[GeoNode-users] Geonode error "page not found" on production install
Ivo Santos ivojfs at gmail.com
Wed Jan 13 01:43:09 PST 2016
Hi Simone,
Yes, tomcat was already instaled. I used the geoserver.war on that link and
now that part is working great.
For now the only problem it's just the link of the homepage. For example,
if I try to go to my homepage atlas.example.com I am being redirected to
atlas.example.com/init/index.php and not to the geonode homepage.
I had a previous configuration with another webgis using that subdomain. Do
you think it could be a wrong configuration on apache or on geonode?
Thank you for all the help and guidance,
Ivo
2016-01-13 8:22 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Hi Ivo,
> one of the reasons why the apt-get installation can fail could be that on
> the machine there were already installed some of the components, in this
> case tomcat maybe.
> anyway if you install geoserver manually be sure to use the one provided
> by geonode http://build.geonode.org/geoserver/latest/geoserver.war.
> what link is broken, exactly?
> 2016-01-13 1:23 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Finnaly I got it almost working but for some reason it appears that using
>> the apt-get instalation, geoserver was not installed. Trying to manual
>> install it.
>> The homepage has also a problem. It's weird but it appears that something
>> redirects the link to some page that is not present on geonode. All the
>> other links are working correctly.
>> Thank you!
>> 2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>> Hi everyone,
>>> So, after trying on localhost and themed my instalation to my needs, I
>>> am installing geonode on the production server. I am again with some doubts
>>> on the configuration. The automatic configuration file geonode.conf was
>>> changed by me on:
>>> <VirtualHost *:80>
>>>     Servername atlas.example.com
>>>     ServerAlias atlas.example.com
>>> When I try to reach geoserver I get a apache tomcat 404. should i change
>>> also on that file, the proxypass "localhost" to "atlas.example.com"?
>>> These are the lines:
>>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>> My 000-default.conf was working with the www.example.com on a CMS, now
>>> the configuration is redirecting to geoserver landing page. On other hand
>>> atlas.example.com shows geonode with "page not found error"
>>> On my local_settings.py I changed the SITEURL= 'http://atlas.example.com'
>>> and ALLOWED_HOSTS=['atlas.example.com','www.example.com']
>>> Hoping that you can help me,
>>> Best regards,
>>> Ivo
>>> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Simone,
>>>> Thank you for your help. I am testing on a lamp instalation on my
>>>> laptop. For now I will test other aspects and leave that part for the
>>>> production environment.
>>>> Best regards,
>>>> Ivo
>>>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>>> Ivo, if your server doesn't have a name (just the ip address) then you
>>>>> cannot have multiple sites under the root. if you have a domain name then
>>>>>  you can take a look at the apache virtualhost configuration
>>>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>>>> hope this helps
>>>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>> Hi Simone,
>>>>>> Thank you for showing me the correct way. I managed to use geonode on
>>>>>> a subdomain like you suggested. But now every other site on the server is
>>>>>> giving error "Bad Request (400)". Probably this is a common error due to my
>>>>>> inexperience with apache. If this questions are not for this list please
>>>>>> let me know.
>>>>>> Regards,
>>>>>> Ivo
>>>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>>> Hi Ivo,
>>>>>>> Geonode works at the root of the domain and you cannot serve it
>>>>>>> under /geonode unless you change the code or maybe do some tricks with
>>>>>>> Apache. Not sure if someone else has tried that. The suggestion is to keep
>>>>>>> at the root but serve it with an Apache virtualhost when you have a domain
>>>>>>> name. Like geonode.yourdomain.com.
>>>>>>> Regards
>>>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha scritto:
>>>>>>>> Hi everyone,
>>>>>>>> I am new to geonode and testing the possibility of using it on my
>>>>>>>> work. For now, I am trying to install Geonode for production.
>>>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But when
>>>>>>>> I try to reach that page it appears "page not found". The homepage of
>>>>>>>> geonode remains http://10.0.2.15
>>>>>>>> Am I missing something here? Can you help me? If you need any kind
>>>>>>>> of information, please ask.
>>>>>>>> Best regards and thank you in advance,
>>>>>>>> Ivo
>>>>>>>> Ivo Santos
>>>>>>> Simone
>>>>>> Ivo Santos
>>>>> Simone
>>>> Ivo Santos
>>> Ivo Santos
>> Ivo Santos
> Simone
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160113/91b3472d/attachment.html>
More information about the geonode-users mailing list
