[GeoNode-users] Adding layer from GeoExplorer porduces error
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Feb 4 07:06:06 PST 2016
oh yes sorry. Strange, the layer should use the typename of the layer like
geonode:puntos_rakel. Does that layer exists and is accessible in geonode
with that address?
2016-02-04 14:27 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Yeah, I usually do that with the layers that I load in GeoServer from
> different sources, but in this case is a user uploaded layer.. It is
> supposed that automatically it will load them, right?
> Regards,
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> ********************* LEGE OHARRA ******************* AVISOLEGAL
> ******************* DISCLAIMER *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: jueves, 04 de febrero de 2016 13:53
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Adding layer from GeoExplorer porduces error
> Hi, you may need to run a geonode updatelayers in order to register them
> in geonode.
> 2016-02-04 11:33 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi List,
> I don’t know why but when I’m trying to add a layer in the geoexplorer
> interface I get an error 404 a prompt shows: PAGE NOT FOUND Using fiddler
> I’ve seen that it fails requesting the url
> http://192.168.1.190/gs/puntos_rakel/edit-check
> where puntos_rakel is a previously added shape layer. It also occurs with
> all geoserver added layers.
> The full output from fiddler is
> <!DOCTYPE html>
> <html lang="en">
> <head>
> <meta charset="utf-8">
> <meta http-equiv="X-UA-Compatible" content="IE=edge">
> <meta name="viewport" content="width=device-width, initial-scale=1">
> <title>GeoNode</title>
> <link href="/static/lib/css/assets.min.css?v=2.4" rel="stylesheet"/>
> <link href="/static/geonode/css/ext-compatibility.css?v=2.4"
> rel="stylesheet" />
> <link href="/static/geonode/css/base.css?v=2.4" rel="stylesheet" />
> <style
> type="text/css">[ng\:cloak],[ng-cloak],[data-ng-cloak],[x-ng-cloak],.ng-cloak,.x-ng-cloak,.ng-hide:not(.ng-hide-animate){display:none
> !important;}</style>
> <!--[if IE]>
> <script src="https://html5shim.googlecode.com/svn/trunk/html5.js
> "></script>
> <style>
> #ieflag{
> display: block !important;
> height: 150px;
> text-align: center;
> </style>
> <![endif]-->
> <link rel="search" type="application/opensearchdescription+xml"
> href="/catalogue/opensearch" title="GeoNode Search"/>
> </head>
> <body class="">
> <nav class="navbar navbar-inverse navbar-fixed-top" role="navigation">
> <div class="container">
> <div class="navbar-header">
> <button type="button" class="navbar-toggle collapsed"
> data-toggle="collapse" data-target="#navbar">
> <span class="sr-only">Toggle navigation</span>
> <span class="icon-bar"></span>
> </button>
> <a class="navbar-brand" href="/">GeoNode</a>
> </div>
> <div id="navbar" class="navbar-collapse collapse">
> <ul class="nav navbar-nav">
> <li id="nav_layers">
> <a href="/layers/">Capas</a>
> </li>
> <li id="nav_maps">
> <a href="/maps/">Mapas</a>
> </li>
> <li id="nav_documents">
> <a href="/documents/">Documentos</a>
> </li>
> <li id="nav_people">
> <a href="/people/">Personas</a>
> </li>
> <li id="nav_groups">
> <a href="/groups/">Grupos</a>
> </li>
> </ul>
> <form class="navbar-form" id="search" action="/search/" >
> <div class="col-md-3">
> <div class="input-group">
> <input id="search_input" type="text" placeholder="Search"
> class="form-control" name="title__icontains">
> <span class="input-group-btn">
> <button class="btn btn-primary" type="submit"><i
> class="fa fa-search"></i></button>
> </span>
> </div>
> </div>
> </form>
> <ul class="nav navbar-nav navbar-right">
> <li>
> <a href="#" data-toggle="modal" data-target="#UserModal"
> role="button" aria-expanded="false">
> <img src="
> http://www.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e/?s=30"
> alt="u0899jbe" /> u0899jbe
> </a>
> </li>
> </ul>
> </div><!--/.nav-collapse -->
> </div>
> </nav>
> <div class="alert alert-danger alert-dismissible" role="alert"
> id="ieflag" style="display:none">
> <button type="button" class="close" data-dismiss="alert"
> aria-label="Close"><span aria-hidden="true">×</span></button>
> <h1>You are using an outdated browser that is not supported by
> GeoNode.</h1>
> <p>Please use a <strong>modern browser</strong> like Mozilla
> Firefox, Google Chrome or Safari.</p>
> </div>
> <div id="wrap">
> <div class="alert alert-warn" id="status-message" hidden="hidden">
> <a class="close" onclick="$('.alert').hide()">×</a>
> <strong><p id="status-message-text">Placeholder for
> status-message</p></strong>
> <p id="status-message-text-body">Placeholder for
> status-message-body</p>
> </div>
> <div class="row">
> <div class="col-md-8">
> <div id="description"><h3>Página no encontrada</h3></div>
> La página solicitada no existe. Tal vez usted está utilizando un marcador
> desactualizado.⏎
> </div>
> <div class="col-md-4">
> </div>
> </div>
> </div>
> </div>
> <footer class="footer">
> <div class="row">
> Proporcionado por: <a href="http://geonode.org">GeoNode</a>
> <em>Versión 2.4</em> |
> <a href="/developer/">Desarrolladores</a> |
> <a href="/about/">Acerca de</a>
> </div>
> <label class="hidden">Idioma</label>
> <form class="form-inline" action="/i18n/setlang/"
> method="post">
> <input type='hidden' name='csrfmiddlewaretoken'
> value='jwfEKZjzwie2cflbenmB0s4wNuXKAFTn' />
> <select class="col-md-6 pull-right" name="language"
> onchange="javascript:form.submit()">
> <option value="en" >
> English
> </option>
> <option value="es" selected="selected">
> Español
> </option>
> <option value="it" >
> Italiano
> </option>
> <option value="fr" >
> Français
> </option>
> <option value="de" >
> Deutsch
> </option>
> <option value="el" >
> Ελληνικά
> </option>
> <option value="id" >
> Bahasa Indonesia
> </option>
> <option value="zh-cn" >
> 中文
> </option>
> <option value="ja" >
> 日本語
> </option>
> <option value="fa" >
> Persian
> </option>
> <option value="ar" >
> Arabic
> </option>
> <option value="bn" >
> Bengali
> </option>
> <option value="ne" >
> Nepali
> </option>
> <option value="sq" >
> Albanian
> </option>
> <option value="af" >
> Afrikaans
> </option>
> <option value="sw" >
> Swahili
> </option>
> <option value="pt" >
> Portuguese
> </option>
> <option value="ru" >
> Russian
> </option>
> <option value="vi" >
> Vietnamese
> </option>
> <option value="ko" >
> 한국어
> </option>
> <option value="am" >
> Amharic
> </option>
> <option value="km" >
> Khmer
> </option>
> <option value="pl" >
> Polish
> </option>
> <option value="sv" >
> Swedish
> </option>
> <option value="th" >
> ไทย
> </option>
> <option value="uk" >
> Ukranian
> </option>
> <option value="si" >
> Sinhala
> </option>
> <option value="ta" >
> Tamil
> </option>
> <option value="tl" >
> Tagalog
> </option>
> </select>
> </form>
> </div>
> </div>
> </div>
> </footer>
> <!-- Modal must stay outside the navbar -->
> <div class="modal fade" id="UserModal" tabindex="-1" role="dialog"
> aria-labelledby="myModalLabel" aria-hidden="true">
> <div class="modal-dialog modal-sm">
> <div class="modal-content">
> <div class="modal-header">
> <button type="button" class="close" data-dismiss="modal"
> aria-hidden="true">×</button>
> <h4 class="modal-title" id="myModalLabel">Menu</h4>
> </div>
> <div class="modal-body">
> <ul class="list-unstyled">
> <li><a href="/layers/upload"><i class="fa
> fa-cloud-upload"></i> Subir Capas</a></li>
> <li class="modal-divider"></li>
> <li><a href="/people/profile/u0899jbe/"><i class="fa
> fa-user"></i> Perfil</a></li>
> <li><a href="/social/recent-activity"><i class="fa
> fa-fire"></i> Reciente Actividad</a></li>
> <li><a href="/messages/inbox/"><i class="fa fa-inbox"></i>
> Bandeja de entrada</a></li>
> <li><a title="Help" rel="tooltip" href="/help/"><i class="fa
> fa-question-circle"></i> Ayuda</a></li>
> </ul>
> </div>
> <div class="modal-footer">
> <form action="/account/logout/" id="logout_form" method="post">
> <a class="btn btn-warning btn-block" href="javascript:{}"
> onclick="document.getElementById('logout_form').submit();">Salir</a>
> </form>
> </div>
> </div>
> </div>
> </div>
> <!-- End of Modal -->
> <script src="/static/lib/js/assets.min.js?v=2.4"></script>
> <script src="/static/geonode/js/utils/utils.js?v=2.4"></script>
> <script src="/static/geonode/js/base/base.js?v=2.4"></script>
> <script type="text/javascript">
> jQuery(function($) {
> function getCookie(name) {
> var cookieValue = null;
> if (document.cookie && document.cookie != '') {
> var cookies = document.cookie.split(';');
> for (var i = 0; i < cookies.length; i++) {
> var cookie = jQuery.trim(cookies[i]);
> // Does this cookie string begin with the name we want?
> if (cookie.substring(0, name.length + 1) == (name + '=')) {
> cookieValue =
> decodeURIComponent(cookie.substring(name.length + 1));
> break;
> return cookieValue;
> function csrfSafeMethod(method) {
> // these HTTP methods do not require CSRF protection
> return (/^(GET|HEAD|OPTIONS|TRACE)$/.test(method));
> function sameOrigin(url) {
> // test that a given url is a same-origin URL
> // url could be relative or scheme relative or absolute
> var host = document.location.host; // host + port
> var protocol = document.location.protocol;
> var sr_origin = '//' + host;
> var origin = protocol + sr_origin;
> // Allow absolute or scheme relative URLs to same origin
> return (url == origin || url.slice(0, origin.length + 1) == origin +
> (url == sr_origin || url.slice(0, sr_origin.length + 1) ==
> sr_origin + '/') ||
> // or any other URL that isn't scheme relative or absolute i.e
> relative.
> !(/^(\/\/|http:|https:).*/.test(url));
> $.ajaxSetup({
> beforeSend: function(xhr, settings) {
> if (!csrfSafeMethod(settings.type) && sameOrigin(settings.url)) {
> // Send the token to same-origin, relative URLs only.
> // Send the token only if the method warrants CSRF protection
> // Using the CSRFToken value acquired earlier
> xhr.setRequestHeader("X-CSRFToken", getCookie('csrftoken'));
> </script>
> src="/static/autocomplete_light/django_admin.js"></script>
> src="/static/autocomplete_light/autocomplete.js"></script>
> src="/static/autocomplete_light/widget.js"></script>
> src="/static/autocomplete_light/addanother.js"></script>
> src="/static/autocomplete_light/text_widget.js"></script>
> src="/static/autocomplete_light/remote.js"></script>
> <link rel="stylesheet" type="text/css"
> href="/static/autocomplete_light/style.css" />
> <script type="text/javascript" src="/jsi18n/"></script>
> var autocomplete = $('#search_input').yourlabsAutocomplete({
> url: '/autocomplete/ResourceBaseAutocomplete/',
> choiceSelector: 'span',
> hideAfter: 200,
> minimumCharacters: 1,
> placeholder: 'Escriba aquí su busqueda ...',
> appendAutocomplete: $('#search_input'),
> autoHilightFirst: false
> $('#search_input').bind('selectChoice', function(e, choice,
> autocomplete) {
> if(choice[0].children[0] == undefined) {
> $('#search_input').val($(choice[0]).text());
> $('#search').submit();
> </script>
> <script>
> // Workaround to fix the autocomplete box positions
> yourlabs.Autocomplete.prototype.fixPosition = function(html) {
> this.input.parents().filter(function() {
> return $(this).css('overflow') === 'hidden';
> }).first().css('overflow', 'visible');
> if(this.input.attr('name') !== 'resource-keywords'){
> this.box.insertAfter(this.input).css({top: 0, left: 0});
> }else{
> var pos = $.extend({}, this.input.position(), {
> height: this.input.outerHeight()
> this.box.insertAfter(this.input).css({top: pos.top +
> pos.height, left: pos.left});
> </script>
> <script type="text/javascript" src="/lang.js"></script>
> </body>
> </html>
> Any Ideas?
> Thanks.
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160204/763a92cb/attachment-0001.html>
More information about the geonode-users
