[GeoNode-users] segmentation fault while I save a map
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Oct 29 01:44:04 PDT 2015
Eugenio, now that you are running with the dev server you should use ipdb
to debug the content of MAP_BASELAYERS.
add "import ipdb; ipdb.set_trace()"
then do the operation that rises the error, the terminal will stop in that
point and you'll be able to inspect all the variables.
my suspect is that the settings are not correct somehow.
2015-10-29 9:38 GMT+01:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Ariel,
> actually I sort out better the configuration file, and now I tested your
> command:
> python manage.py runserver my_server_name:8000
> on click on one map listed I got the following error lines:
> Traceback (most recent call last):
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/handlers/base.py", line
> 112, in get_response
> response = wrapped_callback(request, *callback_args, **callback_kwargs)
> File "/dati/geonode/geonode/maps/views.py", line 112, in map_detail
> config = map_obj.viewer_json(request.user)
> File "/dati/geonode/geonode/utils.py", line 265, in viewer_json
> str(int(keys[-1]) + 1)] = settings.MAP_BASELAYERS[0]['source']
> IndexError: list index out of range
> [29/Oct/2015 03:21:18] "GET /maps/8 HTTP/1.1" 500 139436
> Regarding the saving map operation currently I'm not able to test the
> operation in this mode, since I have a problem on login to django,
> I have:
> [29/Oct/2015 03:36:06] "POST /account/ajax_login HTTP/1.1" 400 32
> hints on that?
> best
> Eugenio
> From: frippe12573 at hotmail.com
> To: ingenieroariel at gmail.com
> CC: geonode-users at lists.osgeo.org
> Subject: RE: [GeoNode-users] segmentation fault while I save a map
> Date: Wed, 28 Oct 2015 18:04:58 +0100
> Hi,
> I run the command you suggested me:
> Validating models...
> 0 errors found
> October 28, 2015 - 12:03:02
> Django version 1.6.11, using settings 'geonode.settings'
> Starting development server at http://my_server_name:8000/
> Quit the server with CONTROL-C.
> then I tried to male the same operation, saving a new map, but I had not a
> traceback on the terminal.
> E.
> From: ingenieroariel at gmail.com
> Date: Wed, 28 Oct 2015 11:33:40 -0500
> Subject: Re: [GeoNode-users] segmentation fault while I save a map
> To: frippe12573 at hotmail.com
> Eugenio,
> Run the site with manage.py runserver 0.0.0.0:8000 (and fixe ip
> accordingly) and then try to save.
> This time you would get a traceback on the terminal that mae be easier to
> debug.
> -a
> On Wed, Oct 28, 2015 at 11:17 AM, Eugenio Trumpy <frippe12573 at hotmail.com>
> wrote:
> Dear all,
> unfortunately I am here again with the same problem I had 2 or 3 weeks ago.
> The main problem is when I save a map I got a 500 server error, which is
> referred to the following line in the apache2 error log:
> [Wed Oct 28 16:50:10.835817 2015] [core:notice] [pid 18289] AH00052: child
> pid 18734 exit signal Segmentation fault (11)
> Actually the map is not saved, however it appears in the map list, without
> the thumb.
> If I click on such map I have the page error:
> IndexError at /maps/6
> Request Method: GET Request URL: http://my_server_name/maps/6 Django
> Version: 1.6.11 Exception Type: IndexError Exception Value:
> Exception Location: /dati/geonode/geonode/utils.py in viewer_json, line
> 265 Python Executable: /usr/bin/python Python Version: 2.7.6 Python Path:
> ['/usr/local/lib/python2.7/dist-packages/pip-7.1.2-py2.7.egg',
> '/dati/geonode',
> '/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-x86_64-linux-gnu',
> '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PILcompat',
> '/usr/lib/pymodules/python2.7',
> '/home/eugenio']
> Server time: Wed, 28 Oct 2015 10:50:54 -0500
> As you suggested I tested an installation on vagrant box (ubuntu server
> 14.04, apache2.4.7, tomcat7 and postgresql9.3, all installed as packages).
> This test works fine, I had not the error on saving maps.
> So I updated my server, now I have:
> ubuntu 14.04, apache 2.4.7, postgresql9.3+postgis2.1 installed as
> packages and tomcat7 installed manually.
> After the syncdb problem (solved) I installed geonode.
> Everything seems to work fine: I'm able to upload layers, I'm able to
> create the maps even choosing the layers uploaded, but I got again the same
> ewrror on saving maps.
> Here I attached the local_setting.py file and the apache2 virtualhost
> config.
> During the configuration I also follow the instructions regarding
> 'Configuring GeoServer' which is in the end, inserting the context param
> GEONODE_BASE_URL and the URL (my_server_name) in web.xml and I put
> my_server_name in the config.xml as indicated.
> Actually, after many many attempt I'm giving up hope...
> thanks for the possible hints
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151029/8cde0106/attachment-0001.html>
More information about the geonode-users
