[GeoNode-users] Geonode error "page not found" on production install
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jan 13 01:48:41 PST 2016
that is definitely an apache misconfiguration, maybe of the php module.
2016-01-13 10:43 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> Hi Simone,
> Yes, tomcat was already instaled. I used the geoserver.war on that link
> and now that part is working great.
> For now the only problem it's just the link of the homepage. For example,
> if I try to go to my homepage atlas.example.com I am being redirected to
> atlas.example.com/init/index.php and not to the geonode homepage.
> I had a previous configuration with another webgis using that subdomain.
> Do you think it could be a wrong configuration on apache or on geonode?
> Thank you for all the help and guidance,
> Ivo
> 2016-01-13 8:22 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi Ivo,
>> one of the reasons why the apt-get installation can fail could be that on
>> the machine there were already installed some of the components, in this
>> case tomcat maybe.
>> anyway if you install geoserver manually be sure to use the one provided
>> by geonode http://build.geonode.org/geoserver/latest/geoserver.war.
>> what link is broken, exactly?
>> 2016-01-13 1:23 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>> Finnaly I got it almost working but for some reason it appears that
>>> using the apt-get instalation, geoserver was not installed. Trying to
>>> manual install it.
>>> The homepage has also a problem. It's weird but it appears that
>>> something redirects the link to some page that is not present on geonode.
>>> All the other links are working correctly.
>>> Thank you!
>>> 2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Hi everyone,
>>>> So, after trying on localhost and themed my instalation to my needs, I
>>>> am installing geonode on the production server. I am again with some doubts
>>>> on the configuration. The automatic configuration file geonode.conf was
>>>> changed by me on:
>>>> <VirtualHost *:80>
>>>>     Servername atlas.example.com
>>>>     ServerAlias atlas.example.com
>>>> When I try to reach geoserver I get a apache tomcat 404. should i
>>>> change also on that file, the proxypass "localhost" to "
>>>> atlas.example.com"? These are the lines:
>>>>     ProxyPass /geoserver http://localhost:8080/geoserver
>>>>     ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>> My 000-default.conf was working with the www.example.com on a CMS, now
>>>> the configuration is redirecting to geoserver landing page. On other hand
>>>> atlas.example.com shows geonode with "page not found error"
>>>> On my local_settings.py I changed the SITEURL= '
>>>> http://atlas.example.com' and ALLOWED_HOSTS=['atlas.example.com','
>>>> www.example.com']
>>>> Hoping that you can help me,
>>>> Best regards,
>>>> Ivo
>>>> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>> Simone,
>>>>> Thank you for your help. I am testing on a lamp instalation on my
>>>>> laptop. For now I will test other aspects and leave that part for the
>>>>> production environment.
>>>>> Best regards,
>>>>> Ivo
>>>>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>>> Ivo, if your server doesn't have a name (just the ip address) then
>>>>>> you cannot have multiple sites under the root. if you have a domain name
>>>>>> then  you can take a look at the apache virtualhost configuration
>>>>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>>>>> hope this helps
>>>>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>> Hi Simone,
>>>>>>> Thank you for showing me the correct way. I managed to use geonode
>>>>>>> on a subdomain like you suggested. But now every other site on the server
>>>>>>> is giving error "Bad Request (400)". Probably this is a common error due to
>>>>>>> my inexperience with apache. If this questions are not for this list please
>>>>>>> let me know.
>>>>>>> Regards,
>>>>>>> Ivo
>>>>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>>> Hi Ivo,
>>>>>>>> Geonode works at the root of the domain and you cannot serve it
>>>>>>>> under /geonode unless you change the code or maybe do some tricks with
>>>>>>>> Apache. Not sure if someone else has tried that. The suggestion is to keep
>>>>>>>> at the root but serve it with an Apache virtualhost when you have a domain
>>>>>>>> name. Like geonode.yourdomain.com.
>>>>>>>> Regards
>>>>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha
>>>>>>>> scritto:
>>>>>>>>> Hi everyone,
>>>>>>>>> I am new to geonode and testing the possibility of using it on my
>>>>>>>>> work. For now, I am trying to install Geonode for production.
>>>>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But when
>>>>>>>>> I try to reach that page it appears "page not found". The homepage of
>>>>>>>>> geonode remains http://10.0.2.15
>>>>>>>>> Am I missing something here? Can you help me? If you need any kind
>>>>>>>>> of information, please ask.
>>>>>>>>> Best regards and thank you in advance,
>>>>>>>>> Ivo
>>>>>>>>> Ivo Santos
>>>>>>>> Simone
>>>>>>> Ivo Santos
>>>>>> Simone
>>>>> Ivo Santos
>>>> Ivo Santos
>>> Ivo Santos
>> Simone
> Ivo Santos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160113/34da3ffe/attachment-0001.html>
More information about the geonode-users mailing list
