'None',
>                                      'identification_fees': 'None',
>                                      'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
>                                      'identification_keywords_type': 'theme',
>                                      'identification_title': 'GeoNode Catalogue',
>                                      'provider_name': 'Organization Name',
>                                      'provider_url': 'http://localhost:8000/'}}}
> CSRF_COOKIE_DOMAIN
> None
> FILE_CHARSET
> 'utf-8'
> DEBUG
> True
> SESSION_FILE_PATH
> None
> DEFAULT_FILE_STORAGE
> 'django.core.files.storage.FileSystemStorage'
> INSTALLED_APPS
> ('django.contrib.auth',
>  'django.contrib.contenttypes',
>  'django.contrib.sessions',
>  'django.contrib.sites',
>  'django.contrib.admin',
>  'django.contrib.sitemaps',
>  'django.contrib.staticfiles',
>  'django.contrib.messages',
>  'django.contrib.humanize',
>  'django.contrib.gis',
>  'pagination',
>  'taggit',
>  'friendlytagloader',
>  'geoexplorer',
>  'leaflet',
>  'django_extensions',
>  'autocomplete_light',
>  'mptt',
>  'modeltranslation',
>  'djcelery',
>  'pinax_theme_bootstrap_account',
>  'pinax_theme_bootstrap',
>  'django_forms_bootstrap',
>  'account',
>  'avatar',
>  'dialogos',
>  'agon_ratings',
>  'announcements',
>  'actstream',
>  'user_messages',
>  'tastypie',
>  'polymorphic',
>  'guardian',
>  'geonode.people',
>  'geonode.base',
>  'geonode.layers',
>  'geonode.maps',
>  'geonode.proxy',
>  'geonode.security',
>  'geonode.social',
>  'geonode.catalogue',
>  'geonode.documents',
>  'geonode.api',
>  'geonode.groups',
>  'geonode.services',
>  'geonode.geoserver',
>  'geonode.upload',
>  'geonode.tasks')
> LANGUAGES_BIDI
> ('he', 'ar', 'fa', 'ur')
> USE_L10N
> False
> DATABASE_ENGINE
> 'postgresql_psycopg2'
> STATIC_ROOT
> '/var/www/geonode/static/'
> STATICFILES_DIRS
> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
> DATABASE_NAME
> 'geonode'
> LEAFLET_CONFIG
> {'PLUGINS': {u'ALL': {u'css': [u'/static/leaflet/draw/leaflet.draw.css',
>                                '/static/lib/css/leaflet.fullscreen.css'],
>                       u'js': [u'/static/leaflet/draw/leaflet.draw.js',
>                               u'/static/leaflet/leaflet.extras.js',
>                               u'/static/leaflet/leaflet.forms.js',
>                               '/static/lib/js/Leaflet.fullscreen.min.js',
>                               '/static/lib/js/esri-leaflet.js']},
>              u'__default__': {u'css': ['/static/lib/css/leaflet.fullscreen.css'],
>                               u'js': ['/static/lib/js/Leaflet.fullscreen.min.js',
>              u'__is_normalized__': True,
>              'esri-leaflet': {'auto-include': True,
>                               u'css': [],
>                               'js': ['/static/lib/js/esri-leaflet.js']},
>              u'forms': {u'auto-include': False,
>                         u'css': [u'/static/leaflet/draw/leaflet.draw.css'],
>                                 u'/static/leaflet/leaflet.forms.js']},
>              'leaflet-fullscreen': {'auto-include': True,
>                                     'js': ['/static/lib/js/Leaflet.fullscreen.min.js']}},
>  'TILES': [('Watercolor',
>             'http://{s}.tile.stamen.com/watercolor/{z}/{x}/{y}.png <http://tile.stamen.com/watercolor/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>'),
>            ('Toner Lite',
>             'http://{s}.tile.stamen.com/toner-lite/{z}/{x}/{y}.png <http://tile.stamen.com/toner-lite/%7Bz%7D/%7Bx%7D/%7By%7D.png>',
>             'Map tiles by <a href="http://stamen.com">Stamen Design</a>,          <a href="http://creativecommons.org/licenses/by/3.0">CC BY 3.0</a> — Map data ©          <a href="http://openstreetmap.org">OpenStreetMap</a> contributors,          <a href="http://creativecommons.org/licenses/by-sa/2.0/">CC-BY-SA</a>')]}
> DOWNLOAD_FORMATS_VECTOR
> ['JPEG',
>  'PDF',
>  'PNG',
>  'Zipped Shapefile',
>  'GML 2.0',
>  'GML 3.1.1',
>  'CSV',
>  'Excel',
>  'GeoJSON',
>  'KML',
>  'Tiles']
> PREPEND_WWW
> False
> SECURE_PROXY_SSL_HEADER
> None
> SOCIAL_ORIGINS
> [{'css_class': 'email',
>   'label': 'Email',
>   'url': 'mailto:?subject={name}&body={url}'},
>  {'css_class': 'fb',
>   'label': 'Facebook',
>   'url': 'http://www.facebook.com/sharer.php?u={url}'},
>  {'css_class': 'tw',
>   'label': 'Twitter',
>   'url': 'https://twitter.com/share?url={url}'},
>  {'css_class': 'gp',
>   'label': 'Google +',
>   'url': 'https://plus.google.com/share?url={url}'}]
> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
> SESSION_COOKIE_HTTPONLY
> True
> DATABASE_PORT
> '5432'
> DEBUG_PROPAGATE_EXCEPTIONS
> False
> DEFAULT_ANONYMOUS_VIEW_PERMISSION
> True
> MEDIA_URL
> '/uploaded/'
> MONTH_DAY_FORMAT
> 'F j'
> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
> u'account_login'
> LOGIN_URL
> '/account/login/'
> SESSION_EXPIRE_AT_BROWSER_CLOSE
> False
> OGP_URL
> 'http://geodata.tufts.edu/solr/select'
> CELERY_EAGER_PROPAGATES_EXCEPTIONS
> True
> TIME_FORMAT
> 'P'
> CELERY_IGNORE_RESULT
> True
> SERVICE_UPDATE_INTERVAL
> 0
> AUTH_USER_MODEL
> 'people.Profile'
> DATE_INPUT_FORMATS
> ('%Y-%m-%d',
>  '%m/%d/%Y',
>  '%m/%d/%y',
>  '%b %d %Y',
>  '%b %d, %Y',
>  '%d %b %Y',
>  '%d %b, %Y',
>  '%B %d %Y',
>  '%B %d, %Y',
>  '%d %B %Y',
>  '%d %B, %Y')
> ACCOUNT_LOGOUT_REDIRECT_URL
> u'/'
> HAYSTACK_SEARCH
> False
> AUTHENTICATION_BACKENDS
> ('django.contrib.auth.backends.ModelBackend',
>  'guardian.backends.ObjectPermissionBackend')
> EMAIL_HOST_PASSWORD
> CELERY_DISABLE_RATE_LIMITS
> True
> PASSWORD_RESET_TIMEOUT_DAYS
> CACHE_MIDDLEWARE_ALIAS
> 'default'
> SESSION_SAVE_EVERY_REQUEST
> False
> NUMBER_GROUPING
> 0
> SHORT_DATETIME_FORMAT
> 'm/d/Y P'
> SESSION_ENGINE
> 'django.contrib.sessions.backends.db'
> CELERY_RESULT_BACKEND
> None
> ACCOUNT_DELETION_MARK_CALLBACK
> CSRF_COOKIE_PATH
> LOGIN_REDIRECT_URL
> '/accounts/profile/'
> SITEURL
> 'http://muchita.cnpm.embrapa.br/'
> PROJECT_ROOT
> '/usr/local/lib/python2.7/dist-packages/geonode'
> ACCOUNT_DELETION_EXPUNGE_HOURS
> 48
> GEONODE_ROOT
> DECIMAL_SEPARATOR
> CSRF_FAILURE_VIEW
> 'django.views.csrf.csrf_failure'
> CELERY_SEND_EVENTS
> False
> NOSE_ARGS
> ['--nocapture', '--detailed-errors']
> LOCALE_PATHS
> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
> THEME_ACCOUNT_CONTACT_EMAIL
> 'admin at example.com'
> PASSWORD_HASHERS
> PROXY_ALLOWED_HOSTS
> MESSAGE_STORAGE
> 'django.contrib.messages.storage.fallback.FallbackStorage'
> USE_QUEUE
> False
> COMMENTS_ALLOW_PROFANITIES
> False
> LOGOUT_URL
> '/account/logout/'
> MAP_BASELAYERS
> [{'source': {'ptype': 'gxp_wmscsource',
>              'restUrl': '/gs/rest',
>              'url': 'http://muchita.cnpm.embrapa.br/geoserver/wms'}},
>  {'args': ['No background'],
>   'fixed': True,
>   'group': 'background',
>   'source': {'ptype': 'gxp_olsource'},
>   'type': 'OpenLayers.Layer',
>   'visibility': False},
>  {'args': ['OpenStreetMap'],
>   'fixed': True,
>   'type': 'OpenLayers.Layer.OSM',
>  {'group': 'background',
>   'name': 'osm',
>   'source': {'ptype': 'gxp_mapquestsource'},
>   'visibility': True},
>   'name': 'naip',
>  {'fixed': True,
>   'name': 'AerialWithLabels',
>   'source': {'ptype': 'gxp_bingsource'},
>  {'source': {'ptype': 'gxp_mapboxsource'}}]
> EMAIL_USE_TLS
> False
> ACCOUNT_LANGUAGES
> [('en', u'English'),
>  ('es', u'espa\xf1ol'),
>  ('it', u'italiano'),
>  ('fr', u'fran\xe7ais'),
>  ('de', u'Deutsch'),
>  ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
>  ('id', u'Bahasa Indonesia'),
>  ('zh-cn', u'\u7b80\u4f53\u4e2d\u6587'),
>  ('ja', u'\u65e5\u672c\u8a9e'),
>  ('fa', u'\u0641\u0627\u0631\u0633\u06cc'),
>  ('ar', u'\u0627\u0644\u0639\u0631\u0628\u064a\u0651\u0629'),
>  ('bn', u'\u09ac\u09be\u0982\u09b2\u09be'),
>  ('ne', u'\u0928\u0947\u092a\u093e\u0932\u0940'),
>  ('sq', u'shqip'),
>  ('af', u'Afrikaans'),
>  ('sw', u'Kiswahili'),
>  ('pt', u'Portugu\xeas'),
>  ('pt-br', u'Portugu\xeas Brasileiro'),
>  ('ru', u'\u0420\u0443\u0441\u0441\u043a\u0438\u0439'),
>  ('vi', u'Ti\xea\u0301ng Vi\xea\u0323t'),
>  ('ko', u'\ud55c\uad6d\uc5b4'),
>  ('am', 'Amharic'),
>  ('km', u'Khmer'),
>  ('pl', u'polski'),
>  ('sv', u'svenska'),
>  ('th', u'\u0e20\u0e32\u0e29\u0e32\u0e44\u0e17\u0e22'),
>  ('uk', u'\u0423\u043a\u0440\u0430\u0457\u043d\u0441\u044c\u043a\u0430'),
>  ('si', 'sinhala'),
>  ('ta', u'tamil'),
>  ('tl', 'tagalog')]
> FIXTURE_DIRS
> ABSOLUTE_URL_OVERRIDES
> DATE_FORMAT
> 'N j, Y'
> OGC_SERVER
> {'default': {'BACKEND': 'geonode.geoserver',
>              'BACKEND_WRITE_ENABLED': True,
>              'DATASTORE': 'datastore',
>              'GEOGIG_DATASTORE_DIR': '',
>              'GEONODE_SECURITY_ENABLED': True,
>              'LOCATION': 'http://localhost:8080/geoserver/',
>              'LOG_FILE': '/usr/share/geoserver/data/logs/geoserver.log',
>              'MAPFISH_PRINT_ENABLED': True,
>              'PRINT_NG_ENABLED': True,
>              'PUBLIC_LOCATION': 'http://muchita.cnpm.embrapa.br/geoserver/',
>              'USER': 'admin',
>              'WMST_ENABLED': False,
>              'WPS_ENABLED': True}}
> SKIP_PERMS_FILTER
> False
> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
> MEDIA_ROOT
> '/var/www/geonode/uploaded'
> AGON_RATINGS_CATEGORY_CHOICES
> {'documents.Document': {'document': 'How good is this document?'},
>  'layers.Layer': {'layer': 'How good is this layer?'},
>  'maps.Map': {'map': 'How good is this map?'}}
> DATABASE_HOST
> DEFAULT_EXCEPTION_REPORTER_FILTER
> 'django.views.debug.SafeExceptionReporterFilter'
> ADMINS
> FORMAT_MODULE_PATH
> None
> DEFAULT_FROM_EMAIL
> GEONODE_APPS
> ('geonode.people',
>  'geonode.base',
>  'geonode.layers',
>  'geonode.maps',
>  'geonode.proxy',
>  'geonode.security',
>  'geonode.social',
>  'geonode.api',
>  'geonode.groups',
>  'geonode.services',
>  'geonode.upload',
>  'geonode.tasks')
> GEOSERVER_URL
> DATETIME_FORMAT
> 'N j, Y, P'
> TEMPLATE_DIRS
> ('/etc/geonode/templates',
>  '/usr/local/lib/python2.7/dist-packages/geonode/templates')
> ALLOWED_DOCUMENT_TYPES
> ['doc',
>  'docx',
>  'gif',
>  'jpg',
>  'jpeg',
>  'ods',
>  'odt',
>  'odp',
>  'pdf',
>  'png',
>  'ppt',
>  'pptx',
>  'rar',
>  'tif',
>  'tiff',
>  'txt',
>  'xls',
>  'xlsx',
>  'xml',
>  'zip',
>  'gz']
> NOTIFICATION_LANGUAGE_MODULE
> 'account.Account'
> ACCOUNT_DELETION_EXPUNGE_CALLBACK
> RESOURCE_PUBLISHING
> False
> ACCOUNT_HOOKSET
> <account.hooks.AccountDefaultHookSet object at 0x7fe06f67d210>
> PROXY_URL
> '/proxy/?url='
> SITE_ID
> 1
> DISALLOWED_USER_AGENTS
> ALLOWED_INCLUDE_ROOTS
> API_LIMIT_PER_PAGE
> ACCOUNT_SETTINGS_REDIRECT_URL
> u'account_settings'
> EXTRA_LANG_INFO
> {'am': {'bidi': False,
>         'code': 'am',
>         'name': 'Amharic',
>         'name_local': 'Amharic'},
>  'si': {'bidi': False,
>         'code': 'si',
>         'name': 'Sinhala',
>         'name_local': 'sinhala'},
>  'ta': {'bidi': False, 'code': 'ta', 'name': 'Tamil', 'name_local': u'tamil'},
>  'tl': {'bidi': False,
>         'code': 'tl',
>         'name': 'Tagalog',
>         'name_local': 'tagalog'}}
> LOGGING
> {'disable_existing_loggers': True,
>  'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
>  'formatters': {'simple': {'format': '%(message)s'},
>                 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
>  'handlers': {'console': {'class': 'logging.StreamHandler',
>                           'formatter': 'simple',
>                           'level': 'ERROR'},
>               'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
>                               'filters': ['require_debug_false'],
>                               'level': 'ERROR'},
>               'null': {'class': 'django.utils.log.NullHandler',
>                        'level': 'ERROR'}},
>  'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>              'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>              'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
>              'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>              'pycsw': {'handlers': ['console'], 'level': 'ERROR'}},
>  'version': 1}
> SHORT_DATE_FORMAT
> 'm/d/Y'
> DATABASE_USER
> 'geonode'
> TEST_RUNNER
> 'django_nose.NoseTestSuiteRunner'
> ACTSTREAM_SETTINGS
> {'FETCH_RELATIONS': True,
>  'GFK_FETCH_DEPTH': 1,
>  'MODELS': ('people.Profile',
>             'layers.layer',
>             'maps.map',
>             'dialogos.comment',
>             'documents.document',
>             'services.service'),
>  'USE_JSONFIELD': True,
>  'USE_PREFETCH': False}
> MODELTRANSLATION_LANGUAGES
> ['en']
> HAYSTACK_FACET_COUNTS
> False
> CACHE_MIDDLEWARE_KEY_PREFIX
> DEFAULT_WORKSPACE
> 'geonode'
> TIME_ZONE
> 'America/Chicago'
> FILE_UPLOAD_MAX_MEMORY_SIZE
> 2621440
> LOCAL_GEOSERVER
> EMAIL_BACKEND
> 'django.core.mail.backends.smtp.EmailBackend'
> ANONYMOUS_USER_ID
> -1
> POSTGIS_VERSION
> (2, 1, 0)
> DEFAULT_MAP_ZOOM
> 0
> TEMPLATE_CONTEXT_PROCESSORS
> ('django.contrib.auth.context_processors.auth',
>  'django.core.context_processors.debug',
>  'django.core.context_processors.i18n',
>  'django.core.context_processors.tz',
>  'django.core.context_processors.media',
>  'django.core.context_processors.static',
>  'django.core.context_processors.request',
>  'django.contrib.messages.context_processors.messages',
>  'account.context_processors.account',
>  'geonode.context_processors.resource_urls',
>  'geonode.geoserver.context_processors.geoserver_urls')
> CELERY_QUEUES
> [<unbound Queue 'default' -> <unbound Exchange ''(direct)> -> default>,
>  <unbound Queue 'cleanup' -> <unbound Exchange ''(direct)> -> cleanup>,
>  <unbound Queue 'update' -> <unbound Exchange ''(direct)> -> update>,
>  <unbound Queue 'email' -> <unbound Exchange ''(direct)> -> email>]
> LOCKDOWN_GEONODE
> False
> SESSION_COOKIE_AGE
> 1209600
> SETTINGS_MODULE
> 'geonode.settings'
> GUARDIAN_GET_INIT_ANONYMOUS_USER
> 'geonode.people.models.get_anonymous_user_instance'
> USE_ETAGS
> False
> SOCIAL_BUTTONS
> True
> LANGUAGES
> (('en', 'English'),
>  ('es', 'Espa\xc3\xb1ol'),
>  ('it', 'Italiano'),
>  ('fr', 'Fran\xc3\xa7ais'),
>  ('de', 'Deutsch'),
>  ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
>  ('id', 'Bahasa Indonesia'),
>  ('zh-cn', '\xe4\xb8\xad\xe6\x96\x87'),
>  ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe8\xaa\x9e'),
>  ('fa', 'Persian'),
>  ('ar', 'Arabic'),
>  ('bn', 'Bengali'),
>  ('ne', 'Nepali'),
>  ('sq', 'Albanian'),
>  ('af', 'Afrikaans'),
>  ('sw', 'Swahili'),
>  ('pt', 'Portuguese'),
>  ('pt-br', 'Portugu\xc3\xaas Brasil'),
>  ('ru', 'Russian'),
>  ('vi', 'Vietnamese'),
>  ('ko', '\xed\x95\x9c\xea\xb5\xad\xec\x96\xb4'),
>  ('am', 'Amharic'),
>  ('km', 'Khmer'),
>  ('pl', 'Polish'),
>  ('sv', 'Swedish'),
>  ('th', 'Thai'),
>  ('uk', 'Ukranian'),
>  ('si', 'Sinhala'),
>  ('ta', 'Tamil'),
>  ('tl', 'Tagalog'))
> CELERY_TASK_RESULT_EXPIRES
> 1
> DEFAULT_INDEX_TABLESPACE
> INTERNAL_IPS
> STATIC_URL
> '/static/'
> EMAIL_PORT
> 25
> LAYER_PREVIEW_LIBRARY
> 'geoext'
> USE_TZ
> False
> DEFAULT_SEARCH_SIZE
> 10
> CLIENT_RESULTS_LIMIT
> 100
> MODELTRANSLATION_DEFAULT_LANGUAGE
> 'en'
> ACCOUNT_SIGNUP_REDIRECT_URL
> u'/'
> DOCUMENT_TYPE_MAP
> {'doc': 'text',
>  'docx': 'text',
>  'gif': 'image',
>  'gz': 'archive',
>  'jpeg': 'image',
>  'jpg': 'image',
>  'log': 'text',
>  'odp': 'presentation',
>  'ods': 'text',
>  'odt': 'text',
>  'pdf': 'presentation',
>  'png': 'image',
>  'ppt': 'presentation',
>  'pptx': 'presentation',
>  'rar': 'archive',
>  'tif': 'image',
>  'tiff': 'image',
>  'txt': 'text',
>  'xls': 'text',
>  'xlsx': 'text',
>  'xml': 'text',
>  'zip': 'archive'}
> CACHE_MIDDLEWARE_SECONDS
> 600
> SITENAME
> 'GeoNode'
> ACCOUNT_CREATE_ON_SAVE
> True
> CSRF_COOKIE_HTTPONLY
> False
> DATETIME_INPUT_FORMATS
> ('%Y-%m-%d %H:%M:%S',
>  '%Y-%m-%d %H:%M:%S.%f',
>  '%Y-%m-%d %H:%M',
>  '%Y-%m-%d',
>  '%m/%d/%Y %H:%M:%S',
>  '%m/%d/%Y %H:%M:%S.%f',
>  '%m/%d/%Y %H:%M',
>  '%m/%d/%Y',
>  '%m/%d/%y %H:%M:%S',
>  '%m/%d/%y %H:%M:%S.%f',
>  '%m/%d/%y %H:%M',
>  '%m/%d/%y')
> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
> False
> DATABASE_PASSWORD
> PROFANITIES_LIST
> EMAIL_HOST_USER
> MAX_DOCUMENT_SIZE
> 2
> You're seeing this error because you have DEBUG = True in your Django
> settings file. Change that to False, and Django will display a standard
> 500 page.
> Davi de O. Custódio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150527/620cad0b/attachment-0001.html>
More information about the geonode-users mailing list
