[GeoNode-users] segmentation fault while I save a map
Eugenio Trumpy
frippe12573 at hotmail.com
Thu Oct 29 01:38:25 PDT 2015
Hi Ariel,
actually I sort out better the configuration file, and now I tested your command:
python manage.py runserver my_server_name:8000
on click on one map listed I got the following error lines:
File "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line 112, in get_response
response = wrapped_callback(request, *callback_args, **callback_kwargs)
File "/dati/geonode/geonode/maps/views.py", line 112, in map_detail
config = map_obj.viewer_json(request.user)
File "/dati/geonode/geonode/utils.py", line 265, in viewer_json
str(int(keys[-1]) + 1)] = settings.MAP_BASELAYERS[0]['source']
IndexError: list index out of range
[29/Oct/2015 03:21:18] "GET /maps/8 HTTP/1.1" 500 139436
Regarding the saving map operation currently I'm not able to test the operation in this mode, since I have a problem on login to django,
I have:
[29/Oct/2015 03:36:06] "POST /account/ajax_login HTTP/1.1" 400 32
hints on that?
best
Eugenio
To: ingenieroariel at gmail.com
CC: geonode-users at lists.osgeo.org
Subject: RE: [GeoNode-users] segmentation fault while I save a map
Date: Wed, 28 Oct 2015 18:04:58 +0100
I run the command you suggested me:
Validating models...
0 errors found
October 28, 2015 - 12:03:02
Django version 1.6.11, using settings 'geonode.settings'
Starting development server at http://my_server_name:8000/
Quit the server with CONTROL-C.
then I tried to male the same operation, saving a new map, but I had not a traceback on the terminal.
E.
Date: Wed, 28 Oct 2015 11:33:40 -0500
Subject: Re: [GeoNode-users] segmentation fault while I save a map
To: frippe12573 at hotmail.com
Eugenio,
Run the site with manage.py runserver 0.0.0.0:8000 (and fixe ip accordingly) and then try to save.
This time you would get a traceback on the terminal that mae be easier to debug.
-a
On Wed, Oct 28, 2015 at 11:17 AM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
Dear all,
unfortunately I am here again with the same problem I had 2 or 3 weeks ago.
The main problem is when I save a map I got a 500 server error, which is referred to the following line in the apache2 error log:
[Wed Oct 28 16:50:10.835817 2015] [core:notice] [pid 18289] AH00052: child pid 18734 exit signal Segmentation fault (11)
Actually the map is not saved, however it appears in the map list, without the thumb.
If I click on such map I have the page error:
IndexError at /maps/6
Request Method:
GET
Request URL:
http://my_server_name/maps/6
Django Version:
1.6.11
Exception Type:
IndexError
Exception Value:
Exception Location:
/dati/geonode/geonode/utils.py in viewer_json, line 265
Python Executable:
/usr/bin/python
Python Version:
2.7.6
Python Path:
['/usr/local/lib/python2.7/dist-packages/pip-7.1.2-py2.7.egg',
'/dati/geonode',
'/usr/lib/python2.7',
'/usr/lib/python2.7/plat-x86_64-linux-gnu',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PILcompat',
'/usr/lib/pymodules/python2.7',
'/home/eugenio']
Server time:
Wed, 28 Oct 2015 10:50:54 -0500
As you suggested I tested an installation on vagrant box (ubuntu server 14.04, apache2.4.7, tomcat7 and postgresql9.3, all installed as packages). This test works fine, I had not the error on saving maps.
So I updated my server, now I have:
ubuntu 14.04, apache 2.4.7, postgresql9.3+postgis2.1 installed as packages and tomcat7 installed manually.
After the syncdb problem (solved) I installed geonode.
Everything seems to work fine: I'm able to upload layers, I'm able to create the maps even choosing the layers uploaded, but I got again the same ewrror on saving maps.
Here I attached the local_setting.py file and the apache2 virtualhost config.
During the configuration I also follow the instructions regarding 'Configuring GeoServer' which is in the end, inserting the context param GEONODE_BASE_URL and the URL (my_server_name) in web.xml and I put my_server_name in the config.xml as indicated.
Actually, after many many attempt I'm giving up hope...
thanks for the possible hints
Eugenio
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151029/f7237082/attachment.html>
More information about the geonode-users
