[GeoNode-users] Geonode error "page not found" on production install
Ivo Santos
ivojfs at gmail.com
Wed Jan 13 01:50:22 PST 2016
Ok, can you tell me if geonode is compatible with suphp? I am trying to
explore if it is a compatibility issue.
2016-01-13 9:48 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> that is definitely an apache misconfiguration, maybe of the php module.
> 2016-01-13 10:43 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>> Hi Simone,
>> Yes, tomcat was already instaled. I used the geoserver.war on that link
>> and now that part is working great.
>> For now the only problem it's just the link of the homepage. For example,
>> if I try to go to my homepage atlas.example.com I am being redirected to
>> atlas.example.com/init/index.php and not to the geonode homepage.
>> I had a previous configuration with another webgis using that subdomain.
>> Do you think it could be a wrong configuration on apache or on geonode?
>> Thank you for all the help and guidance,
>> Ivo
>> 2016-01-13 8:22 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>> Hi Ivo,
>>> one of the reasons why the apt-get installation can fail could be that
>>> on the machine there were already installed some of the components, in this
>>> case tomcat maybe.
>>> anyway if you install geoserver manually be sure to use the one provided
>>> by geonode http://build.geonode.org/geoserver/latest/geoserver.war.
>>> what link is broken, exactly?
>>> 2016-01-13 1:23 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>> Finnaly I got it almost working but for some reason it appears that
>>>> using the apt-get instalation, geoserver was not installed. Trying to
>>>> manual install it.
>>>> The homepage has also a problem. It's weird but it appears that
>>>> something redirects the link to some page that is not present on geonode.
>>>> All the other links are working correctly.
>>>> Thank you!
>>>> 2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>> Hi everyone,
>>>>> So, after trying on localhost and themed my instalation to my needs, I
>>>>> am installing geonode on the production server. I am again with some doubts
>>>>> on the configuration. The automatic configuration file geonode.conf was
>>>>> changed by me on:
>>>>> <VirtualHost *:80>
>>>>> Servername atlas.example.com
>>>>> ServerAlias atlas.example.com
>>>>> When I try to reach geoserver I get a apache tomcat 404. should i
>>>>> change also on that file, the proxypass "localhost" to "
>>>>> atlas.example.com"? These are the lines:
>>>>> ProxyPass /geoserver http://localhost:8080/geoserver
>>>>> ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>>> My 000-default.conf was working with the www.example.com on a CMS,
>>>>> now the configuration is redirecting to geoserver landing page. On other
>>>>> hand atlas.example.com shows geonode with "page not found error"
>>>>> On my local_settings.py I changed the SITEURL= '
>>>>> http://atlas.example.com' and ALLOWED_HOSTS=['atlas.example.com','
>>>>> www.example.com']
>>>>> Hoping that you can help me,
>>>>> Best regards,
>>>>> Ivo
>>>>> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>> Simone,
>>>>>> Thank you for your help. I am testing on a lamp instalation on my
>>>>>> laptop. For now I will test other aspects and leave that part for the
>>>>>> production environment.
>>>>>> Best regards,
>>>>>> Ivo
>>>>>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com
>>>>>>> Ivo, if your server doesn't have a name (just the ip address) then
>>>>>>> you cannot have multiple sites under the root. if you have a domain name
>>>>>>> then you can take a look at the apache virtualhost configuration
>>>>>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>>>>>> hope this helps
>>>>>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>>> Hi Simone,
>>>>>>>> Thank you for showing me the correct way. I managed to use geonode
>>>>>>>> on a subdomain like you suggested. But now every other site on the server
>>>>>>>> is giving error "Bad Request (400)". Probably this is a common error due to
>>>>>>>> my inexperience with apache. If this questions are not for this list please
>>>>>>>> let me know.
>>>>>>>> Regards,
>>>>>>>> Ivo
>>>>>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <
>>>>>>>>> Hi Ivo,
>>>>>>>>> Geonode works at the root of the domain and you cannot serve it
>>>>>>>>> under /geonode unless you change the code or maybe do some tricks with
>>>>>>>>> Apache. Not sure if someone else has tried that. The suggestion is to keep
>>>>>>>>> at the root but serve it with an Apache virtualhost when you have a domain
>>>>>>>>> name. Like geonode.yourdomain.com.
>>>>>>>>> Regards
>>>>>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha
>>>>>>>>> scritto:
>>>>>>>>>> Hi everyone,
>>>>>>>>>> I am new to geonode and testing the possibility of using it on my
>>>>>>>>>> work. For now, I am trying to install Geonode for production.
>>>>>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But
>>>>>>>>>> when I try to reach that page it appears "page not found". The homepage of
>>>>>>>>>> geonode remains http://10.0.2.15
>>>>>>>>>> Am I missing something here? Can you help me? If you need any
>>>>>>>>>> kind of information, please ask.
>>>>>>>>>> Best regards and thank you in advance,
>>>>>>>>>> Ivo
>>>>>>>>>> Ivo Santos
>>>>>>>>> Simone
>>>>>>>> Ivo Santos
>>>>>>> Simone
>>>>>> Ivo Santos
>>>>> Ivo Santos
>>>> Ivo Santos
>>> Simone
>> Ivo Santos
> Simone
Ivo Santos
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160113/8278897f/attachment.html>
More information about the geonode-users
