[GeoNode-users] projects managing in geonode
Simone Dalmasso simone.dalmasso at gmail.com
Wed Nov 18 05:45:30 PST 2015
Hi Eugenio,
almost all correct but you should not modify the pre and post settings.
Just the local_settings within each new__site folder.
Geoserver and the db are the normal geonode one, there's only one geoserver
and one db for all the sites.
2015-11-18 14:16 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> thank you again for your answer. I take a look at the documentation page,
> however I need some clarification.
> Here below some doubts on how to organize the sites and hence how to
> configure geonode:
> Have I to configure a principle site from which all the others I will
> create will depend?
> or I can create many stand alone sites?
> Currently I would spread three different sites.
> I understand I should create three virtual host (in apache in my case)
> linked to three different folder specially prepared in
> geonode/contrib/geocities. That's means in each virtualhost I need to
> refer the aliases, WSGIScript alias (wsgi.py) and static folders to each
> specific
> sites folder.
> To add the sities folder I have to run:
> python manage.py addsite site3 site3.example.com
> Within the site directory, in local_setting.py, I have only to set up the SITEURL and of course I can customize the template.
> Then I need to work on pre/post_settings doesn't it?
> Could you please explain me better how and where to set up geoserver and db?
> Afterword to customize the look and feel of each site I need to work on templates dir in each site dir.
> Thanks for any hints..
> E.
> From: simone.dalmasso at gmail.com
> Date: Thu, 12 Nov 2015 15:57:29 +0100
> Subject: Re: [GeoNode-users] projects managing in geonode
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> Hi Eugenio,
> you may want to take a look at the geosites contrib app, docs are there as
> well
> https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites.
> For the templates I suggest you to look over the django guide.
> ciao
> 2015-11-12 15:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi all,
> after a bit long time to adjust a version of geonode on my production
> server, now it's running.
> However before using it I need to understand what is the best way, let's
> say even the philosophy, to manage different projects
> which can possibly share information.
> What I understand is that I can use a single istance of geonode for all my
> projects, but I need to create different portals which however
> point to the same spatial db and geoserver for the spatial data
> (indicating different datastore in each local_setting.py but different db
> to store the django tables. Is that correct?
> Over the tutorial:
> http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/theme_admin.html#customize-theme-admin
> I wonder if there is some other guide or reference to understand more
> deeply how to work with the template.
> Thank you
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151118/809c0ff4/attachment.html>
More information about the geonode-users mailing list
