[GeoNode-users] GeoNode/GeoServer update issue
Francesco Marigliano f.marigliano.it at ieee.org
Mon Nov 23 01:20:57 PST 2015
Just changed baseUrl from/http://localhost// to
/http://mygeonode.mysite.it, /after apache//restart never seems to change
Il 23/11/2015 10:16, Simone Dalmasso ha scritto:
> Ops sorry, I gave you wrong information :)
> the file is data/security/auth/geonodeAuthProvider/config.xml
> 2015-11-23 10:12 GMT+01:00 Francesco Marigliano
> <f.marigliano.it at ieee.org <mailto:f.marigliano.it at ieee.org>>:
>     Il 23/11/2015 10:04, Simone Dalmasso ha scritto:
>>     Hi Francesco, seems a communication issue between geoserver and
>>     geonode. Can you take a look at the geoserver logs?
>     Here you are
>     at
>     org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>         at
>     org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>         at
>     org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
>         at
>     java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>         at
>     java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>         at java.lang.Thread.run(Thread.java:745)
>     Caused by: java.io.IOException: HTTPClient::sendGET: GeoNode
>     communication failed, status report is: 404, Not Found,
>     http://localhost/layers/acls
>         at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:95)
>         at
>     org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>         at
>     org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>         at
>     org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
>>     in case chack that /he WEB-INF/web.xml file of geoserver points
>>     to the correct geonode address.
>     Did you mean "PROXY_BASE_URL" field?
>>     2015-11-23 9:48 GMT+01:00 Francesco Marigliano
>>         Hi all,
>>         I recently updated GeoNode to /2.4c4, /after that if I'm not
>>         logged into GeoServer I can't see any layer in GeoExplorer.
>>         Just checked /local_settings.py /it seems to be everything ok.
>>         Avast logo <https://www.avast.com/antivirus>
>>         Questa e-mail è stata controllata per individuare virus con
>>         Avast antivirus.
>>         www.avast.com <https://www.avast.com/antivirus>
>>         _______________________________________________
>>         geonode-users mailing list
>>         geonode-users at lists.osgeo.org
>>         <mailto:geonode-users at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/geonode-users
>>     Simone
>     Questa e-mail è stata controllata per individuare virus con Avast
>     antivirus.
> Simone
Questa e-mail è stata controllata per individuare virus con Avast antivirus.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/b4156c46/attachment.html>
More information about the geonode-users mailing list
