[GeoNode-users] Create Map interface questions
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jan 18 06:15:53 PST 2016
you can just rewrite the entire MAP_BASELAYERS
2016-01-18 14:21 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi,
> Yes in my local_settings.py I have
> MAP_BASELAYERS = [{
> "source": {
> "ptype": "gxp_wmscsource",
> "url": GEOSERVER_URL + "wms",
> "restUrl": "/gs/rest"
> If I change the URL to GEOSERVER_URL + "geonode/wms" it duplicates the
> entry in the combobox.
> I've found the settings.py file under python2.7/dits-packages/geonode and
> in it I can see what you've mentioned
> LOCAL_GEOSERVER = {
> "source": {
> "url": OGC_SERVER['default']['PUBLIC_LOCATION'] + "wms",
> baselayers = MAP_BASELAYERS
> MAP_BASELAYERS = [LOCAL_GEOSERVER]
> MAP_BASELAYERS.extend(baselayers)
> Should I modify it here?
> Agur bero bat,
> David Alda Fernández de Lezea
> Área de Sistemas de Información Geográfica, Planificación Territorial y
> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
> Arloa.
> dalda at hazi.eus | www.hazi.eus
> T 945 003 240 – M 627 923 170 – F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
> ********************* LEGE OHARRA ******************* AVISOLEGAL
> ******************* DISCLAIMER *****************************
> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
> kontserbatu gabe.
> Este mensaje es personal y confidencial y su uso no autorizado está
> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
> sin reenviarlo ni conservarlo.
> This message is personal and confidential, unauthorised use is legally
> prohibited. If you are not the intended recipient, delete it without
> resending or backing it.
> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
> Enviado el: lunes, 18 de enero de 2016 13:28
> Para: David Alda Fernandez de Lezea
> CC: geonode-users at lists.osgeo.org
> Asunto: Re: [GeoNode-users] Create Map interface questions
> Have you already tried ti change this line?
> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L928
> 2016-01-18 13:10 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi Simone,
> Thanks for your response. The change I want to make in the combo is the
> URL itself . Now it's pointing to http://myip.com/geoserver/wms but I
> want to change it to http://myip.com/geoserver/geonode/wms so I can
> separate the contents into workspaces. Any thoughts?
> Thanks.
> Agur bero bat,
> Arloa.
> kontserbatu gabe.
> Enviado el: lunes, 18 de enero de 2016 10:37
> Hi,
> you can change the name that appears there directly from the geoserver
> admin panel.
> About the ID, I think you would have to change the js code, not very
> easy..., https://github.com/GeoNode/django-geoexplorer, and you would
> have to re-compile it.
> hope it helps
> 2016-01-18 9:50 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
> Hi List,
> I'd like to ask if it's possible and how to edit/customize the following
> cases:
> 1. In the Map Creation part in the Available Servers combobox I'd
> like to change "My Local GeoServer" to point to the geonode workspace (
> http://myip.com/geoserver/geonode/wms) and the caption for another one.
> If I edit the local_settings.py in the MAP_BASELAYERS and change it there
> then it duplicates the entry in the combo. Any ideas how to change it?
> 2. The other thing is how to get the column "ID" (once you've
> chosen a server and list it contents) wider, because I can hardly see the
> names of the layers.
> Thanks in advance,
> Regards,
> Agur bero bat,
> Arloa.
> T 945 003 240 - M 627 923 170 - F 945 003 290
> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
> kontserbatu gabe.
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160118/602e4620/attachment-0001.html>
More information about the geonode-users
