[GeoNode-users] Create Map interface questions
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Jan 18 06:16:43 PST 2016
in your local_setting :)
2016-01-18 15:15 GMT+01:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> you can just rewrite the entire MAP_BASELAYERS
> 2016-01-18 14:21 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
>> Hi,
>> Yes in my local_settings.py I have
>> MAP_BASELAYERS = [{
>> "source": {
>> "ptype": "gxp_wmscsource",
>> "url": GEOSERVER_URL + "wms",
>> "restUrl": "/gs/rest"
>> If I change the URL to GEOSERVER_URL + "geonode/wms" it duplicates the
>> entry in the combobox.
>> I've found the settings.py file under python2.7/dits-packages/geonode and
>> in it I can see what you've mentioned
>> LOCAL_GEOSERVER = {
>> "source": {
>> "url": OGC_SERVER['default']['PUBLIC_LOCATION'] + "wms",
>> baselayers = MAP_BASELAYERS
>> MAP_BASELAYERS = [LOCAL_GEOSERVER]
>> MAP_BASELAYERS.extend(baselayers)
>> Should I modify it here?
>> Agur bero bat,
>> David Alda Fernández de Lezea
>> Área de Sistemas de Información Geográfica, Planificación Territorial y
>> Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren
>> Arloa.
>> dalda at hazi.eus | www.hazi.eus
>> T 945 003 240 – M 627 923 170 – F 945 003 290
>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
>> ********************* LEGE OHARRA ******************* AVISOLEGAL
>> ******************* DISCLAIMER *****************************
>> Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera
>> debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta
>> kontserbatu gabe.
>> Este mensaje es personal y confidencial y su uso no autorizado está
>> prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo,
>> sin reenviarlo ni conservarlo.
>> This message is personal and confidential, unauthorised use is legally
>> prohibited. If you are not the intended recipient, delete it without
>> resending or backing it.
>> De: Simone Dalmasso [mailto:simone.dalmasso at gmail.com]
>> Enviado el: lunes, 18 de enero de 2016 13:28
>> Para: David Alda Fernandez de Lezea
>> CC: geonode-users at lists.osgeo.org
>> Asunto: Re: [GeoNode-users] Create Map interface questions
>> Have you already tried ti change this line?
>> https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L928
>> 2016-01-18 13:10 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus
>> Hi Simone,
>> Thanks for your response. The change I want to make in the combo is the
>> URL itself . Now it's pointing to http://myip.com/geoserver/wms but I
>> want to change it to http://myip.com/geoserver/geonode/wms so I can
>> separate the contents into workspaces. Any thoughts?
>> Thanks.
>> Agur bero bat,
>> Arloa.
>> kontserbatu gabe.
>> Enviado el: lunes, 18 de enero de 2016 10:37
>> Hi,
>> you can change the name that appears there directly from the geoserver
>> admin panel.
>> About the ID, I think you would have to change the js code, not very
>> easy..., https://github.com/GeoNode/django-geoexplorer, and you would
>> have to re-compile it.
>> hope it helps
>> 2016-01-18 9:50 GMT+01:00 David Alda Fernandez de Lezea <dalda at hazi.eus>:
>> Hi List,
>> I'd like to ask if it's possible and how to edit/customize the following
>> cases:
>> 1. In the Map Creation part in the Available Servers combobox I'd
>> like to change "My Local GeoServer" to point to the geonode workspace (
>> http://myip.com/geoserver/geonode/wms) and the caption for another one.
>> If I edit the local_settings.py in the MAP_BASELAYERS and change it there
>> then it duplicates the entry in the combo. Any ideas how to change it?
>> 2. The other thing is how to get the column "ID" (once you've
>> chosen a server and list it contents) wider, because I can hardly see the
>> names of the layers.
>> Thanks in advance,
>> Regards,
>> Agur bero bat,
>> Arloa.
>> T 945 003 240 - M 627 923 170 - F 945 003 290
>> Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute - Araba
>> kontserbatu gabe.
>> geonode-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Simone
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160118/4f798327/attachment.html>
More information about the geonode-users
