[GeoNode-users] projects managing in geonode
Simone Dalmasso simone.dalmasso at gmail.com
Thu Nov 12 06:57:29 PST 2015
Hi Eugenio,
you may want to take a look at the geosites contrib app, docs are there as
well https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites
For the templates I suggest you to look over the django guide.
ciao
2015-11-12 15:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi all,
> after a bit long time to adjust a version of geonode on my production
> server, now it's running.
> However before using it I need to understand what is the best way, let's
> say even the philosophy, to manage different projects
> which can possibly share information.
> What I understand is that I can use a single istance of geonode for all my
> projects, but I need to create different portals which however
> point to the same spatial db and geoserver for the spatial data
> (indicating different datastore in each local_setting.py but different db
> to store the django tables. Is that correct?
> Over the tutorial:
> http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/theme_admin.html#customize-theme-admin
> I wonder if there is some other guide or reference to understand more
> deeply how to work with the template.
> Thank you
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151112/50faa403/attachment.html>
More information about the geonode-users mailing list
