[GeoNode-users] geonode_data is still empty
Eugenio Trumpy frippe12573 at hotmail.com
Mon Nov 2 06:32:06 PST 2015
Thank you Ariel,
just setting the DATASTORE as 'datastore' in my local_setting.py now the shp file are saved in the postgis DB.
E.
Date: Mon, 2 Nov 2015 08:10:13 -0500
Subject: Re: [GeoNode-users] geonode_data is still empty
To: frippe12573 at hotmail.com
CC: geonode-users at lists.osgeo.org
What about your OWS configuration?. In the part of the settings file where geoserver is configured, you need to tell it to use the postgis datastore. One thing you can do is check out the production local settings file that we ship with the debian packages and check for differences:
https://github.com/GeoNode/geonode/blob/master/package/support/geonode.local_settings
-a
On Mon, Nov 2, 2015 at 4:44 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
Hi all,
I'm working to set up a new installation of geonode, and I was trying the functionalities.
I configured postgresql as DB. Following the instruction of the custom installation
I set up the two DBs, geonode and geonode_data.
I understood geonode_data is to store the uploaded spatial dataset as shp file,
so I tested an shp upload. The shp file was correctly uploaded, but it was saved in the
geoserver data dir and not in the db. Is that correct? am I missing something on the
local_setting.py or somewhare?
Of course my config file includes the parameters for the DBs and the DBs were created:
DATABASES = {
    'default': {
         'ENGINE': 'django.db.backends.postgresql_psycopg2',
         #'ENGINE': '',
         'NAME': 'geonode',
         'USER': 'geonode',
         'PASSWORD': 'my_pass',
         'HOST' : 'localhost',
         'PORT' : '5433',
    # vector datastore for uploads
    'datastore' : {
        'ENGINE': 'django.contrib.gis.db.backends.postgis',
        #'ENGINE': '', # Empty ENGINE name disables
        'NAME': 'geonode_data',
        'USER' : 'geonode',
        'PASSWORD' : 'my_pass',
        'PORT' : '5433',
Thank you for any hints
best
Eugenio
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151102/b26ab131/attachment.html>
More information about the geonode-users mailing list
