[GeoNode-users] Add Custom Metadata Fields
Tom Kralidis tomkralidis at gmail.com
Fri Nov 6 16:47:51 PST 2015
Hi Jonáš: this would require development and, given that it's likely a
model change, a migration plan for a future release.  Having said
this, I think this would be a valuable feature.
..Tom
On Thu, Nov 5, 2015 at 11:14 AM, Jonáš Veselka <jonas.veselka at gisat.cz> wrote:
> Tom,
> do You mean to add that fields by ourself in our instance of Geonode or we
> could do that with Your help to be in next release?
> Jonáš
> 2015-11-05 3:45 GMT+01:00 Tom Kralidis <tomkralidis at gmail.com>:
>> Hi Jonáš: most of the INSPIRE required fields are supported by
>> GeoNode. A quick scan indicates that, of the outstanding fields, some
>> we can add easily in the code base, and some require deeper discussion
>> (INSPIRE codelist values, GEMET keywords).
>> I'm not aware of any options for custom fields/profiles for GeoNode
>> resource models, though other devs/users may have suggestions.  This
>> is also a great opportunity to use INSPIRE as an example to implement
>> a generic approach to this feature.
>> ..Tom
>> On Wed, Nov 4, 2015 at 12:04 PM, Jonáš Veselka <jonas.veselka at gisat.cz>
>> wrote:
>> > Hi,
>> > we are preparing the GeoNode for a project, where we need metadata
>> > fields to
>> > be INSPIRE compliant.
>> > Specifically we need these fields:
>> > Resource title
>> > Resource abstract
>> > Resource type
>> > Resource locator
>> > Spatial data service type
>> > Keyword value
>> > Originating controlled vocabulary
>> > Geographic bounding box
>> > Temporal extent
>> > Date of creation
>> > Specification
>> > Degree
>> > Conditions applying to access and use
>> > Responsible party
>> > Responsible party role
>> > Metadata point of contact
>> > Metadata date
>> > Metadata language
>> > Based on this documentation
>> > http://docs.geonode.org/en/master/reference/developers/settings.html#pycsw
>> > we found that metadata:inspire['enabled'] is already set to true in our
>> > Geonode, but fields are different to INSPIRE standard:
>> > https://www.dropbox.com/s/znn4fvxvka0j5bm/geonode-metadata-fields.png?dl=0
>> > Is there any option to manage available metadata fields?
>> > Regards,
>> > Jonáš
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
