[GeoNode-users] Geonode error "page not found" on production install
Ivo Santos
ivojfs at gmail.com
Tue Jan 12 16:23:35 PST 2016
Finnaly I got it almost working but for some reason it appears that using
the apt-get instalation, geoserver was not installed. Trying to manual
install it.
The homepage has also a problem. It's weird but it appears that something
redirects the link to some page that is not present on geonode. All the
other links are working correctly.
Thank you!
2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
> Hi everyone,
> So, after trying on localhost and themed my instalation to my needs, I am
> installing geonode on the production server. I am again with some doubts on
> the configuration. The automatic configuration file geonode.conf was
> changed by me on:
> <VirtualHost *:80>
> Servername atlas.example.com
> ServerAlias atlas.example.com
> When I try to reach geoserver I get a apache tomcat 404. should i change
> also on that file, the proxypass "localhost" to "atlas.example.com"?
> These are the lines:
> ProxyPass /geoserver http://localhost:8080/geoserver
> ProxyPassReverse /geoserver http://localhost:8080/geoserver
> My 000-default.conf was working with the www.example.com on a CMS, now
> the configuration is redirecting to geoserver landing page. On other hand
> atlas.example.com shows geonode with "page not found error"
> On my local_settings.py I changed the SITEURL= 'http://atlas.example.com'
> and ALLOWED_HOSTS=['atlas.example.com','www.example.com']
> Hoping that you can help me,
> Best regards,
> Ivo
> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>> Simone,
>> Thank you for your help. I am testing on a lamp instalation on my laptop.
>> For now I will test other aspects and leave that part for the production
>> environment.
>> Best regards,
>> Ivo
>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Ivo, if your server doesn't have a name (just the ip address) then you
>>> cannot have multiple sites under the root. if you have a domain name then
>>> you can take a look at the apache virtualhost configuration
>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>> hope this helps
>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Hi Simone,
>>>> Thank you for showing me the correct way. I managed to use geonode on a
>>>> subdomain like you suggested. But now every other site on the server is
>>>> giving error "Bad Request (400)". Probably this is a common error due to my
>>>> inexperience with apache. If this questions are not for this list please
>>>> let me know.
>>>> Regards,
>>>> Ivo
>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Hi Ivo,
>>>>> Geonode works at the root of the domain and you cannot serve it under
>>>>> /geonode unless you change the code or maybe do some tricks with Apache.
>>>>> Not sure if someone else has tried that. The suggestion is to keep at the
>>>>> root but serve it with an Apache virtualhost when you have a domain name.
>>>>> Like geonode.yourdomain.com.
>>>>> Regards
>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha scritto:
>>>>>> Hi everyone,
>>>>>> I am new to geonode and testing the possibility of using it on my
>>>>>> work. For now, I am trying to install Geonode for production.
>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But when I
>>>>>> try to reach that page it appears "page not found". The homepage of geonode
>>>>>> remains http://10.0.2.15
>>>>>> Am I missing something here? Can you help me? If you need any kind of
>>>>>> information, please ask.
>>>>>> Best regards and thank you in advance,
>>>>>> Ivo
>>>>>> Ivo Santos
>>>>> Simone
>>>> Ivo Santos
>>> Simone
>> Ivo Santos
> Ivo Santos
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160113/f33b5783/attachment.html>
More information about the geonode-users
