[GeoNode-users] failed migration from 2.0 to 2.4
Paolo Corti
pcorti at gmail.com
Mon Apr 11 07:52:29 PDT 2016
Looks like the migrations scripts didn't run successfully.
Levi, could you re-run the process and provide the full log of the
migration scripts?
Also, make sure to read comments here:
https://github.com/GeoNode/geonode/issues/2067
thanks
p
On Mon, Apr 11, 2016 at 8:03 AM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> The issue seems to be originating here
> https://github.com/GeoNode/geonode/blob/master/geonode/base/templatetags/base_tags.py#L54.
> And the final error is: ValueError: invalid literal for int() with base 10:
> 'None'
> @capooti any hints?
> 2016-04-11 13:59 GMT+02:00 Levi Westerveld <levi.westerveld at gmail.com>:
>> Hello,
>> We recently moved our data from a 2.0 geonode server
>> (http://geonode.grida.no/) to a new server with geonode 2.4
>> (http://opengeo.grida.no/). geonode 2.4 was successfully installed before we
>> ran the migration using the scripts provided here:
>> https://github.com/capooti/geonode/tree/migration_from20_to_24/scripts/migrations/migrate20to24.
>> After running the two migration scripts, users, layers, and maps data were
>> transferred successfully, but each time I clicked on a layer nothing would
>> happen. When we tried to access the geoserver after logging in we also
>> received an error message.
>> Now we have an Internal Server Error after we tried to open up to the
>> client side so that the server could be accessed externally from a browser.
>> The error log file from /var/logs/apache2/error.log is attached to this
>> email.
>> perhaps someone here has an idea on what is the best way forward?
>> Many thanks for the help,
>> Levi
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @capooti
skype: capooti
More information about the geonode-users
