[GeoNode-users] Geonode error "page not found" on production install
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jan 13 00:22:18 PST 2016
Hi Ivo,
one of the reasons why the apt-get installation can fail could be that on
the machine there were already installed some of the components, in this
case tomcat maybe.
anyway if you install geoserver manually be sure to use the one provided by
geonode http://build.geonode.org/geoserver/latest/geoserver.war.
what link is broken, exactly?
2016-01-13 1:23 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> Finnaly I got it almost working but for some reason it appears that using
> the apt-get instalation, geoserver was not installed. Trying to manual
> install it.
> The homepage has also a problem. It's weird but it appears that something
> redirects the link to some page that is not present on geonode. All the
> other links are working correctly.
> Thank you!
> 2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>> Hi everyone,
>> So, after trying on localhost and themed my instalation to my needs, I am
>> installing geonode on the production server. I am again with some doubts on
>> the configuration. The automatic configuration file geonode.conf was
>> changed by me on:
>> <VirtualHost *:80>
>> Servername atlas.example.com
>> ServerAlias atlas.example.com
>> When I try to reach geoserver I get a apache tomcat 404. should i change
>> also on that file, the proxypass "localhost" to "atlas.example.com"?
>> These are the lines:
>> ProxyPass /geoserver http://localhost:8080/geoserver
>> ProxyPassReverse /geoserver http://localhost:8080/geoserver
>> My 000-default.conf was working with the www.example.com on a CMS, now
>> the configuration is redirecting to geoserver landing page. On other hand
>> atlas.example.com shows geonode with "page not found error"
>> On my local_settings.py I changed the SITEURL= 'http://atlas.example.com'
>> and ALLOWED_HOSTS=['atlas.example.com','www.example.com']
>> Hoping that you can help me,
>> Best regards,
>> Ivo
>> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>> Simone,
>>> Thank you for your help. I am testing on a lamp instalation on my
>>> laptop. For now I will test other aspects and leave that part for the
>>> production environment.
>>> Best regards,
>>> Ivo
>>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Ivo, if your server doesn't have a name (just the ip address) then you
>>>> cannot have multiple sites under the root. if you have a domain name then
>>>> you can take a look at the apache virtualhost configuration
>>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>>> hope this helps
>>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>> Hi Simone,
>>>>> Thank you for showing me the correct way. I managed to use geonode on
>>>>> a subdomain like you suggested. But now every other site on the server is
>>>>> giving error "Bad Request (400)". Probably this is a common error due to my
>>>>> inexperience with apache. If this questions are not for this list please
>>>>> let me know.
>>>>> Regards,
>>>>> Ivo
>>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>>> Hi Ivo,
>>>>>> Geonode works at the root of the domain and you cannot serve it under
>>>>>> /geonode unless you change the code or maybe do some tricks with Apache.
>>>>>> Not sure if someone else has tried that. The suggestion is to keep at the
>>>>>> root but serve it with an Apache virtualhost when you have a domain name.
>>>>>> Like geonode.yourdomain.com.
>>>>>> Regards
>>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha scritto:
>>>>>>> Hi everyone,
>>>>>>> I am new to geonode and testing the possibility of using it on my
>>>>>>> work. For now, I am trying to install Geonode for production.
>>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But when I
>>>>>>> try to reach that page it appears "page not found". The homepage of geonode
>>>>>>> remains http://10.0.2.15
>>>>>>> Am I missing something here? Can you help me? If you need any kind
>>>>>>> of information, please ask.
>>>>>>> Best regards and thank you in advance,
>>>>>>> Ivo
>>>>>>> Ivo Santos
>>>>>> Simone
>>>>> Ivo Santos
>>>> Simone
>>> Ivo Santos
>> Ivo Santos
> Ivo Santos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160113/c5394246/attachment-0001.html>
More information about the geonode-users
