[GeoNode-users] "sudo paver setup" command hangs when trying to install on Ubuntu 14.04
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Aug 22 10:32:10 PDT 2016
Hi, usually that step can take a while and you have to wait depending on
your internet speed.
We used that command today and was fine.
How long did u wait?
Il lunedì 22 agosto 2016, Kevin Côté <Kevin.Cote2 at usherbrooke.ca> ha
scritto:
> Hi,
> I'm trying to do a fresh install on a Ubuntu 14.04 VM without using the
> direct method "sudo apt-get install geonode". I want to install it this way
> to be able to follow steps in the doc for customizing the look of the
> plateform.
> I'm following the steps from this tutorial: http://docs.geonode.
> org/en/master/tutorials/install_and_admin/geonode_install/index.html
> The problem is when I run the command "sudo paver setup", the script
> download the geoserver.war binary, but then hangs there and does not do
> anything else. It gets stuck at "Downloading geoserver binary" in the
> console.
> Anyone has an idea why it is doing such thing ? Is there a problem with
> the pavement.py file ?
> Thank you
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160822/a1566e7d/attachment.html>
More information about the geonode-users
