[GeoNode-users] problem to install geonode on a remote vm
Giuseppe Ricci peppepegasus at gmail.com
Wed Sep 23 07:02:41 PDT 2015
Hi guys,
I'm trying to install geonode on a virtual machine installed on Micrsoft
Azure server.
I followed this tutorial:
http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
but when i give this command:
sudo geonode-updateip localhost:4567
I receive this errors:
$  sudo geonode-updateip localhost:4567
Replacing SITEURL value with 'localhost:4567' in
/etc/geonode/local_settings.py ... done.
Adding entry for 'localhost:4567' in
/usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
found to the printing whitelist.
Adding localhost:4567 to ALLOWED_HOSTS in /etc/geonode/local_settings.py
... 'localhost:4567' already found in ALLOWED_HOSTS list.
 * Restarting web server
apache2
AH00558: apache2: Could not reliably determine the server's fully qualified
domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
suppress this message
[ OK ]
Finished processing 0 layers in 0.0 seconds.
0 Created layers
0 Updated layers
0 Failed layers
0.000000 seconds per layer
At the adress localhost:4567 I receive the message:
web page doesn't exist. ERR_CONNECTION_REFUSED.
Can some one to help me?
Thanks.
Dott. Giuseppe Ricci
Via B. Spaventa 6, Terlizzi
Cel. 340 3059772
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/34a1fd9a/attachment.html>
More information about the geonode-users mailing list
