[GeoNode-users] map latitude longitude from mouse position and xml
Stefan Steiniger
sstein at geo.uzh.ch
Tue Nov 10 11:22:30 PST 2015
perhaps you should rather look at using Leaflet : http://leafletjs.com/
if you just want to publish this radar position info alone and not other
data.
You have to convert the xml to a shapfile which can be load by GeoNode -
except that your XML is a "kml", then you can use it straight. Perhaps
you can do the conversion with GDAL? Or convert your xml to csv before?
best,
stefan
Am 10.11.15 um 05:11 schrieb akaki ratiani:
> 1)I am interesting, does Geonode support map latitude longitude when I
> moving cursor position.
> If geonode does not have this function, we will be glad if the stuff can
> add this future. That would be great update.
> 2) I have xml file which shows radars position movements (in xml file
> is - latitude, longitude coordinates that are changing every 1 minute).
> I’d like to add this file like a layer on map ,which will display our
> radars. I do not know how to do this, Can you help me in this item?
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
