[GeoNode-users] Fwd: Layer styles not updatable 2.4b25
Rainer Lissewski rainerlissewski at gmail.com
Thu May 28 01:23:41 PDT 2015
Yes. I will think of a layer to upload. Anyhow, the behaviour is very
fuzzy, and sometime for no reason it works, and then again not. I have also
looked into performance issues, but my geonode (being used by a max of 3
users simultaneously) is running with 8GB RAM (6 of those for Java, i.e
geoserver) and dual core, so this should be sufficient, or am I wrong?
2015-05-28 10:19 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Thanks for the feedback Rainer.
> So it is failing when you edit the style and the widget makes a put to
> geoserver. We should try to load a very heavy layer on demo.geonode.org
> to replicate this.
> 2015-05-28 9:58 GMT+02:00 Rainer Lissewski <rainerlissewski at gmail.com>:
>> It happens mostly with quite big layers (say > 5000 points) . As said in
>> https://github.com/GeoNode/geonode/issues/2031#issuecomment-106215309 it
>> is connected wit a PUT request not being replied by the server.
>> 2015-05-12 13:37 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hm, I'd really like to sort this out. :) but I need to find the way to
>>> replicate it. Thanks for the debug so far.
>>> 2015-05-12 13:33 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>> i am using 2.4b25 as installed from ppa geonode/testing on trusty lts
>>>> _____________________________________
>>>> *A P L I K @ T E . E U <http://www.aplikate.eu/>*
>>>> Linux, GIS and database developer team
>>>> Wittmannsdorfer Str. 4
>>>> 12053 Berlin
>>>> Germany / Allemagne
>>>> Tel.: +49 (0) 30 28 45 40 71
>>>> Mobil: +49 (0) 163 681 77 34
>>>> Fax: +49 (0)30 / 48 49 81 286
>>>> 2015-05-12 13:26 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> I don't see errors, I'm also trying to replicate both locally and on
>>>>> demo.geonode.org but every created style works fine.
>>>>> Are you using the last geonode b25 or something older?
>>>>> 2015-05-12 12:20 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu>:
>>>>>> Hi , all styles were created in geonode GUI, so no pattern there.
>>>>>> also now errors in stacktrace
>>>>>>     AXIS["Latitude", NORTH],
>>>>>>     AUTHORITY["EPSG","4326"]],
>>>>>>   PROJECTION["Mercator_1SP"],
>>>>>>   PARAMETER["semi_minor", 6378137.0],
>>>>>>   PARAMETER["latitude_of_origin", 0.0],
>>>>>>   PARAMETER["central_meridian", 0.0],
>>>>>>   PARAMETER["scale_factor", 1.0],
>>>>>>   PARAMETER["false_easting", 0.0],
>>>>>>   PARAMETER["false_northing", 0.0],
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>>   AUTHORITY["EPSG","900913"]]
>>>>>> Bbox = SRSEnvelope[1056665.4788672 : 1066449.4184863, 7122708.0427344
>>>>>> : 7132491.9823535]
>>>>>> RemoteOwsType = null
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> BgColor = java.awt.Color[r=255,g=255,b=255]
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> ValidateSchema = false
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BaseUrl = http://xx.x.x.x:xxxxx/geoserver/
>>>>>> RawKvp = {_OLSALT=0.9492145837284625, _DC=0.7638796556275338,
>>>>>> BBOX=1056665.4788672,7122708.0427344,1066449.4184863,7132491.9823535,
>>>>>> SERVICE=WMS, TILED=true, HEIGHT=256, REQUEST=GetMap,
>>>>>> STYLES=style1_3d7625b4, WIDTH=256, TRANSPARENT=TRUE, VERSION=1.1.1,
>>>>>> FORMAT=image/png, LAYERS=geonode:layer11, SRS=EPSG:900913}
>>>>>> RequestCharset = UTF-8
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,436 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> Layers = [org.geoserver.wms.MapLayerInfo at edaec8d6]
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>> FeatureVersion = null
>>>>>> Styles = [StyleImpl[ name=style1_3d7625b4]]
>>>>>> Crs = PROJCS["WGS84 / Google Mercator",
>>>>>>   GEOGCS["WGS 84",
>>>>>>     DATUM["World Geodetic System 1984",
>>>>>>       SPHEROID["WGS 84", 6378137.0, 298.257223563,
>>>>>> AUTHORITY["EPSG","7030"]],
>>>>>>       AUTHORITY["EPSG","6326"]],
>>>>>>     PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
>>>>>>     UNIT["degree", 0.017453292519943295],
>>>>>>     AXIS["Longitude", EAST],
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7103140.1634961
>>>>>> : 7112924.1031152]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1046881.539248,7103140.1634961,1056665.4788672,7112924.1031152,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,445 INFO [geoserver.wms] -
>>>>>> Request: getServiceInfo
>>>>>> 2015-05-12 10:10:25,446 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7093356.223877 :
>>>>>> 7103140.1634961]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1046881.539248,7093356.223877,1056665.4788672,7103140.1634961,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,483 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,490 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7112924.1031152
>>>>>> : 7122708.0427344]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1046881.539248,7112924.1031152,1056665.4788672,7122708.0427344,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,503 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,511 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7083572.2842578
>>>>>> : 7093356.223877]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1086017.2977246,7083572.2842578,1095801.2373438,7093356.223877,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,515 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,517 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1086017.2977246 : 1095801.2373438, 7122708.0427344
>>>>>> : 7132491.9823535]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1086017.2977246,7122708.0427344,1095801.2373438,7132491.9823535,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,528 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,530 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,538 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,547 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 512
>>>>>> Height = 1024
>>>>>> MaxFeatures = null
>>>>>> Tiled = false
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323,
>>>>>> 7083572.284257814 : 7122708.042734373]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BaseUrl = http://localhost:8080/geoserver/
>>>>>> RawKvp =
>>>>>> {BBOX=1095801.237343751,7083572.284257814,1115369.1165820323,7122708.
>>>>>> 042734373, SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap,
>>>>>> STYLES=style1_3d7625b4, WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true,
>>>>>> VERSION=1.1.1, FORMAT=image/png, GWC_SEED_INTERCEPT=true,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,560 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,580 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7093356.223877
>>>>>> : 7103140.1634961]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1095801.2373438,7093356.223877,1105585.1769629,7103140.1634961,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,581 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7112924.1031152
>>>>>> : 7122708.0427344]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1095801.2373438,7112924.1031152,1105585.1769629,7122708.0427344,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7103140.1634961
>>>>>> : 7112924.1031152]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1095801.2373438,7103140.1634961,1105585.1769629,7112924.1031152,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,762 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,767 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,770 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7083572.2842578
>>>>>> : 7093356.223877]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1095801.2373438,7083572.2842578,1105585.1769629,7093356.223877,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,773 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7083572.2842578
>>>>>> : 7093356.223877]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1046881.539248,7083572.2842578,1056665.4788672,7093356.223877,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,774 INFO [geoserver.wms] -
>>>>>> 2015-05-12 10:10:25,785 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 1024
>>>>>> Height = 1024
>>>>>> MaxFeatures = null
>>>>>> Tiled = false
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1017529.7203906253 : 1056665.478867188, 7122708.
>>>>>> 042734373 : 7161843.801210936]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> RawKvp = {BBOX=1017529.7203906253,7122708.042734373,1056665.478867188,7161843.801210936,
>>>>>> SERVICE=WMS, HEIGHT=1024, REQUEST=GetMap, STYLES=style1_3d7625b4,
>>>>>> WIDTH=1024, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
>>>>>> FORMAT=image/png, GWC_SEED_INTERCEPT=true, LAYERS=geonode:layer11,
>>>>>> SRS=EPSG:900913}
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 512
>>>>>> Height = 1024
>>>>>> MaxFeatures = null
>>>>>> Tiled = false
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.237343751 : 1115369.1165820323, 7122708.
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> RawKvp = {BBOX=1095801.237343751,7122708.042734373,1115369.1165820323,7161843.801210936,
>>>>>> WIDTH=512, EXCEPTIONS=SE_XML, TRANSPARENT=true, VERSION=1.1.1,
>>>>>> SRS=EPSG:900913}
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,804 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1095801.2373438 : 1105585.1769629, 7122708.0427344
>>>>>> : 7132491.9823535]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1095801.2373438,7122708.0427344,1105585.1769629,7132491.9823535,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 2015-05-12 10:10:25,825 INFO [geoserver.wms] -
>>>>>> Request: getMap
>>>>>> Exceptions = SE_XML
>>>>>> Width = 256
>>>>>> Height = 256
>>>>>> MaxFeatures = null
>>>>>> Tiled = true
>>>>>> Palette = null
>>>>>> SRS = EPSG:900913
>>>>>>   GEOGCS["WGS 84",
>>>>>>   UNIT["m", 1.0],
>>>>>>   AXIS["x", EAST],
>>>>>>   AXIS["y", NORTH],
>>>>>> Bbox = SRSEnvelope[1046881.539248 : 1056665.4788672, 7122708.0427344
>>>>>> : 7132491.9823535]
>>>>>> RemoteOwsURL = null
>>>>>> Env = {}
>>>>>> FormatOptions = {}
>>>>>> Angle = 0.0
>>>>>> CQLFilter = null
>>>>>> Elevation = []
>>>>>> FeatureId = null
>>>>>> StartIndex = null
>>>>>> ViewParams = null
>>>>>> Transparent = true
>>>>>> SldBody = null
>>>>>> Sld = null
>>>>>> SldVersion = null
>>>>>> TilesOrigin = null
>>>>>> Buffer = 0
>>>>>> Format = image/png
>>>>>> Time = []
>>>>>> Filter = null
>>>>>> Filters = null
>>>>>> Get = true
>>>>>> BBOX=1046881.539248,7122708.0427344,1056665.4788672,7132491.9823535,
>>>>>> Version = 1.1.1
>>>>>> Request = GetMap
>>>>>> 12053 Berlin
>>>>>> Germany / Allemagne
>>>>>> 2015-05-12 11:55 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> that is indeed strange, it doesn't look at a permission bug. They
>>>>>>> ones with no (none) might have a space instead. Do you have more
>>>>>>> information on how you created those styles?
>>>>>>> 2015-05-12 11:47 GMT+02:00 Rainer Lissewski <r.lissewski at aplikate.eu
>>>>>>>> okay I found a pattern now:
>>>>>>>> in /admin/layers/style/
>>>>>>>> [image: Inline-Bild 1]
>>>>>>>> -The styles that have  "(None)" entry in the Workspace column  can
>>>>>>>> be edited via geonode style editor
>>>>>>>> -The styles that have no "(None)" entry entry in the Workspace
>>>>>>>> column  canot be edited via geonode style editor
>>>>>>>> How ever if i open a particular style in  /admin/layers/style/ ,
>>>>>>>> the workspace field is empty for all stlyes, wether they have a "(None)"
>>>>>>>> entry in the Workspace column or not.
>>>>>>>> Is this a bug with the django permissions system?
>>>>>>>> 12053 Berlin
>>>>>>>> Germany / Allemagne
>>>>>>>> 2015-05-12 11:27 GMT+02:00 Rainer Lissewski <
>>>>>>>>> I have unticked the option "Automatic caching for non-standard
>>>>>>>>> styles" in
>>>>>>>>> /geoserver/web/?wicket:bookmarkablePage=:org.geoserver.gwc.web.GWCSettingsPage
>>>>>>>>> That resolved the issue for a number of layers but not for all.
>>>>>>>>> The style for one point layer n my installation is still only editable in
>>>>>>>>> geoserver via SLD, not via geonode gui.
>>>>>>>>> 2015-05-12 10:43 GMT+02:00 Rainer Lissewski <
>>>>>>>>>> hmm. The only difference I can see is that, here,  the problem
>>>>>>>>>> occurs with a point layer
>>>>>>>>>> 12053 Berlin
>>>>>>>>>> Germany / Allemagne
>>>>>>>>>> 2015-05-12 10:33 GMT+02:00 Simone Dalmasso <
>>>>>>>>>>> Rainer, I'm testing this here
>>>>>>>>>>> http://demo.geonode.org/layers/geonode%3Astreams_2 but I can't
>>>>>>>>>>> replicate.
>>>>>>>>>>> 2015-05-12 10:23 GMT+02:00 Rainer Lissewski <
>>>>>>>>>>>> Open a layer, edit layer, edit style. In the popup, select rule
>>>>>>>>>>>> and edit. Change color and/or opacity. Save and close. Repeat process, the
>>>>>>>>>>>> rule has reverted back to its original style.
>>>>>>>>>>>> Also see https://github.com/GeoNode/geonode/issues/2146
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/a495d1a0/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150528/a495d1a0/attachment-0001.png>
More information about the geonode-users mailing list
