[GeoNode-users] problem to install geonode on a remote vm
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Sep 23 07:06:17 PDT 2015
Hi Giuseppe,
I don't know about Azure but the connection refused error should be more
relate to the web server configuration rather than Geonode that would throw
a 5XX error series in case of errors or misconfigurations.
2015-09-23 16:02 GMT+02:00 Giuseppe Ricci <peppepegasus at gmail.com>:
> Hi guys,
> I'm trying to install geonode on a virtual machine installed on Micrsoft
> Azure server.
> I followed this tutorial:
> http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
> but when i give this command:
> sudo geonode-updateip localhost:4567
> I receive this errors:
> $ sudo geonode-updateip localhost:4567
> Replacing SITEURL value with 'localhost:4567' in
> /etc/geonode/local_settings.py ... done.
> Adding entry for 'localhost:4567' in
> /usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
> found to the printing whitelist.
> Adding localhost:4567 to ALLOWED_HOSTS in /etc/geonode/local_settings.py
> ... 'localhost:4567' already found in ALLOWED_HOSTS list.
> * Restarting web server
> apache2
> AH00558: apache2: Could not reliably determine the server's fully qualified
> domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
> suppress this message
> [ OK ]
> Finished processing 0 layers in 0.0 seconds.
> 0 Created layers
> 0 Updated layers
> 0 Failed layers
> 0.000000 seconds per layer
> At the adress localhost:4567 I receive the message:
> web page doesn't exist. ERR_CONNECTION_REFUSED.
> Can some one to help me?
> Thanks.
> Dott. Giuseppe Ricci
> Via B. Spaventa 6, Terlizzi
> Cel. 340 3059772
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/460afc23/attachment.html>
More information about the geonode-users
