[GeoNode-users] failed migration from 2.0 to 2.4
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Apr 11 05:03:06 PDT 2016
The issue seems to be originating here
https://github.com/GeoNode/geonode/blob/master/geonode/base/templatetags/base_tags.py#L54
And the final error is: ValueError: invalid literal for int() with base 10:
'None'
@capooti any hints?
2016-04-11 13:59 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
> Hello,
> We recently moved our data from a 2.0 geonode server (
> http://geonode.grida.no/) to a new server with geonode 2.4 (
> http://opengeo.grida.no/). geonode 2.4 was successfully installed before
> we ran the migration using the scripts provided here:
> https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24
> After running the two migration scripts, users, layers, and maps data were
> transferred successfully, but each time I clicked on a layer nothing would
> happen. When we tried to access the geoserver after logging in we also
> received an error message.
> Now we have an Internal Server Error after we tried to open up to the
> client side so that the server could be accessed externally from a browser.
> The error log file from /var/logs/apache2/error.log is attached to this
> email.
> perhaps someone here has an idea on what is the best way forward?
> Many thanks for the help,
> Levi
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160411/30094590/attachment.html>
More information about the geonode-users
