[GeoNode-users] geonode updatelayers exception "non-XML response"
Christian Willmes
c.willmes at uni-koeln.de
Tue Nov 10 08:16:40 PST 2015
I get the attached two error stack traces in catalina.out, regarding
remote services.
I tried to add this service:
http://geonode.crc806db.uni-koeln.de:8081/GEBCO/service?REQUEST=GetCapabilities
The Metadata is read in correctly, on accessing the layer from the
GeoNode frontend, I get error1.log.
On accessing the layer remotely from a third party application, I get
the error2.log stack trace.
It seems the metadata is read in correctly, but the layer is not created...
Regards,
Christian
Am 10.11.2015 um 09:41 schrieb Christian Willmes:
> The "catalina.out" provides some useful information. I did not looked
> there yet, will take some time for it this afternoon, and report back
> if there is still a problem, and what its about. If I still can't fix
> it, I will try to join during the sprint online next week.
> Thanks,
> Christian
> Am 09.11.2015 um 15:48 schrieb Jeffrey Johnson:
>> Christian,
>> Can you join us online next week during the sprint to look into this
>> issue? Also, its probably helpful if you paste the stacktrace from
>> tomcat.
>> Jeff
>> On Sun, Nov 8, 2015 at 11:49 PM, Christian Willmes
>> <christian.willmes at googlemail.com> wrote:
>>> Hi,
>>> any advice on this? How can I fix it and preserve my data, and most
>>> important the URLs?
>>> I considered reinstalling Geonode, by preserving the GeoServer, but I
>>> figured, that this may break the URLs, which would be bad, because
>>> other
>>> applications link to the Geonode resources.
>>> Regards,
>>> Christian
>>> Am 05.11.2015 um 16:58 schrieb Christian Willmes:
>>>> Hi,
>>>> I can't run the "geonode updatelayers" command anymore, because it
>>>> always
>>>> aborts with an error like:
>>>>>> Exception: ('GeoServer gave non-XML response for [GET
>>>>>> http://localhost:8080/geoserver/rest/workspaces/geonode/datastores/datastore/featuretypes/lgm_landmask_hires.xml]:
>>>>>> <featureType>\n <name>lgm_landmask_hires</name>\n
>>>>>> <nativeName>lgm_landmask_hires</nativeName>\n <namespace>\n
>>>>>> <name>geonode</name>\n [...]
>>>> I cant fix the schema in geoserver by reloading the feature type in
>>>> the
>>>> Layer edit view, but it does not work. It throws really long java
>>>> stack
>>>> trace in the "publication" tab, one line says:
>>>>>> Caused by: java.io.IOException: Schema 'lgm_landmask_hires' does not
>>>>>> exist.
>>>> I also completely deleted another layer, that throwed this same error
>>>> before. But its not really an option to delete all layers to be
>>>> able to run
>>>> the command again.
>>>> I also tried with the --ignore-errors option, but got the same error /
>>>> abort.
>>>> How can I fix or circumvent this problem?
>>>> Thanks and regards,
>>>> Christian
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
Christian Willmes
AG GIS & Fernerkundung | GIS & RS Group
Geographisches Institut | Institute of Geography
Universität zu Köln | University of Cologne
Tel.: +49 (0)221 470 6234
http://www.geographie.uni-koeln.de/willmes-christian.695.en.html
http://www.sfb806.de
http://crc806db.uni-koeln.de
Type: text/x-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151110/0c15cf76/attachment-0002.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151110/0c15cf76/attachment-0003.bin>
More information about the geonode-users
