[GeoNode-users] segmentation fault while I save a map
Ariel Nunez ingenieroariel at gmail.com
Wed Oct 28 09:33:40 PDT 2015
Eugenio,
Run the site with manage.py runserver 0.0.0.0:8000 (and fixe ip
accordingly) and then try to save.
This time you would get a traceback on the terminal that mae be easier to
debug.
-a
On Wed, Oct 28, 2015 at 11:17 AM, Eugenio Trumpy <frippe12573 at hotmail.com>
wrote:
> Dear all,
> unfortunately I am here again with the same problem I had 2 or 3 weeks ago.
> The main problem is when I save a map I got a 500 server error, which is
> referred to the following line in the apache2 error log:
> [Wed Oct 28 16:50:10.835817 2015] [core:notice] [pid 18289] AH00052: child
> pid 18734 exit signal Segmentation fault (11)
> Actually the map is not saved, however it appears in the map list, without
> the thumb.
> If I click on such map I have the page error:
> IndexError at /maps/6
> list index out of range
> Request Method: GET Request URL: http://my_server_name/maps/6 Django
> Version: 1.6.11 Exception Type: IndexError Exception Value:
> Exception Location: /dati/geonode/geonode/utils.py in viewer_json, line
> 265 Python Executable: /usr/bin/python Python Version: 2.7.6 Python Path:
> ['/usr/local/lib/python2.7/dist-packages/pip-7.1.2-py2.7.egg',
>  '/dati/geonode',
>  '/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-x86_64-linux-gnu',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PILcompat',
>  '/usr/lib/pymodules/python2.7',
>  '/home/eugenio']
> Server time: Wed, 28 Oct 2015 10:50:54 -0500
> As you suggested I tested an installation on vagrant box (ubuntu server
> 14.04, apache2.4.7, tomcat7 and postgresql9.3, all installed as packages).
> This test works fine, I had not the error on saving maps.
> So I updated my server, now I have:
> ubuntu 14.04, apache 2.4.7,  postgresql9.3+postgis2.1 installed as
> packages and tomcat7 installed manually.
> After the syncdb problem (solved) I installed geonode.
> Everything seems to work fine: I'm able to upload layers, I'm able to
> create the maps even choosing the layers uploaded, but I got again the same
> ewrror on saving maps.
> Here I attached the local_setting.py file and the apache2 virtualhost
> config.
> During the configuration I also follow the instructions regarding
> 'Configuring GeoServer' which is in the end, inserting the context param
> GEONODE_BASE_URL and the URL (my_server_name) in web.xml and I put
> my_server_name in the config.xml as indicated.
> Actually, after many many attempt I'm giving up hope...
> thanks for the possible hints
> Eugenio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151028/1a73f71d/attachment.html>
More information about the geonode-users mailing list
