[GeoNode-users] Info to update geonode
Simone Dalmasso simone.dalmasso at gmail.com
Tue Feb 16 04:22:02 PST 2016
Annalisa,
your procedure should be ok, you don't have to do createsuperuser again nor
the updateip. and your project should stay as it is so no need for another
install.
You also did correctly by backing up the db and geoserver folders.
2016-02-16 12:29 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>:
> Another question:
> I've installed also geonode-project (
> https://github.com/GeoNode/geonode-project ) with
> $ django-admin startproject geoportale --template=https://github.com/GeoNode/geonode-project/archive/master.zip -epy,rst
> $ sudo pip install -e geoportale
> I have to upgrade also the template? How?
> Thank you
> Annalisa
> 2016-02-16 12:12 GMT+01:00 Annalisa Schiavon <annalisa.schiavon at gmail.com>
>> Hi all,
>> I'd like to update my geonode version from 2.4c1 to stable on the same
>> server.
>> It's correct to do:
>> add-apt-repository --remove ppa:geonode/testing
>> and then
>> add-apt-repository ppa:geonode/stable
>> apt-get update
>> apt-get install geonode
>> I've made backup of geonode and geonode-data database with pg-dump and
>> I've backup ok local_setting and other files.
>> Geoserver data are in an other dir than default, so It should not give
>> problems ...
>> If it's correct, I've to do geonode-updateip and createsuperuser or not?
>> Ip doesn't change, and superuser already exists.
>> Thanks
>> Annalisa
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160216/4dff216e/attachment.html>
More information about the geonode-users mailing list
