[GeoNode-users] import SHP
Paolo Corti pcorti at gmail.com
Fri Oct 2 05:17:21 PDT 2015
On Fri, Oct 2, 2015 at 1:25 PM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> Hi Paolo,
> unfortunately I still have problem on import shp file.
> As I said before the /uploaded is owned by www-data (even same group),
> also geonode installation has the same credential (www-data:www-data 755).
> Geonode directory is inside my data dir, owned by me (eugenio:eugenio 755).
> The user eugenio belongs to www-data group.
> Is that config right?
> I think my problem could be related even to geoserver (the one I set
> dedicated to geonode),
> as by geonode I can see the new layer, but I cannot visualize it on the map.
> Can you give me some hints?
Hi Eugenio
I think that unluckily your configuration is messed up.
Could you try to reinstall GeoNode, and only after it is working add
on top of it the other GeoServer?
cheers
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
