[GeoNode-users] geonode-users Digest, Vol 8, Issue 14
Florian Hoedt florian.hoedt at hs-owl.de
Wed Sep 23 08:50:35 PDT 2015
Hello
Shouldn`t you use:
sudo geonode-updateip your_INTERNET_IP:4567
instead of:
sudo geonode-updateip localhost:4567
or
sudo geonode-updateip your_lan_ip:4567
??? I am a newcomer to Geonode, too, so...
do not forget to configure your geoserver to use the "outside" IP as proxy!
mit freundlichen Grüßen
Florian Hoedt
B.Sc. Florian Hoedt
Hochschule Ostwestfalen-Lippe / Campus Höxter
FB 9 Landschaftsarchitektur und Umweltplanung
An der Wilhelmshöhe 44
37671 Höxter
Tel.: 05271-687-7478
E-Mail: florian.hoedt at hs-owl.de
www.hs-owl.de/fb9
-----Ursprüngliche Nachricht-----
Von: geonode-users-bounces at lists.osgeo.org [mailto:geonode-users-bounces at lists.osgeo.org] Im Auftrag von geonode-users-request at lists.osgeo.org
Gesendet: Wednesday, September 23, 2015 5:13 PM
An: geonode-users at lists.osgeo.org
Betreff: geonode-users Digest, Vol 8, Issue 14
Send geonode-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
	http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
	geonode-users-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of geonode-users digest..."
Today's Topics:
   1. problem to install geonode on a remote vm (Giuseppe Ricci)
   2. Re: problem to install geonode on a remote vm (Simone Dalmasso)
   3. Re: problem to install geonode on a remote vm (Giuseppe Ricci)
   4. Re: problem to install geonode on a remote vm (Charles Coss?)
Message: 1
Date: Wed, 23 Sep 2015 16:02:41 +0200
To: geonode-users at lists.osgeo.org
Subject: [GeoNode-users] problem to install geonode on a remote vm
Message-ID:
	<CAB6LW8Y7k0P1mwgJcio7BPHHshs9bpk9hXhT5K20yVy_8GV-rg at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hi guys,
I'm trying to install geonode on a virtual machine installed on Micrsoft Azure server.
I followed this tutorial:
http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
but when i give this command:
I receive this errors:
$  sudo geonode-updateip localhost:4567
Replacing SITEURL value with 'localhost:4567' in /etc/geonode/local_settings.py ... done.
Adding entry for 'localhost:4567' in
/usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already found to the printing whitelist.
Adding localhost:4567 to ALLOWED_HOSTS in /etc/geonode/local_settings.py ... 'localhost:4567' already found in ALLOWED_HOSTS list.
 * Restarting web server
apache2
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 100.73.20.46. Set the 'ServerName' directive globally to suppress this message
[ OK ]
Finished processing 0 layers in 0.0 seconds.
0 Created layers
0 Updated layers
0 Failed layers
0.000000 seconds per layer
At the adress localhost:4567 I receive the message:
web page doesn't exist. ERR_CONNECTION_REFUSED.
Can some one to help me?
Thanks.
Dott. Giuseppe Ricci
Via B. Spaventa 6, Terlizzi
Cel. 340 3059772
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/34a1fd9a/attachment-0001.html>
Message: 2
Date: Wed, 23 Sep 2015 16:06:17 +0200
From: Simone Dalmasso <simone.dalmasso at gmail.com>
To: Giuseppe Ricci <peppepegasus at gmail.com>
Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] problem to install geonode on a remote vm
Message-ID:
	<CAAHAC+dszrJgBcuBRniLMMc2EoY5auYw48H4NHed0MCWYaQVQA at mail.gmail.com>
Hi Giuseppe,
I don't know about Azure but the connection refused error should be more relate to the web server configuration rather than Geonode that would throw a 5XX error series in case of errors or misconfigurations.
2015-09-23 16:02 GMT+02:00 Giuseppe Ricci <peppepegasus at gmail.com>:
> Hi guys,
> $  sudo geonode-updateip localhost:4567 Replacing SITEURL value with
> apache2
> [ OK ]
> 0 Created layers
> 0 Updated layers
> 0 Failed layers
> Thanks.
> Cel. 340 3059772
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/460afc23/attachment-0001.html>
Message: 3
Date: Wed, 23 Sep 2015 17:00:25 +0200
To: Simone Dalmasso <simone.dalmasso at gmail.com>
Message-ID:
	<CAB6LW8bPyQRoLGzuDtw90Lg96WULovVmycO_GFsQH1e=j1=TJQ at mail.gmail.com>
I have a question: the mentioned tutorial is to install in local geonode..if I want to install on a remote server there is a tutorial?
Thanks
Cel. 340 3059772
2015-09-23 16:06 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Giuseppe,
>> Hi guys,
>> apache2
>> [ OK ]
>> 0 Created layers
>> 0 Updated layers
>> 0 Failed layers
>> Thanks.
>> Cel. 340 3059772
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/ccdb61a2/attachment-0001.html>
Message: 4
Date: Wed, 23 Sep 2015 11:12:35 -0400
Cc: geonode-users <geonode-users at lists.osgeo.org>
Message-ID:
	<CABtoULhoPDY=ew+vkF7=XYmbViEMNsB0OsLiP-W7m_c6PWt9QA at mail.gmail.com>
Hi, we have an issue running the latest GeoNode on a virtual server.  From our LAN we access via a 192.168 ip address.  Externally we access via
another, real ip address.   But when we access externally the image
thumbnails and layers fail to show because they are referencing the 192.168
address.   Looking through the database ("maps_mapsnapshot" table) I found
that GeoNode had ingested the 192.168 address and was generating links from
there.   I concluded that having 2 ips (one internal, one external) must
not be possible given what was happening.  I don't see any way around it and we're re-configuring our systems to use a single IP as a result.
Thanks,
Charles Coss?
Guyana Forestry Commission
Georgetown, Guyana
On Wed, Sep 23, 2015 at 10:02 AM, Giuseppe Ricci <peppepegasus at gmail.com>
wrote:
> Hi guys,
> apache2
> [ OK ]
> 0 Created layers
> 0 Updated layers
> 0 Failed layers
> Thanks.
> Cel. 340 3059772
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150923/c86b59e9/attachment.html>
End of geonode-users Digest, Vol 8, Issue 14
More information about the geonode-users mailing list
