[GeoNode-users] Can't upload shapefiles
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Jan 19 07:39:52 PST 2016
Hi Alessio,
this seems more a DNS problem. If the IP of your machine has not changed
then maybe is an issue of your name provider.
2016-01-19 16:30 GMT+01:00 Alessio <alessio.dl at gmail.com>:
> Hi all,
> I installed Geonode 2.0 on Ubuntu 12.04 using APT several months ago.
> It always worked fine, but now I'm having problems performing shapefiles
> uploads (and even removing them using geonode UI).
> The error is "Unable to find server at geoportale.izs.it"
> I checked /etc/geonode/local_settings.py and the SITEURL variable is set
> to my address "http://geoportale.izs.it"
> GeoServer's Settings -> Global looks good, with Proxy Base URL set to
> http://geoportale.izs.it/geoserver/
> In /usr/share/geoserver/data/security/auth/geonodeAuthProvider/config.xml
> I have <baseUrl>http://geoportale.izs.it</baseUrl>
> So, for what I can see, all looks correct.
> What can I do to fix this? Thank you
> Alessio
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20160119/ba4c80b6/attachment.html>
More information about the geonode-users
