[GeoNode-users] segmentation fault while I save a map
Eugenio Trumpy
frippe12573 at hotmail.com
Wed Oct 28 09:17:53 PDT 2015
Dear all,
unfortunately I am here again with the same problem I had 2 or 3 weeks ago.
The main problem is when I save a map I got a 500 server error, which is referred to the following line in the apache2 error log:
[Wed Oct 28 16:50:10.835817 2015] [core:notice] [pid 18289] AH00052: child pid 18734 exit signal Segmentation fault (11)
Actually the map is not saved, however it appears in the map list, without the thumb.
If I click on such map I have the page error:
IndexError at /maps/6
list index out of range
Request Method:
GET
Request URL:
http://my_server_name/maps/6
Django Version:
1.6.11
Exception Type:
IndexError
Exception Value:
Exception Location:
/dati/geonode/geonode/utils.py in viewer_json, line 265
Python Executable:
/usr/bin/python
Python Version:
2.7.6
Python Path:
['/usr/local/lib/python2.7/dist-packages/pip-7.1.2-py2.7.egg',
'/dati/geonode',
'/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/pymodules/python2.7',
'/home/eugenio']
Server time:
Wed, 28 Oct 2015 10:50:54 -0500
As you suggested I tested an installation on vagrant box (ubuntu server 14.04, apache2.4.7, tomcat7 and postgresql9.3, all installed as packages). This test works fine, I had not the error on saving maps.
So I updated my server, now I have:
ubuntu 14.04, apache 2.4.7, postgresql9.3+postgis2.1 installed as packages and tomcat7 installed manually.
After the syncdb problem (solved) I installed geonode.
Everything seems to work fine: I'm able to upload layers, I'm able to create the maps even choosing the layers uploaded, but I got again the same ewrror on saving maps.
Here I attached the local_setting.py file and the apache2 virtualhost config.
During the configuration I also follow the instructions regarding 'Configuring GeoServer' which is in the end, inserting the context param GEONODE_BASE_URL and the URL (my_server_name) in web.xml and I put my_server_name in the config.xml as indicated.
Actually, after many many attempt I'm giving up hope...
thanks for the possible hints
Eugenio
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151028/8d22e566/attachment-0001.html>
Type: text/x-script.phyton
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151028/8d22e566/attachment-0001.bin>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151028/8d22e566/attachment-0001.ksh>
More information about the geonode-users
