[GeoNode-users] problem to install geonode on a remote vm
Giuseppe Ricci peppepegasus at gmail.com
Thu Sep 24 03:04:13 PDT 2015
As suggested Ariel I set in the file /etc/geonode/local_settings.py in this
manner:
SITEURL = 'http://domain.cloudapp.net:4567/'
but I have the same problem..is it not correct as ip adress configuration?
g
Dott. Giuseppe Ricci
Via B. Spaventa 6, Terlizzi
Cel. 340 3059772
2015-09-23 20:50 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
> I totally concur.
> On Wed, Sep 23, 2015 at 2:44 PM, Ariel Nunez <ingenieroariel at gmail.com>
> wrote:
>> In your intranet, you can set the domain name for testing in the router
>> configuration.
>> On your developer machine and for trusted users you can edit the
>> /etc/hostnames (or the windows equivalent) and test it too.
>> I usually do that and it works fine, let's you get early feedback on the
>> name from trusted people and generally results in a faster agreement on
>> what the DNS should be.
>> -a
>> On Wed, Sep 23, 2015 at 12:47 PM, Charles Cossé <ccosse at gmail.com> wrote:
>>> Ahh yes that's a good idea ... we don't have a domain yet so we've just
>>> been using numbers, but thank you for that suggestion.  We will have to
>>> pause and consider that.
>>> -C
>>> On Wed, Sep 23, 2015 at 1:07 PM, Ariel Nunez <ingenieroariel at gmail.com>
>>> wrote:
>>>> You best bet is to set a domain name that resolves both locally and
>>>> externally to the right IP address.
>>>> GeoNode stores the full URL internally in a few places, the main reason
>>>> is historical because geonetwork and geoserver need fully qualified urls
>>>> instead of relative ones. It would be interested to have someone
>>>> investigate how to remove that restriction from GeoNode.
>>>> -a
>>>> On Wed, Sep 23, 2015 at 10:12 AM, Charles Cossé <ccosse at gmail.com>
>>>> wrote:
>>>>> Hi, we have an issue running the latest GeoNode on a virtual server.
>>>>> From our LAN we access via a 192.168 ip address.  Externally we access via
>>>>> another, real ip address.   But when we access externally the image
>>>>> thumbnails and layers fail to show because they are referencing the 192.168
>>>>> address.   Looking through the database ("maps_mapsnapshot" table) I found
>>>>> that GeoNode had ingested the 192.168 address and was generating links from
>>>>> there.   I concluded that having 2 ips (one internal, one external) must
>>>>> not be possible given what was happening.  I don't see any way around it
>>>>> and we're re-configuring our systems to use a single IP as a result.
>>>>> Thanks,
>>>>> Charles Cossé
>>>>> Guyana Forestry Commission
>>>>> Georgetown, Guyana
>>>>> On Wed, Sep 23, 2015 at 10:02 AM, Giuseppe Ricci <
>>>>> peppepegasus at gmail.com> wrote:
>>>>>> Hi guys,
>>>>>> I'm trying to install geonode on a virtual machine installed on
>>>>>> Micrsoft Azure server.
>>>>>> I followed this tutorial:
>>>>>> http://docs.geonode.org/en/master/tutorials/admin/prep/index.html
>>>>>> but when i give this command:
>>>>>> sudo geonode-updateip localhost:4567
>>>>>> I receive this errors:
>>>>>> $  sudo geonode-updateip localhost:4567
>>>>>> Replacing SITEURL value with 'localhost:4567' in
>>>>>> /etc/geonode/local_settings.py ... done.
>>>>>> Adding entry for 'localhost:4567' in
>>>>>> /usr/share/geoserver/data/printing/config.yaml ... 'localhost:4567' already
>>>>>> found to the printing whitelist.
>>>>>> Adding localhost:4567 to ALLOWED_HOSTS in
>>>>>> /etc/geonode/local_settings.py ... 'localhost:4567' already found in
>>>>>> ALLOWED_HOSTS list.
>>>>>>  * Restarting web server
>>>>>> apache2
>>>>>> AH00558: apache2: Could not reliably determine the server's fully qualified
>>>>>> domain name, using 100.73.20.46. Set the 'ServerName' directive globally to
>>>>>> suppress this message
>>>>>> [ OK ]
>>>>>> Finished processing 0 layers in 0.0 seconds.
>>>>>> 0 Created layers
>>>>>> 0 Updated layers
>>>>>> 0 Failed layers
>>>>>> 0.000000 seconds per layer
>>>>>> At the adress localhost:4567 I receive the message:
>>>>>> web page doesn't exist. ERR_CONNECTION_REFUSED.
>>>>>> Can some one to help me?
>>>>>> Thanks.
>>>>>> Cel. 340 3059772
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150924/d769bdaa/attachment-0001.html>
More information about the geonode-users mailing list
