[GeoNode-users] Fwd: Layer styles not updatable 2.4b25
Simone Dalmasso
simone.dalmasso at gmail.com
Thu May 28 01:19:40 PDT 2015
Thanks for the feedback Rainer.
So it is failing when you edit the style and the widget makes a put to
geoserver. We should try to load a very heavy layer on demo.geonode.org to
replicate this.
2015-05-28 9:58 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com>:
> It happens mostly with quite big layers (say > 5000 points) . As said in
> https://github.com/GeoNode/geonode/issues/2031#issuecomment-106215309 it
> is connected wit a PUT request not being replied by the server.
> 2015-05-12 13:37 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hm, I'd really like to sort this out. :) but I need to find the way to
>> replicate it. Thanks for the debug so far.
>> 2015-05-12 13:33 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>> i am using 2.4b25 as installed from ppa geonode/testing on trusty lts
>>> _____________________________________
>>> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
>>> Linux, GIS and database developer team
>>> Wittmannsdorfer Str. 4
>>> 12053 Berlin
>>> Germany / Allemagne
>>> Tel.: +49 (0) 30 28 45 40 71
>>> Mobil: +49 (0) 163 681 77 34
>>> Fax: +49 (0)30 / 48 49 81 286
>>> 2015-05-12 13:26 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> I don't see errors, I'm also trying to replicate both locally and on
>>>> demo.geonode.org but every created style works fine.
>>>> Are you using the last geonode b25 or something older?
>>>> 2015-05-12 12:20 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>> Hi , all styles were created in geonode GUI, so no pattern there.
>>>>> also now errors in stacktrace
>>>>> AXIS["Latitude", NORTH],
>>>>> AUTHORITY["EPSG","4326"]],
>>>>> PROJECTION["Mercator_1SP"],
>>>>> PARAMETER["semi_minor", 6378137.0],
>>>>> PARAMETER["latitude_of_origin", 0.0],
>>>>> PARAMETER["central_meridian", 0.0],
>>>>> PARAMETER["scale_factor", 1.0],
>>>>> PARAMETER["false_easting", 0.0],
>>>>> PARAMETER["false_northing", 0.0],
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> AUTHORITY["EPSG","900913"]]
>>>>> Bbox = SRSEnvelope[1056665.4788672 : 1066449.4184863, 7122708.0427344
>>>>> : 7132491.9823535]
>>>>> RemoteOwsType = null
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> ValidateSchema = false
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BaseUrl = http://xx.x.x.x:xxxxx/geoserver/
>>>>> RawKvp = {_OLSALT=0.9492145837284625, _DC=0.7638796556275338,
>>>>> BBOX=1056665.4788672,7122708.0427344,1066449.4184863,7132491.9823535,
>>>>> SERVICE=WMS, TILED=true, HEIGHT=256, REQUEST=GetMap,
>>>>> STYLES=style1_3d7625b4, WIDTH=256, TRANSPARENT=TRUE, VERSION=1.1.1,
>>>>> FORMAT=image/png, LAYERS=geonode:layer11, SRS=EPSG:900913}
>>>>> RequestCharset = UTF-8
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,436 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> Layers = [org.geoserver.wms.MapLayerInfo at edaec8d6]
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> FeatureVersion = null
>>>>> Styles = [StyleImpl[ name=style1_3d7625b4]]
>>>>> Crs = PROJCS["WGS84 / Google Mercator",
>>>>> GEOGCS["WGS 84",
>>>>> DATUM["World Geodetic System 1984",
>>>>> SPHEROID["WGS 84", 6378137.0, 298.257223563,
>>>>> AUTHORITY["EPSG","7030"]],
>>>>> AUTHORITY["EPSG","6326"]],
>>>>> PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
>>>>> UNIT["degree", 0.017453292519943295],
>>>>> AXIS["Longitude", EAST],
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7103140.1634961 :
>>>>> 7112924.1031152]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1046881.539248,7103140.1634961,1056665.4788672,7112924.1031152,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,445 INFO [geoserver.wms] -
>>>>> Request: getServiceInfo
>>>>> 2015-05-12 10:10:25,446 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7093356.223877 :
>>>>> 7103140.1634961]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1046881.539248,7093356.223877,1056665.4788672,7103140.1634961,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,483 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,490 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7112924.1031152 :
>>>>> 7122708.0427344]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1046881.539248,7112924.1031152,1056665.4788672,7122708.0427344,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,503 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,511 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7083572.2842578
>>>>> : 7093356.223877]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1086017.2977246,7083572.2842578,1095801.2373438,7093356.223877,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,515 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,517 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7122708.0427344
>>>>> : 7132491.9823535]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1086017.2977246,7122708.0427344,1095801.2373438,7132491.9823535,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,528 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,530 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,538 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,547 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 512
>>>>> Height = 1024
>>>>> MaxFeatures = null
>>>>> Tiled = false
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323,
>>>>> 7083572.284257814 : 7122708.042734373]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BaseUrl = http://localhost:8080/geoserver/
>>>>> RawKvp =
>>>>> {BBOX=1095801.237343751,7083572.284257814,1115369.1165820323,7122708.
>>>>> 042734373, SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap,
>>>>> STYLES=style1_3d7625b4, WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true,
>>>>> VERSION=1.1.1, FORMAT=image/png, GWC_SEED_INTERCEPT=true,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,560 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,580 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7093356.223877 :
>>>>> 7103140.1634961]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1095801.2373438,7093356.223877,1105585.1769629,7103140.1634961,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,581 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7112924.1031152
>>>>> : 7122708.0427344]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1095801.2373438,7112924.1031152,1105585.1769629,7122708.0427344,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7103140.1634961
>>>>> : 7112924.1031152]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1095801.2373438,7103140.1634961,1105585.1769629,7112924.1031152,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,762 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,767 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,770 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7083572.2842578
>>>>> : 7093356.223877]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1095801.2373438,7083572.2842578,1105585.1769629,7093356.223877,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,773 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7083572.2842578 :
>>>>> 7093356.223877]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1046881.539248,7083572.2842578,1056665.4788672,7093356.223877,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,774 INFO [geoserver.wms] -
>>>>> 2015-05-12 10:10:25,785 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 1024
>>>>> Height = 1024
>>>>> MaxFeatures = null
>>>>> Tiled = false
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1017529.7203906253 : 1056665.478867188, 7122708.
>>>>> 042734373 : 7161843.801210936]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> RawKvp = {BBOX=1017529.7203906253,7122708.042734373,1056665.478867188,7161843.801210936,
>>>>> SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap, STYLES=style1_3d7625b4,
>>>>> WIDTH=1024, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
>>>>> FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=geonode:layer11,
>>>>> SRS=EPSG:900913}
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 512
>>>>> Height = 1024
>>>>> MaxFeatures = null
>>>>> Tiled = false
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323, 7122708.
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> RawKvp = {BBOX=1095801.237343751,7122708.042734373,1115369.1165820323,7161843.801210936,
>>>>> WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
>>>>> SRS=EPSG:900913}
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,804 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7122708.0427344
>>>>> : 7132491.9823535]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1095801.2373438,7122708.0427344,1105585.1769629,7132491.9823535,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 2015-05-12 10:10:25,825 INFO [geoserver.wms] -
>>>>> Request: getMap
>>>>> Exceptions = SE_XML
>>>>> Width = 256
>>>>> Height = 256
>>>>> MaxFeatures = null
>>>>> Tiled = true
>>>>> Palette = null
>>>>> SRS = EPSG:900913
>>>>> GEOGCS["WGS 84",
>>>>> UNIT["m", 1.0],
>>>>> AXIS["x", EAST],
>>>>> AXIS["y", NORTH],
>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7122708.0427344
>>>>> : 7132491.9823535]
>>>>> RemoteOwsURL = null
>>>>> Env = {}
>>>>> FormatOptions = {}
>>>>> Angle = 0.0
>>>>> CQLFilter = null
>>>>> Elevation = []
>>>>> FeatureId = null
>>>>> StartIndex = null
>>>>> ViewParams = null
>>>>> Transparent = true
>>>>> SldBody = null
>>>>> Sld = null
>>>>> SldVersion = null
>>>>> TilesOrigin = null
>>>>> Buffer = 0
>>>>> Format = image/png
>>>>> Time = []
>>>>> Filter = null
>>>>> Filters = null
>>>>> Get = true
>>>>> BBOX=1046881.539248,7122708.0427344,1056665.4788672,7132491.9823535,
>>>>> Version = 1.1.1
>>>>> Request = GetMap
>>>>> 12053 Berlin
>>>>> Germany / Allemagne
>>>>> 2015-05-12 11:55 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> that is indeed strange, it doesn't look at a permission bug. They
>>>>>> ones with no (none) might have a space instead. Do you have more
>>>>>> information on how you created those styles?
>>>>>> 2015-05-12 11:47 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>
>>>>>>> okay I found a pattern now:
>>>>>>> in /admin/layers/style/
>>>>>>> [image: Inline-Bild 1]
>>>>>>> -The styles that have "(None)" entry in the Workspace column can
>>>>>>> be edited via geonode style editor
>>>>>>> -The styles that have no "(None)" entry entry in the Workspace
>>>>>>> column canot be edited via geonode style editor
>>>>>>> How ever if i open a particular style in /admin/layers/style/ , the
>>>>>>> workspace field is empty for all stlyes, wether they have a "(None)" entry
>>>>>>> in the Workspace column or not.
>>>>>>> Is this a bug with the django permissions system?
>>>>>>> 12053 Berlin
>>>>>>> Germany / Allemagne
>>>>>>> 2015-05-12 11:27 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu
>>>>>>>> I have unticked the option "Automatic caching for non-standard
>>>>>>>> styles" in
>>>>>>>> /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.gwc.web.GWCSettingsPage
>>>>>>>> That resolved the issue for a number of layers but not for all. The
>>>>>>>> style for one point layer n my installation is still only editable in
>>>>>>>> geoserver via SLD, not via geonode gui.
>>>>>>>> 2015-05-12 10:43 GMT+02:00 Rainer Lissewski <
>>>>>>>>> hmm. The only difference I can see is that, here, the problem
>>>>>>>>> occurs with a point layer
>>>>>>>>> 12053 Berlin
>>>>>>>>> Germany / Allemagne
>>>>>>>>> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <
>>>>>>>>>> Rainer, I'm testing this here
>>>>>>>>>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't
>>>>>>>>>> replicate.
>>>>>>>>>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>> Open a layer, edit layer, edit style. In the popup, select rule
>>>>>>>>>>> and edit. Change color and/or opacity. Save and close. Repeat process, the
>>>>>>>>>>> rule has reverted back to its original style.
>>>>>>>>>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/80969c99/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/80969c99/attachment-0001.png>
More information about the geonode-users
