[GeoNode-users] error on saving maps
Simone Dalmasso simone.dalmasso at gmail.com
Tue Sep 29 01:43:35 PDT 2015
That is fine,
actually the place originating the error could be here
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L904,
you can dig a bit there to see what's going wrong.
2015-09-29 10:35 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> settings.py has 0755 premisses, the user and group belonging to is www-data
> Is that correct?
> E.
> From: simone.dalmasso at gmail.com
> Date: Tue, 29 Sep 2015 10:20:26 +0200
> Subject: Re: error on saving maps
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> The error is that GeoNode can't read this list
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L605,
> properly.
> It may depend of an incorrect settings import.
> 2015-09-29 10:17 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> actually I didn't modify such file and/or MAP_BASELAYER.
> What do you mean, saying settings are not imported correctly?
> E.
> Date: Tue, 29 Sep 2015 10:10:15 +0200
> Eugenio, perhaps you modified the MAP_BASELAYERS from the settings?
> https://github.com/GeoNode/geonode/blob/master/geonode/utils.py#L266 or
> the settings are not imported correctly
> 2015-09-29 10:00 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear all,
> I just solved my problems on geoserver version provided by geonode.
> Now a new problem appears on saving maps.
> I have no errors on creating a map, when I save a new map I got an error,
> The server returned an error: 500 Internal Server Error
> so my apache2 error log havs:
> [Tue Sep 29 09:47:45 2015] [error] [client x.x.x.x] Premature end of
> script headers: wsgi.py, referer: http://my_server_name/maps/new
> [Tue Sep 29 09:47:45 2015] [notice] child pid 15764 exit signal
> Segmentation fault (11)
> Actually on maps page of geonode I see the new map, without title and
> thumbnail.
> If I click to view such map a page error appears:
> IndexError at /maps/89
> list index out of range
> Request Method: GET Request URL: http://my_server_name/maps/89 Django
> Version: 1.6.10 Exception Type: IndexError Exception Value:
> Exception Location: /dati/geonode/geonode/utils.py in viewer_json, line
> 266 Python Executable: /usr/bin/python Python Version: 2.7.3 Python Path:
> ['/dati/.venvs/geonode/lib/python2.7/site-packages',
>  '/usr/local/lib/python2.7/dist-packages/virtualenv-1.8.4-py2.7.egg',
>  '/usr/local/lib/python2.7/dist-packages/pip-1.2.1-py2.7.egg',
>  '/dati/geonode',
>  '/usr/lib/python2.7',
>  '/usr/lib/python2.7/plat-linux2',
>  '/usr/lib/python2.7/lib-tk',
>  '/usr/lib/python2.7/lib-old',
>  '/usr/lib/python2.7/lib-dynload',
>  '/usr/local/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages',
>  '/usr/lib/python2.7/dist-packages/PIL',
>  '/usr/lib/pymodules/python2.7',
>  '/var/www']
> Server time: Tue, 29 Sep 2015 09:59:48 +0200
> Any hints on this issue?
> Regards
> Eugenio
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150929/4c394c22/attachment.html>
More information about the geonode-users mailing list
