[GeoNode-users] Add Custom Metadata Fields
Tom Kralidis tomkralidis at gmail.com
Wed Nov 4 18:45:22 PST 2015
Hi Jonáš: most of the INSPIRE required fields are supported by
GeoNode. A quick scan indicates that, of the outstanding fields, some
we can add easily in the code base, and some require deeper discussion
(INSPIRE codelist values, GEMET keywords).
I'm not aware of any options for custom fields/profiles for GeoNode
resource models, though other devs/users may have suggestions.  This
is also a great opportunity to use INSPIRE as an example to implement
a generic approach to this feature.
..Tom
On Wed, Nov 4, 2015 at 12:04 PM, Jonáš Veselka <jonas.veselka at gisat.cz> wrote:
> Hi,
> we are preparing the GeoNode for a project, where we need metadata fields to
> be INSPIRE compliant.
> Specifically we need these fields:
> Resource title
> Resource abstract
> Resource type
> Resource locator
> Spatial data service type
> Keyword value
> Originating controlled vocabulary
> Geographic bounding box
> Temporal extent
> Date of creation
> Specification
> Degree
> Conditions applying to access and use
> Responsible party
> Responsible party role
> Metadata point of contact
> Metadata date
> Metadata language
> Based on this documentation
> http://docs.geonode.org/en/master/reference/developers/settings.html#pycsw
> we found that metadata:inspire['enabled'] is already set to true in our
> Geonode, but fields are different to INSPIRE standard:
> https://www.dropbox.com/s/znn4fvxvka0j5bm/geonode-metadata-fields.png?dl=0
> Is there any option to manage available metadata fields?
> Regards,
> Jonáš
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
