[GeoNode-users] GeoNode-GeoExplorer advice
    David Alda Fernandez de Lezea
    dalda at hazi.eus
    Thu Jan 21 04:03:24 PST 2016
Hi again,
It seems that if you're behind a proxy the git protocol is cut out. I managed to get through this changing git local commands config by entering this in the console
git config --global url."https://".insteadOf git://
Source https://github.com/Polymer/polymer/issues/1468
It starts to download everything required but there's an error just in the final part. Not sure if it has something to do with geoexplorer
Cloning into 'geoserver/externals/geoserver-exts'...
remote: Counting objects: 15821, done.
emote: Total 15821 (delta 0), reused 0 (delta 0), pack-reused 15821
Receiving objects: 100% (15821/15821), 7.78 MiB | 2.21 MiB/s, done.
Resolving deltas: 100% (5145/5145), done.
Checking connectivity... done.
Submodule path 'geoserver/externals/geoserver-exts': checked out '3fd1427dab0ad4
6b74e4c8cf6367e84ef7aa79b6'
Cloning into 'geoserver/externals/geotools'...
remote: Counting objects: 154190, done.
remote: Total 154190 (delta 0), reused 0 (delta 0), pack-reused 154190
Receiving objects: 100% (154190/154190), 107.37 MiB | 5.41 MiB/s, done.
Resolving deltas: 100% (73641/73641), done.
error: unable to create file modules/unsupported/coverage-experiment/coverage-ap
i/src/test/resources/org/geotools/coverage/io/catalog/test-data/.IASI_C_EUMP_201
21120062959_31590_eps_o_l2/IASI_C_EUMP_20121120062959_31590_eps_o_l2.14.log.db (
Filename too long)
21120062959_31590_eps_o_l2/IASI_C_EUMP_20121120062959_31590_eps_o_l2.data.db (Fi
lename too long)
21120062959_31590_eps_o_l2/IASI_C_EUMP_20121120062959_31590_eps_o_l2.index.db (F
ilename too long)
21120062959_31590_eps_o_l2/IASI_C_EUMP_20121120062959_31590_eps_o_l2.trace.db (F
ilename too long)
Cloning into 'geoserver/externals/geowebcache'...
remote: Counting objects: 31625, done.
remote: Total 31625 (delta 0), reused 0 (delta 0), pack-reused 31625
Receiving objects: 100% (31625/31625), 6.14 MiB | 2.85 MiB/s, done.
Resolving deltas: 100% (12160/12160), done.
Submodule path 'geoserver/externals/geowebcache': checked out '5420d1aeb5e2e06d1
64b2f0cc1f3a58963cdd2b1'
Unable to checkout 'c3ab16a384370cff7de5b0c60782901852ed4fbd' in submodule path
Once the download is completed I run "ant debug" but it complains saying tha I have to make a clean install.
c:\Datos\Proyectos\42_GEONODE\suite\geoexplorer>ant debug
Buildfile: c:\Datos\Proyectos\42_GEONODE\suite\geoexplorer\build.xml
installed:
BUILD FAILED
c:\Datos\Proyectos\42_GEONODE\suite\geoexplorer\build.xml:23: App not yet built.
  Run `mvn clean install` first.
Total time: 0 seconds
All right, I launch de clean install, but it also produces an error! What a nightmare!
c:\Datos\Proyectos\42_GEONODE\suite\geoexplorer>mvn clean install
[INFO] Scanning for projects...
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building OpenGeo Suite GeoExplorer 4-SNAPSHOT
[WARNING] The POM for org.ringojs:ringojs:jar:0.8.1 is missing, no dependency in
formation available
[INFO] BUILD FAILURE
[INFO] Total time: 1.565 s
[INFO] Finished at: 2016-01-21T12:55:59+01:00
[INFO] Final Memory: 7M/155M
[ERROR] Failed to execute goal on project geoexplorer: Could not resolve depende
ncies for project org.opengeo:geoexplorer:jar:4-SNAPSHOT: Failure to find org.ri
ngojs:ringojs:jar:0.8.1 in http://repo.opengeo.org/ was cached in the local repo
sitory, resolution will not be reattempted until the update interval of opengeo
has elapsed or updates are forced -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyReso
lutionException
Any ideas???
Agur bero bat,
David Alda Fernández de Lezea
Área de Sistemas de Información Geográfica, Planificación Territorial y Forestal Informazio Geografikoen Sistemak, Lurralde eta Baso Antolaketaren Arloa.
dalda at hazi.eus | www.hazi.eus
T 945 003 240 – M 627 923 170 – F 945 003 290
Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   *****************************
Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
Este mensaje es personal y confidencial y su uso no autorizado está prohibido legalmente. Si usted no es el destinatario, proceda a borrarlo, sin reenviarlo ni conservarlo.
This message is personal and confidential, unauthorised use is legally prohibited. If you are not the intended recipient, delete it without resending or backing it.
-----Mensaje original-----
De: geonode-users [mailto:geonode-users-bounces at lists.osgeo.org] En nombre de David Alda Fernandez de Lezea
Enviado el: jueves, 21 de enero de 2016 10:21
Para: ingenieroariel at gmail.com; geonode-users at lists.osgeo.org
Asunto: Re: [GeoNode-users] GeoNode-GeoExplorer advice
Hi Ariel,
Thanks for your response.
As my company's firewall is blocking access to git protocol I I used the url http://github.com/GeoNode/suite.git . I got it downloaded but when executing  "git submodule update --init --recursive" I get the following output error:
c:\Datos\Proyectos\42_GEONODE\suite>git submodule update --init --recursive Submodule 'geoexplorer/app/static/externals/geoext' (git://github.com/geoext/geo
ext.git) registered for path 'geoexplorer/app/static/externals/geoext'
Submodule 'geoexplorer/app/static/externals/gxp' (git://github.com/GeoNode/gxp.g
it) registered for path 'geoexplorer/app/static/externals/gxp'
Submodule 'geoexplorer/app/static/externals/openlayers' (git://github.com/boundl
essgeo/openlayers.git) registered for path 'geoexplorer/app/static/externals/ope
nlayers'
Submodule 'geoexplorer/app/static/externals/printpreview' (git://github.com/boun
dlessgeo/PrintPreview.git) registered for path 'geoexplorer/app/static/externals /printpreview'
Submodule 'geoexplorer/externals/buildkit' (git://github.com/boundlessgeo/buildk
it.git) registered for path 'geoexplorer/externals/buildkit'
Submodule 'geoexplorer/externals/stick' (https://github.com/hns/stick.git) regis tered for path 'geoexplorer/externals/stick'
Submodule 'geoserver/data_dir/externals/suite-data' (https://github.com/boundles
sgeo/suite-data.git) registered for path 'geoserver/data_dir/externals/suite-dat
a'
Submodule 'geoserver/externals/geoscript/js' (git://github.com/jdeolive/geoscrip
t-js.git) registered for path 'geoserver/externals/geoscript/js'
Submodule 'geoserver/externals/geoscript/py' (git://github.com/jdeolive/geoscrip
t-py.git) registered for path 'geoserver/externals/geoscript/py'
Submodule 'geoserver/externals/geoserver' (git://github.com/boundlessgeo/geoserv
er.git) registered for path 'geoserver/externals/geoserver'
Submodule 'geoserver/externals/geoserver-exts' (git://github.com/boundlessgeo/ge
oserver-exts.git) registered for path 'geoserver/externals/geoserver-exts'
Submodule 'geoserver/externals/geotools' (git://github.com/boundlessgeo/geotools
.git) registered for path 'geoserver/externals/geotools'
Submodule 'geoserver/externals/geowebcache' (git://github.com/boundlessgeo/geowe
bcache.git) registered for path 'geoserver/externals/geowebcache'
Cloning into 'geoexplorer/app/static/externals/geoext'...
fatal: unable to connect to github.com:
github.com[0: 192.30.252.130]: errno=No error
fatal: clone of 'git://github.com/geoext/geoext.git' into submodule path 'geoexp lorer/app/static/externals/geoext' failed
Any ideas?
Thanks in advance.
Regards,
Agur bero bat,
T 945 003 240 – M 627 923 170 – F 945 003 290 Hazi | Granja Modelo de Arkaute s/n | 01192 Arkaute – Araba
*********************  LEGE OHARRA   *******************   AVISOLEGAL   *******************   DISCLAIMER   ***************************** Mezu hau pertsonala eta isilpekoa da eta baimenik gabeko erabilera debekatua dago legalki. Jasotzailea ez bazara ezabatu mezua, bidali eta kontserbatu gabe.
De: Ariel Nunez [mailto:ingenieroariel at gmail.com] Enviado el: miércoles, 20 de enero de 2016 12:31
Para: David Alda Fernandez de Lezea
Hey David,
The process is outlined here:
http://docs.geonode.org/en/master/tutorials/devel/devel_debug/geoexplorer.html
No te desanimes si lo ves un poco enredado, Ariel
On Wed, Jan 20, 2016 at 3:03 AM, David Alda Fernandez de Lezea <dalda at hazi.eus> wrote:
> Hi list,
> I'm looking for some advice on how to add new functionalities to
> GeoNode's GeoExplorer plugin. Generally speaking GeoNode's
> architecture fits my requirements but I would like to add new features
> to the GeoExplorer (custom buttons and OL controls basically)
> Do I have to install GeoNode in development mode or something like that to edit the GeoExplorer?  What would you recommend?
> Any help is much appreciated.
> Thanks in advance.
> Regards,
> Agur bero bat,
> T 945 003 240 - M 627 923 170 - F 945 003 290 Hazi | Granja Modelo de
> Arkaute s/n | 01192 Arkaute - Araba
> geonode-users mailing list
> http://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users
