[GeoNode-users] import SHP
Eugenio Trumpy
frippe12573 at hotmail.com
Fri Oct 2 04:25:32 PDT 2015
Hi Paolo,
unfortunately I still have problem on import shp file.
As I said before the /uploaded is owned by www-data (even same group),
also geonode installation has the same credential (www-data:www-data 755).
Geonode directory is inside my data dir, owned by me (eugenio:eugenio 755).
The user eugenio belongs to www-data group.
Is that config right?
I think my problem could be related even to geoserver (the one I set dedicated to geonode),
as by geonode I can see the new layer, but I cannot visualize it on the map.
Can you give me some hints?
Thanks
Eugenio
> From: pcorti at gmail.com
> Date: Wed, 30 Sep 2015 17:32:39 +0200
> Subject: Re: [GeoNode-users] import SHP
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> sorry, you need to make sure that also the user running the
> updatelayers command has write permission on that directory.
> p
> On Wed, Sep 30, 2015 at 5:14 PM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> > Hi,
> > /uploaded/ directory is owned by www-data (same group), and has 755 grants.
> > I checked inside and I saw the shp file uploaded before.
> > MEDIA_ROOT in settings.py is:
> > MEDIA_ROOT = os.path.join(PROJECT_ROOT, "uploaded")
> > whereas
> > MEDIA_URL = "uploaded"
> > Even geonode directory has the same credentials.
> > E.
> >> Date: Wed, 30 Sep 2015 16:55:25 +0200
> >> On Wed, Sep 30, 2015 at 4:05 PM, Eugenio Trumpy <frippe12573 at hotmail.com>
> >> wrote:
> >> > Hi Paolo,
> >> > I did what you suggest.
> >> > The shp file has been uploaded correctly in the geoserver,
> >> > however I got errors on updatelayers, as follow:
> >> > $ python manage.py updatelayers
> >> > Stopping process because --ignore-errors was not set and an error was
> >> > found.
> >> > Traceback (most recent call last):
> >> > File "manage.py", line 28, in <module>
> >> > execute_from_command_line(sys.argv)
> >> > File
> >> > "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> >> > line 399, in execute_from_command_line
> >> > utility.execute()
> >> > File
> >> > line 392, in execute
> >> > self.fetch_command(subcommand).run_from_argv(self.argv)
> >> > File
> >> > "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> >> > line 242, in run_from_argv
> >> > self.execute(*args, **options.__dict__)
> >> > File
> >> > line 285, in execute
> >> > output = self.handle(*args, **options)
> >> > File
> >> > "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py",
> >> > line
> >> > 108, in handle
> >> > remove_deleted=remove_deleted)
> >> > File "/dati/geonode/geonode/geoserver/helpers.py", line 445, in gs_slurp
> >> > "bbox_y1": Decimal(resource.latlon_bbox[3])
> >> > File
> >> > "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py",
> >> > line 154, in get_or_create
> >> > return self.get_queryset().get_or_create(**kwargs)
> >> > File
> >> > "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py",
> >> > line 341, in get_or_create
> >> > return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> >> > File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> >> > line 383, in get_or_create
> >> > obj.save(force_insert=True, using=self.db)
> >> > File
> >> > "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
> >> > line 90, in save
> >> > return super(PolymorphicModel, self).save(*args, **kwargs)
> >> > File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
> >> > line 545, in save
> >> > force_update=force_update, update_fields=update_fields)
> >> > line 582, in save_base
> >> > update_fields=update_fields, raw=raw, using=using)
> >> > File
> >> > "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py",
> >> > line
> >> > 185, in send
> >> > response = receiver(signal=self, sender=sender, **named)
> >> > File "/dati/geonode/geonode/geoserver/signals.py", line 394, in
> >> > geoserver_post_save
> >> > create_thumbnail(instance, thumbnail_remote_url, thumbnail_create_url,
> >> > ogc_client=http_client)
> >> > File "/dati/geonode/geonode/layers/utils.py", line 676, in
> >> > create_thumbnail
> >> > instance.save_thumbnail(filename, image=image)
> >> > File "/dati/geonode/geonode/base/models.py", line 564, in save_thumbnail
> >> > with open(os.path.join(upload_path, filename), 'wb') as f:
> >> > Exception: ('Failed to process reg2001_s_wgs84utm33', IOError(13,
> >> > 'Permission denied'))
> >> > From the last line, I guess, my problem is on permissions.
> >> > Mybey something is missing on my config files....
> >> > Where in particular?
> >> > E.
> >> make sure your web server has permission to write to the media
> >> directory where the thumbnails are generated (set in MEDIA_ROOT in the
> >> GeoNode settings file)
> >> p
> >> Paolo Corti
> >> Geospatial software developer
> >> web: http://www.paolocorti.net
> >> twitter: @capooti
> >> skype: capooti
> Paolo Corti
> twitter: @capooti
> skype: capooti
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151002/f3a3fef0/attachment.html>
More information about the geonode-users
