[GeoNode-users] Geonode error "page not found" on production install
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jan 13 01:52:51 PST 2016
I think it should but each configuration should live in it's own
virtualhost, so one for suphp and one for geonode. with different
subdomains.
2016-01-13 10:50 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
> Ok, can you tell me if geonode is compatible with suphp? I am trying to
> explore if it is a compatibility issue.
> 2016-01-13 9:48 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> that is definitely an apache misconfiguration, maybe of the php module.
>> 2016-01-13 10:43 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>> Hi Simone,
>>> Yes, tomcat was already instaled. I used the geoserver.war on that link
>>> and now that part is working great.
>>> For now the only problem it's just the link of the homepage. For
>>> example, if I try to go to my homepage atlas.example.com I am being
>>> redirected to atlas.example.com/init/index.php and not to the geonode
>>> homepage.
>>> I had a previous configuration with another webgis using that subdomain.
>>> Do you think it could be a wrong configuration on apache or on geonode?
>>> Thank you for all the help and guidance,
>>> Ivo
>>> 2016-01-13 8:22 GMT+00:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Hi Ivo,
>>>> one of the reasons why the apt-get installation can fail could be that
>>>> on the machine there were already installed some of the components, in this
>>>> case tomcat maybe.
>>>> anyway if you install geoserver manually be sure to use the one
>>>> provided by geonode
>>>> http://build.geonode.org/geoserver/latest/geoserver.war.
>>>> what link is broken, exactly?
>>>> 2016-01-13 1:23 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>> Finnaly I got it almost working but for some reason it appears that
>>>>> using the apt-get instalation, geoserver was not installed. Trying to
>>>>> manual install it.
>>>>> The homepage has also a problem. It's weird but it appears that
>>>>> something redirects the link to some page that is not present on geonode.
>>>>> All the other links are working correctly.
>>>>> Thank you!
>>>>> 2016-01-12 20:25 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>> Hi everyone,
>>>>>> So, after trying on localhost and themed my instalation to my needs,
>>>>>> I am installing geonode on the production server. I am again with some
>>>>>> doubts on the configuration. The automatic configuration file geonode.conf
>>>>>> was changed by me on:
>>>>>> <VirtualHost *:80>
>>>>>> Servername atlas.example.com
>>>>>> ServerAlias atlas.example.com
>>>>>> When I try to reach geoserver I get a apache tomcat 404. should i
>>>>>> change also on that file, the proxypass "localhost" to "
>>>>>> atlas.example.com"? These are the lines:
>>>>>> ProxyPass /geoserver http://localhost:8080/geoserver
>>>>>> ProxyPassReverse /geoserver http://localhost:8080/geoserver
>>>>>> My 000-default.conf was working with the www.example.com on a CMS,
>>>>>> now the configuration is redirecting to geoserver landing page. On other
>>>>>> hand atlas.example.com shows geonode with "page not found error"
>>>>>> On my local_settings.py I changed the SITEURL= '
>>>>>> http://atlas.example.com' and ALLOWED_HOSTS=['atlas.example.com','
>>>>>> www.example.com']
>>>>>> Hoping that you can help me,
>>>>>> Best regards,
>>>>>> Ivo
>>>>>> 2016-01-09 17:36 GMT+00:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>> Simone,
>>>>>>> Thank you for your help. I am testing on a lamp instalation on my
>>>>>>> laptop. For now I will test other aspects and leave that part for the
>>>>>>> production environment.
>>>>>>> Best regards,
>>>>>>> Ivo
>>>>>>> 2016-01-08 10:42 GMT+00:00 Simone Dalmasso <
>>>>>>>> Ivo, if your server doesn't have a name (just the ip address) then
>>>>>>>> you cannot have multiple sites under the root. if you have a domain name
>>>>>>>> then you can take a look at the apache virtualhost configuration
>>>>>>>> https://httpd.apache.org/docs/2.2/vhosts/examples.html.
>>>>>>>> hope this helps
>>>>>>>> 2016-01-08 11:39 GMT+01:00 Ivo Santos <ivojfs at gmail.com>:
>>>>>>>>> Hi Simone,
>>>>>>>>> Thank you for showing me the correct way. I managed to use geonode
>>>>>>>>> on a subdomain like you suggested. But now every other site on the server
>>>>>>>>> is giving error "Bad Request (400)". Probably this is a common error due to
>>>>>>>>> my inexperience with apache. If this questions are not for this list please
>>>>>>>>> let me know.
>>>>>>>>> Regards,
>>>>>>>>> Ivo
>>>>>>>>> 2016-01-08 7:36 GMT+00:00 Simone Dalmasso <
>>>>>>>>>> Hi Ivo,
>>>>>>>>>> Geonode works at the root of the domain and you cannot serve it
>>>>>>>>>> under /geonode unless you change the code or maybe do some tricks with
>>>>>>>>>> Apache. Not sure if someone else has tried that. The suggestion is to keep
>>>>>>>>>> at the root but serve it with an Apache virtualhost when you have a domain
>>>>>>>>>> name. Like geonode.yourdomain.com.
>>>>>>>>>> Regards
>>>>>>>>>> Il giovedì 7 gennaio 2016, Ivo Santos <ivojfs at gmail.com> ha
>>>>>>>>>> scritto:
>>>>>>>>>>> Hi everyone,
>>>>>>>>>>> I am new to geonode and testing the possibility of using it on
>>>>>>>>>>> my work. For now, I am trying to install Geonode for production.
>>>>>>>>>>> I instaled via apt-get with the snapshots repository on latest
>>>>>>>>>>> version of ubuntu. After that I created the superuser, updated the ip and
>>>>>>>>>>> after that changed the local_settings.py (SITEURL = '
>>>>>>>>>>> http://10.0.2.15/geonode/') as on the docs
>>>>>>>>>>> <http://docs.geonode.org/en/dev/deploy/production.html>. But
>>>>>>>>>>> when I try to reach that page it appears "page not found". The homepage of
>>>>>>>>>>> geonode remains http://10.0.2.15
>>>>>>>>>>> Am I missing something here? Can you help me? If you need any
>>>>>>>>>>> kind of information, please ask.
>>>>>>>>>>> Best regards and thank you in advance,
>>>>>>>>>>> Ivo
>>>>>>>>>>> Ivo Santos
>>>>>>>>>> Simone
>>>>>>>>> Ivo Santos
>>>>>>>> Simone
>>>>>>> Ivo Santos
>>>>>> Ivo Santos
>>>>> Ivo Santos
>>>> Simone
>>> Ivo Santos
>> Simone
> Ivo Santos
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160113/7e5e8145/attachment-0001.html>
More information about the geonode-users
