[GeoNode-users] Adding layer from GeoExplorer porduces error
David Alda Fernandez de Lezea
dalda at hazi.eus
Mon Feb 8 01:02:20 PST 2016
Hi Simone,
Yeah, it’s accessible by http://192.168.1.190/layers/geonode%3Apuntos_rakel
I also modified the settins.py last lines to get in the WMS combo box only the layers uploaded to geonode workspace. Could that be the problem?
if 'geonode.geoserver' in INSTALLED_APPS:
LOCAL_GEOSERVER = {
"source": {
"ptype": "gxp_wmscsource",
"url": OGC_SERVER['default']['PUBLIC_LOCATION'] + "geonode/wms",
"restUrl": "/gs/rest"
baselayers = MAP_BASELAYERS
MAP_BASELAYERS = [LOCAL_GEOSERVER]
MAP_BASELAYERS.extend(baselayers)
Thanks.
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
********************* LEGE OHARRA ******************* AVISOLEGAL ******************* DISCLAIMER *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
Enviado el: jueves, 04 de febrero de 2016 16:06
Para: David Alda Fernandez de Lezea
CC: geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] Adding layer from GeoExplorer porduces error
oh yes sorry. Strange, the layer should use the typename of the layer like geonode:puntos_rakel. Does that layer exists and is accessible in geonode with that address?
2016-02-04 14:27 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Yeah, I usually do that with the layers that I load in GeoServer from different sources, but in this case is a user uploaded layer.. It is supposed that automatically it will load them, right?
Regards,
Agur bero bat,
Enviado el: jueves, 04 de febrero de 2016 13:53
Hi, you may need to run a geonode updatelayers in order to register them in geonode.
2016-02-04 11:33 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
Hi List,
I don’t know why but when I’m trying to add a layer in the geoexplorer interface I get an error 404 a prompt shows: PAGE NOT FOUND Using fiddler I’ve seen that it fails requesting the url
http://192.168.1.190/gs/puntos_rakel/edit-check
where puntos_rakel is a previously added shape layer. It also occurs with all geoserver added layers.
The full output from fiddler is
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1">
<title>GeoNode</title>
<link href="/static/lib/css/assets.min.css?v=2.4" rel="stylesheet"/>
<link href="/static/geonode/css/ext-compatibility.css?v=2.4" rel="stylesheet" />
<link href="/static/geonode/css/base.css?v=2.4" rel="stylesheet" />
<style type="text/css">[ng\:cloak],[ng-cloak],[data-ng-cloak],[x-ng-cloak],.ng-cloak,.x-ng-cloak,.ng-hide:not(.ng-hide-animate){display:none !important;}</style>
<!--[if IE]>
<script src="https://html5shim.googlecode.com/svn/trunk/html5.js"></script>
<style>
#ieflag{
display: block !important;
height: 150px;
text-align: center;
</style>
<![endif]-->
<link rel="search" type="application/opensearchdescription+xml" href="/catalogue/opensearch" title="GeoNode Search"/>
</head>
<body class="">
<nav class="navbar navbar-inverse navbar-fixed-top" role="navigation">
<div class="container">
<div class="navbar-header">
<button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#navbar">
<span class="sr-only">Toggle navigation</span>
<span class="icon-bar"></span>
</button>
<a class="navbar-brand" href="/">GeoNode</a>
</div>
<div id="navbar" class="navbar-collapse collapse">
<ul class="nav navbar-nav">
<li id="nav_layers">
<a href="/layers/">Capas</a>
</li>
<li id="nav_maps">
<a href="/maps/">Mapas</a>
</li>
<li id="nav_documents">
<a href="/documents/">Documentos</a>
</li>
<li id="nav_people">
<a href="/people/">Personas</a>
</li>
<li id="nav_groups">
<a href="/groups/">Grupos</a>
</li>
</ul>
<form class="navbar-form" id="search" action="/search/" >
<div class="col-md-3">
<div class="input-group">
<input id="search_input" type="text" placeholder="Search" class="form-control" name="title__icontains">
<span class="input-group-btn">
<button class="btn btn-primary" type="submit"><i class="fa fa-search"></i></button>
</span>
</div>
</div>
</form>
<ul class="nav navbar-nav navbar-right">
<li>
<a href="#" data-toggle="modal" data-target="#UserModal" role="button" aria-expanded="false">
<img src="http://www.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e/?s=30" alt="u0899jbe" /> u0899jbe
</a>
</li>
</ul>
</div><!--/.nav-collapse -->
</div>
</nav>
<div class="alert alert-danger alert-dismissible" role="alert" id="ieflag" style="display:none">
<button type="button" class="close" data-dismiss="alert" aria-label="Close"><span aria-hidden="true">×</span></button>
<h1>You are using an outdated browser that is not supported by GeoNode.</h1>
<p>Please use a <strong>modern browser</strong> like Mozilla Firefox, Google Chrome or Safari.</p>
</div>
<div id="wrap">
<div class="alert alert-warn" id="status-message" hidden="hidden">
<a class="close" onclick="$('.alert').hide()">×</a>
<strong><p id="status-message-text">Placeholder for status-message</p></strong>
<p id="status-message-text-body">Placeholder for status-message-body</p>
</div>
<div class="row">
<div class="col-md-8">
<div id="description"><h3>Página no encontrada</h3></div>
La página solicitada no existe. Tal vez usted está utilizando un marcador desactualizado.⏎
</div>
<div class="col-md-4">
</div>
</div>
</div>
</div>
<footer class="footer">
<div class="row">
Proporcionado por: <a href="http://geonode.org">GeoNode</a> <em>Versión 2.4</em> |
<a href="/developer/">Desarrolladores</a> |
<a href="/about/">Acerca de</a>
</div>
<label class="hidden">Idioma</label>
<form class="form-inline" action="/i18n/setlang/" method="post">
<input type='hidden' name='csrfmiddlewaretoken' value='jwfEKZjzwie2cflbenmB0s4wNuXKAFTn' />
<select class="col-md-6 pull-right" name="language" onchange="javascript:form.submit()">
<option value="en" >
English
</option>
<option value="es" selected="selected">
Español
</option>
<option value="it" >
Italiano
</option>
<option value="fr" >
Français
</option>
<option value="de" >
Deutsch
</option>
<option value="el" >
Ελληνικά
</option>
<option value="id" >
Bahasa Indonesia
</option>
<option value="zh-cn" >
中文
</option>
<option value="ja" >
日本語
</option>
<option value="fa" >
Persian
</option>
<option value="ar" >
Arabic
</option>
<option value="bn" >
Bengali
</option>
<option value="ne" >
Nepali
</option>
<option value="sq" >
Albanian
</option>
<option value="af" >
Afrikaans
</option>
<option value="sw" >
Swahili
</option>
<option value="pt" >
Portuguese
</option>
<option value="ru" >
Russian
</option>
<option value="vi" >
Vietnamese
</option>
<option value="ko" >
한국어
</option>
<option value="am" >
Amharic
</option>
<option value="km" >
Khmer
</option>
<option value="pl" >
Polish
</option>
<option value="sv" >
Swedish
</option>
<option value="th" >
ไทย
</option>
<option value="uk" >
Ukranian
</option>
<option value="si" >
Sinhala
</option>
<option value="ta" >
Tamil
</option>
<option value="tl" >
Tagalog
</option>
</select>
</form>
</div>
</div>
</div>
</footer>
<!-- Modal must stay outside the navbar -->
<div class="modal fade" id="UserModal" tabindex="-1" role="dialog" aria-labelledby="myModalLabel" aria-hidden="true">
<div class="modal-dialog modal-sm">
<div class="modal-content">
<div class="modal-header">
<button type="button" class="close" data-dismiss="modal" aria-hidden="true">×</button>
<h4 class="modal-title" id="myModalLabel">Menu</h4>
</div>
<div class="modal-body">
<ul class="list-unstyled">
<li><a href="/layers/upload"><i class="fa fa-cloud-upload"></i> Subir Capas</a></li>
<li class="modal-divider"></li>
<li><a href="/people/profile/u0899jbe/"><i class="fa fa-user"></i> Perfil</a></li>
<li><a href="/social/recent-activity"><i class="fa fa-fire"></i> Reciente Actividad</a></li>
<li><a href="/messages/inbox/"><i class="fa fa-inbox"></i> Bandeja de entrada</a></li>
<li><a title="Help" rel="tooltip" href="/help/"><i class="fa fa-question-circle"></i> Ayuda</a></li>
</ul>
</div>
<div class="modal-footer">
<form action="/account/logout/" id="logout_form" method="post">
<a class="btn btn-warning btn-block" href="javascript:{}" onclick="document.getElementById('logout_form').submit();">Salir</a>
</form>
</div>
</div>
</div>
</div>
<!-- End of Modal -->
<script src="/static/lib/js/assets.min.js?v=2.4"></script>
<script src="/static/geonode/js/utils/utils.js?v=2.4"></script>
<script src="/static/geonode/js/base/base.js?v=2.4"></script>
<script type="text/javascript">
jQuery(function($) {
function getCookie(name) {
var cookieValue = null;
if (document.cookie && document.cookie != '') {
var cookies = document.cookie.split(';');
for (var i = 0; i < cookies.length; i++) {
var cookie = jQuery.trim(cookies[i]);
// Does this cookie string begin with the name we want?
if (cookie.substring(0, name.length + 1) == (name + '=')) {
cookieValue = decodeURIComponent(cookie.substring(name.length + 1));
break;
return cookieValue;
function csrfSafeMethod(method) {
// these HTTP methods do not require CSRF protection
return (/^(GET|HEAD|OPTIONS|TRACE)$/.test(method));
function sameOrigin(url) {
// test that a given url is a same-origin URL
// url could be relative or scheme relative or absolute
var host = document.location.host; // host + port
var protocol = document.location.protocol;
var sr_origin = '//' + host;
var origin = protocol + sr_origin;
// Allow absolute or scheme relative URLs to same origin
return (url == origin || url.slice(0, origin.length + 1) == origin + '/') ||
(url == sr_origin || url.slice(0, sr_origin.length + 1) == sr_origin + '/') ||
// or any other URL that isn't scheme relative or absolute i.e relative.
!(/^(\/\/|http:|https:).*/.test(url));
$.ajaxSetup({
beforeSend: function(xhr, settings) {
if (!csrfSafeMethod(settings.type) && sameOrigin(settings.url)) {
// Send the token to same-origin, relative URLs only.
// Send the token only if the method warrants CSRF protection
// Using the CSRFToken value acquired earlier
xhr.setRequestHeader("X-CSRFToken", getCookie('csrftoken'));
</script>
<script type="text/javascript" src="/static/autocomplete_light/django_admin.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/autocomplete.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/widget.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/addanother.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/text_widget.js"></script>
<script type="text/javascript" src="/static/autocomplete_light/remote.js"></script>
<link rel="stylesheet" type="text/css" href="/static/autocomplete_light/style.css" />
<script type="text/javascript" src="/jsi18n/"></script>
var autocomplete = $('#search_input').yourlabsAutocomplete({
url: '/autocomplete/ResourceBaseAutocomplete/',
choiceSelector: 'span',
hideAfter: 200,
minimumCharacters: 1,
placeholder: 'Escriba aquí su busqueda ...',
appendAutocomplete: $('#search_input'),
autoHilightFirst: false
$('#search_input').bind('selectChoice', function(e, choice, autocomplete) {
if(choice[0].children[0] == undefined) {
$('#search_input').val($(choice[0]).text());
$('#search').submit();
</script>
<script>
// Workaround to fix the autocomplete box positions
yourlabs.Autocomplete.prototype.fixPosition = function(html) {
this.input.parents().filter(function() {
return $(this).css('overflow') === 'hidden';
}).first().css('overflow', 'visible');
if(this.input.attr('name') !== 'resource-keywords'){
this.box.insertAfter(this.input).css({top: 0, left: 0});
}else{
var pos = $.extend({}, this.input.position(), {
height: this.input.outerHeight()
this.box.insertAfter(this.input).css({top: pos.top + pos.height, left: pos.left});
</script>
<script type="text/javascript" src="/lang.js"></script>
</body>
</html>
Any Ideas?
Thanks.
Agur bero bat,
geonode-users mailing list
http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
Simone
More information about the geonode-users
