[GeoNode-users] Info to update geonode
Annalisa Schiavon
annalisa.schiavon at gmail.com
Tue Feb 16 03:29:36 PST 2016
Another question:
I've installed also geonode-project (
https://github.com/GeoNode/geonode-project ) with
$ django-admin startproject geoportale
--template=https://github.com/GeoNode/geonode-project/archive/master.zip
-epy,rst
$ sudo pip install -e geoportale
I have to upgrade also the template? How?
Thank you
Annalisa
2016-02-16 12:12 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Hi all,
> I'd like to update my geonode version from 2.4c1 to stable on the same
> server.
> It's correct to do:
> add-apt-repository --remove ppa:geonode/testing
> and then
> add-apt-repository ppa:geonode/stable
> apt-get update
> apt-get install geonode
> I've made backup of geonode and geonode-data database with pg-dump and
> I've backup ok local_setting and other files.
> Geoserver data are in an other dir than default, so It should not give
> problems ...
> If it's correct, I've to do geonode-updateip and createsuperuser or not?
> Ip doesn't change, and superuser already exists.
> Thanks
> Annalisa
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160216/8247268b/attachment.html>
More information about the geonode-users
