[GeoNode-users] GeoNode Upgrade
David Alda Fernandez de Lezea
dalda at hazi.eus
Sun Nov 29 22:46:37 PST 2015
Thank you all. I knew the migration of GeoServer's data directory was as easy as that. For GeoNode I'll think about the pros and cons.
Thank you very much.
Regards,
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
-----Mensaje original-----
De: Paolo Corti [mailto:pcorti at gmail.com]
Enviado el: martes, 24 de noviembre de 2015 19:42
Para: Simone Dalmasso
CC: David Alda Fernandez de Lezea; geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] GeoNode Upgrade
Hi
read the comments in this issue:
https://github.com/GeoNode/geonode/issues/2067
then you can then try to use this branch, where there are the migration scripts:
https://github.com/capooti/geonode/blob/migration_from20_to_24/scripts/migrations/migrate20to24/index.rst
they worked successfully already for 2/3 organizations using GeoNode
regards
p
On Tue, Nov 24, 2015 at 2:21 AM, Simone Dalmasso <simone.dalmasso at gmail.com> wrote:
> Hi David,
> the migrations are not automatic and it's not possible to install the
> 2.4 just on top of the 2.0.1 due to the big amount of changes
> happened. There are manual migrations that you can do though, they
> have been used successfully some times. I'm cc.ing @capooti for more details.
> Ciao
> 2015-11-24 8:02 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
>> Hi,
>> Congrats to the developers team!! I was looking forward to
>> downloading the new release! By the way, how can I upgrade from
>> 2.0.1 to 2.4 without losing all my GeoServer and User/permission data?
>> Thanks in advance.
>> Regards,
>> Agur bero bat,
>> T 945 003 240 - M 627 923 170 - F 945 003 290 Hazi | Granja Modelo de
>> Arkaute s/n | 01192 Arkaute - Araba
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
