[GeoNode-users] projects managing in geonode
Eugenio Trumpy
frippe12573 at hotmail.com
Wed Nov 18 07:47:47 PST 2015
Hi Simone,
just tried the simple command:
python manage.py addsite mysite misite.mydomain
I got
Unknown command: 'addsite'
Type 'manage.py help' for usage.
Maybe I need to point to some specific folder...
E.
Date: Wed, 18 Nov 2015 14:45:30 +0100
Subject: Re: [GeoNode-users] projects managing in geonode
To: frippe12573 at hotmail.com
CC: geonode-users at lists.osgeo.org
Hi Eugenio,
almost all correct but you should not modify the pre and post settings. Just the local_settings within each new__site folder.Geoserver and the db are the normal geonode one, there's only one geoserver and one db for all the sites.
2015-11-18 14:16 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi Simone,
thank you again for your answer. I take a look at the documentation page, however I need some clarification.
Here below some doubts on how to organize the sites and hence how to configure geonode:
Have I to configure a principle site from which all the others I will create will depend?
or I can create many stand alone sites?
Currently I would spread three different sites.
I understand I should create three virtual host (in apache in my case) linked to three different folder specially prepared in
geonode/contrib/geocities. That's means in each virtualhost I need to refer the aliases, WSGIScript alias (wsgi.py) and static folders to each specific
sites folder.
To add the sities folder I have to run:
python manage.py addsite site3 site3.example.com
Within the site directory, in local_setting.py, I have only to set up the SITEURL and of course I can customize the template.
Then I need to work on pre/post_settings doesn't it?
Could you please explain me better how and where to set up geoserver and db?
Afterword to customize the look and feel of each site I need to work on templates dir in each site dir.
Thanks for any hints..
E.
Date: Thu, 12 Nov 2015 15:57:29 +0100
Hi Eugenio,you may want to take a look at the geosites contrib app, docs are there as well https://github.com/GeoNode/geonode/tree/master/geonode/contrib/geosites.
For the templates I suggest you to look over the django guide.
ciao
2015-11-12 15:53 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
Hi all,
after a bit long time to adjust a version of geonode on my production server, now it's running.
However before using it I need to understand what is the best way, let's say even the philosophy, to manage different projects
which can possibly share information.
What I understand is that I can use a single istance of geonode for all my projects, but I need to create different portals which however
point to the same spatial db and geoserver for the spatial data (indicating different datastore in each local_setting.py but different db to store the django tables. Is that correct?
Over the tutorial: http://docs.geonode.org/en/latest/tutorials/admin/customize_admin/theme_admin.html#customize-theme-admin
I wonder if there is some other guide or reference to understand more deeply how to work with the template.
Thank you
Eugenio
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151118/6cc63539/attachment-0001.html>
More information about the geonode-users
