[GeoNode-users] GeoNode/GeoServer update issue
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Nov 23 01:24:19 PST 2015
Ok, consider that the communication between geoserver and geonode is
"internal" so if geonode and geoserver are on the same server and geonode
responds to the root of the server address "/" the localhost is fine
because for geoserver geonode is on localhost. But if your server address
is *mysite.it <http://mysite.it>* and geonode responds to
*mygeonode.mysite.*it then the change you have done is fine.
To apply the fixes you have to restart tomcat though as apache only deals
with the geonode code.
2015-11-23 10:20 GMT+01:00 Francesco Marigliano <f.marigliano.it at ieee.org>:
> Just changed baseUrl from* http://localhost/ <http://localhost/>* to *http://mygeonode.mysite.it
> <http://mygeonode.mysite.it>, *after apache restart never seems to change
> Il 23/11/2015 10:16, Simone Dalmasso ha scritto:
> Ops sorry, I gave you wrong information :)
> the file is data/security/auth/geonodeAuthProvider/config.xml
> 2015-11-23 10:12 GMT+01:00 Francesco Marigliano <f.marigliano.it at ieee.org>
>> Il 23/11/2015 10:04, Simone Dalmasso ha scritto:
>> Hi Francesco, seems a communication issue between geoserver and geonode.
>> Can you take a look at the geoserver logs?
>> Here you are
>> at
>> org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1041)
>> at
>> org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:607)
>> at
>> org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:313)
>> at
>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>> at
>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>> at java.lang.Thread.run(Thread.java:745)
>> Caused by: java.io.IOException: HTTPClient::sendGET: GeoNode
>> communication failed, status report is: 404, Not Found,
>> http://localhost/layers/acls
>> at org.geonode.security.HTTPClient.sendGET(HTTPClient.java:95)
>> at
>> org.geonode.security.DefaultSecurityClient.authenticate(DefaultSecurityClient.java:185)
>> at
>> org.geonode.security.DefaultSecurityClient.authenticateCookie(DefaultSecurityClient.java:116)
>> at
>> org.geonode.security.GeoNodeAuthenticationProvider.authenticate(GeoNodeAuthenticationProvider.java:66)
>> in case chack that /he WEB-INF/web.xml file of geoserver points to the
>> correct geonode address.
>> Did you mean "PROXY_BASE_URL" field?
>> 2015-11-23 9:48 GMT+01:00 Francesco Marigliano <
>> <f.marigliano.it at ieee.org>f.marigliano.it at ieee.org>:
>>> Hi all,
>>> I recently updated GeoNode to *2.4c4, *after that if I'm not logged
>>> into GeoServer I can't see any layer in GeoExplorer.
>>> Just checked *local_settings.py *it seems to be everything ok.
>>> [image: Avast logo] <https://www.avast.com/antivirus>
>>> Questa e-mail è stata controllata per individuare virus con Avast
>>> antivirus.
>>> www.avast.com <https://www.avast.com/antivirus>
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
>> antivirus.
> Simone
> antivirus.
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151123/2eba081a/attachment-0001.html>
More information about the geonode-users
