[GeoNode-users] QGIS GeoServer/PostGIS Tools missing Sextante?
Florian Hoedt gannebamm at gmail.com
Mon Sep 7 01:39:51 PDT 2015
Look here. This was my workflow to get geonode running in a virtual machine
on a win7 64bit OS. The postgis DB geonode / geoserver are using is
accessible through win7, too:
·         Install Oracle VM
·         Download ubuntu 14.04LTS 64bit image
·         Create VM
*Network Settings: *NAT, PortForwarding:  (1.Geonode , 2.PostgreSQL)
HostIP: 127.0.0.1 Port: 80
GuestIP: 10.0.2.15 Port: 80
HostIP: 127.0.0.1 Port: 543
*3 *GuestIP: 10.0.2.15 Port: 5432
·         Install Ubuntu - User: geonode ; password: YOURPASSWORD
·         Install VirtualBox Guest Additions
·         Restart VM and resize the screen
Open Terminal:
$ sudo add-apt-repository ppa:geonode/testing *## Proxy Errors, see below!*
$ sudo apt-get update
$ sudo apt-get install geonode
$ sudo geonode-updateip 127.0.0.1
$ geonode createsuperuser
username: admin
pass: YOURPASSWORD
·         Start geoserver admin (localhost/geoserver)
·         *Set Proxy-Base URL* to:
http://127.0.0.1/geoserver
·         *Edit /etc/postgresql/9.3/main/*
o   postgresql.conf
listen_addresses = '*' #adress postgres should listen to
o   pg_hba.conf
# IPv4 local connections:
host       all           all                        127.0.0.1/32         md5
host       all           all                           10.0.2.2/24
md5  #external access
*Edit /etc/geonode/local_settings.py *ALLOWED_HOSTS=['localhost',
'127.0.0.1', ]
PROXY_ALLOWED_HOSTS = ('localhost', '127.0.0.1')
*PROXY ERRORS:*
sudo update-ca-certificates
export http_proxy=http://<proxy>:<port>
export https_proxy=http://<proxy>:<port>
sudo *-E* add-apt-repository ppa:geonode/testing
On Mon, Sep 7, 2015 at 10:05 AM, gannebamm <gannebamm at gmail.com> wrote:
> Hi
> I used an oracle virtual box with Ubuntu 14lts and Nat networking to get
> geonode working.
> If you need help I could post my workflow. Just need to get to my notebook
> again :)
> Sent from mobile
> Hi
> geonode working.
> again :)
> Sent from mobile
> ---- Paras Talwar schrieb ----
> Hi,
> Can anyone know how to install Geonode in Windows 7????
> greetings,
> Paras
> On Thu, Sep 3, 2015 at 3:30 PM, Florian Hoedt <gannebamm at gmail.com> wrote:
>> Hi,
>> I can not find the GeoServer Tools which are shown in the Geonode docu:
>> http://geonode.readthedocs.org/en/latest/tutorials/users/processing/sextante.html
>> I am using QGIS 2.8 Wien.
>> Where are those tools? They seem to be quite handy for most common tasks!
>> greetings,
>> Florian
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150907/faf23729/attachment-0001.html>
More information about the geonode-users mailing list
