[GeoNode-users] import SHP
Paolo Corti
pcorti at gmail.com
Wed Sep 30 07:55:25 PDT 2015
On Wed, Sep 30, 2015 at 4:05 PM, Eugenio Trumpy <frippe12573 at hotmail.com> wrote:
> Hi Paolo,
> I did what you suggest.
> The shp file has been uploaded correctly in the geoserver,
> however I got errors on updatelayers, as follow:
> $ python manage.py updatelayers
> Stopping process because --ignore-errors was not set and an error was found.
> Traceback (most recent call last):
> File "manage.py", line 28, in <module>
> execute_from_command_line(sys.argv)
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/__init__.py",
> line 399, in execute_from_command_line
> utility.execute()
> File
> line 392, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File
> "/usr/local/lib/python2.7/dist-packages/django/core/management/base.py",
> line 242, in run_from_argv
> self.execute(*args, **options.__dict__)
> File
> line 285, in execute
> output = self.handle(*args, **options)
> File
> "/dati/geonode/geonode/geoserver/management/commands/updatelayers.py", line
> 108, in handle
> remove_deleted=remove_deleted)
> File "/dati/geonode/geonode/geoserver/helpers.py", line 445, in gs_slurp
> "bbox_y1": Decimal(resource.latlon_bbox[3])
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/manager.py",
> line 154, in get_or_create
> return self.get_queryset().get_or_create(**kwargs)
> File "/usr/local/lib/python2.7/dist-packages/modeltranslation/manager.py",
> line 341, in get_or_create
> return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/query.py",
> line 383, in get_or_create
> obj.save(force_insert=True, using=self.db)
> File
> "/usr/local/lib/python2.7/dist-packages/polymorphic/polymorphic_model.py",
> line 90, in save
> return super(PolymorphicModel, self).save(*args, **kwargs)
> File "/usr/local/lib/python2.7/dist-packages/django/db/models/base.py",
> line 545, in save
> force_update=force_update, update_fields=update_fields)
> line 582, in save_base
> update_fields=update_fields, raw=raw, using=using)
> File
> "/usr/local/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line
> 185, in send
> response = receiver(signal=self, sender=sender, **named)
> File "/dati/geonode/geonode/geoserver/signals.py", line 394, in
> geoserver_post_save
> create_thumbnail(instance, thumbnail_remote_url, thumbnail_create_url,
> ogc_client=http_client)
> File "/dati/geonode/geonode/layers/utils.py", line 676, in
> create_thumbnail
> instance.save_thumbnail(filename, image=image)
> File "/dati/geonode/geonode/base/models.py", line 564, in save_thumbnail
> with open(os.path.join(upload_path, filename), 'wb') as f:
> Exception: ('Failed to process reg2001_s_wgs84utm33', IOError(13,
> 'Permission denied'))
> From the last line, I guess, my problem is on permissions.
> Mybey something is missing on my config files....
> Where in particular?
> E.
make sure your web server has permission to write to the media
directory where the thumbnails are generated (set in MEDIA_ROOT in the
GeoNode settings file)
p
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
